查看: 5131|回复: 17
[Toshiba] 影驰240G 主控PS3111芯片thgbf7t0l8lbata
发表于 2020-8-1 18:03:22 | 显示全部楼层 |阅读模式
求开卡方法。
发表于 2022-10-8 17:42:41 | 显示全部楼层
我也有一块这个240G的影驰,现在坏掉, 短接才可以看见
Model: SATAFIRM   S11
Fw   : SBFM81W3
Firmware lock supported [29 00 01 02]
Drive unlocked [29 00 01 03]
P/N  : 511-180615223   , SBSM81.1
S11fw: SBFM81.3, 2018Sep18
S11rv: M81.2-D3
Original Model: GALAX TA1D0240A
Bank00: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank01: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank02: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank03: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank04: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank05: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank06: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank07: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank08: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank09: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank10: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank11: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank12: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank13: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank14: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank15: 0x98,0x3a,0x94,0x93,0x76,0xd1,0x8,0x4 - Toshiba 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Controller    : PS3111
Flash CE      : 16
Flash Channel : 2
Dram Size,MB  : 32
Flash CE Mask : [++++++++ ++++++++]
Flash Mode/Clk: 2/10 (Set 2/10)
Block per Die : 4212
Block per CE  : 4212
Page per Block: 256
SLC Cache     : 786432(0xc0000)
用 PS3111 SSD MP Tool Pro Plus v2.2.70可以识别, 但开卡失败
按照SBFM81W3,用SBFM81.3_05092018.BIN,SBFM81.3_18092018.BIN制作固件均刷机成功, 但重新开机, 连SSD都看不见而失败。
发表于 2022-9-5 17:26:33 | 显示全部楼层
这里点点那里点点
发表于 2022-1-3 00:47:50 | 显示全部楼层
有成功的吗?我是金百达 kp310 240g的也是这样
发表于 2020-8-14 13:36:48 | 显示全部楼层
冶具很贵。3111网上有人开卡成功,成功率很低
发表于 2020-8-14 06:27:39 来自手机浏览器 | 显示全部楼层
不是说3111要冶具吗
发表于 2020-8-14 00:13:26 | 显示全部楼层
PS3111的主控好像暂时都开不出来,已经研究一月了。有成功的分享一下吧
 楼主| 发表于 2020-8-6 12:21:06 | 显示全部楼层
有没有大神分享一下。表示无从下手。   手上好几个PS3111了
 楼主| 发表于 2020-8-6 12:20:27 | 显示全部楼层
cheng9032 发表于 2020-8-3 15:44
我也在用这个软件开金士顿a400,一直开卡报红,表示玩不懂!
表示同样玩不懂,又得到一个士必得的盘也是PS3111的
发表于 2020-8-3 15:56:18 | 显示全部楼层
我也遇到这个问题了
发表于 2020-8-3 15:44:57 来自手机浏览器 | 显示全部楼层
发表于 2020-8-2 22:24:09 | 显示全部楼层
3111+UFS的盘
发表于 2020-8-2 21:06:12 | 显示全部楼层
目测是翻新出售
发表于 2020-8-2 01:24:08 | 显示全部楼层
你这个Flash id 检测结果到底怎样啊,截图不是运行完毕的结果吧
发表于 2020-8-1 19:54:52 | 显示全部楼层
去问卖治具和开卡软件给你的人呀!
 楼主| 发表于 2020-8-1 19:43:59 | 显示全部楼层
技术宅小唐 发表于 2020-8-1 18:34
都是中文界面了,别求啦自己研究,这里点点哪里点点,慢慢摸索
开不出。点开始,几秒就红了。
头像被屏蔽
发表于 2020-8-1 18:55:58 | 显示全部楼层
我没用过这个 但给我我就能开
发表于 2020-8-1 18:34:02 | 显示全部楼层
回复 支持 0 反对 1
GMT+8, 2025-7-19 09:44 , Processed in 0.265201 second(s), 12 queries , Redis On.
