查看: 3629|回复: 16
[SandForce] 威刚SX300容量120G主控SF2281,颗粒编号60073200颗粒测试不通过是不是没有办...
发表于 2021-8-2 11:10:59 | 显示全部楼层 |阅读模式
威刚SX300容量120G的mSATA,主控SF2281,颗粒编号60073200颗粒测试不通过是不是没有办...
试了好多ID都不可以,然后再这论坛里有大神提示说是NQ314,用6.0.A固件里的22144ID,SF-2281 128GB Micron34 MLC BGA 4xMT29F256G08CUCBBH3 (RAISE OFF),可以走到颗粒测试这里,但是测试不通过,是不是颗粒坏了,这个硬盘是4个颗粒。
./SF_Genesis -PROCESS_SSD 84:0:0:0 /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22142.12345.t1.driveconfig 12345 www_123 log=/log/
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 08/02/2021 10:28:46] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 84:0:0:0
                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22142.12345.t1.driveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=/log/
[Mon 08/02/2021 10:28:46] - Instructing the operating system to purge any existing cached data for device: '84:0:0:0'
[Mon 08/02/2021 10:28:51] - Issuing a discovery command for device: '84:0:0:0'
[Mon 08/02/2021 10:28:56] - Discovery command completed...
[Mon 08/02/2021 10:28:56] - Waiting 5 seconds for the system to settle...
[Mon 08/02/2021 10:29:01] - Device designation string '84:0:0:0' is mapped to node '/dev/sg2'
[Mon 08/02/2021 10:29:01] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22142.12345.t1.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Mon 08/02/2021 10:29:02] - Successfully received the IDENTIFY data from the drive...
[Mon 08/02/2021 10:29:02] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Mon 08/02/2021 10:29:02] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Mon 08/02/2021 10:29:02] - file  /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22142.12345.t1.driveconfig Loaded successfully
[Mon 08/02/2021 10:29:02] - Warning:  Unable to query diagnostics information to perform power management settings check
[Mon 08/02/2021 10:29:02] - B01 Power Management configuration request detected
[Mon 08/02/2021 10:29:02] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22142.12345.t1.driveconfig
[Mon 08/02/2021 10:29:02] - Extracted Config_ID: 1 (22142) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22142.12345.t1.driveconfig
[Mon 08/02/2021 10:29:02] - Extracted SerialOutputControl: 0
[Mon 08/02/2021 10:29:02] - Searching for flashware image for configuration 22142
[Mon 08/02/2021 10:29:02] - Manifest found for configuration 22142
[Mon 08/02/2021 10:29:02] - Flashware image extracted: 22142_fw_cl_mlc_Micron_32Gb_MT29F128G08CKCBBH2_2Q_2C_2D_PP_R00483_s512.vic
[Mon 08/02/2021 10:29:02] - Searching for manufacturing image for configuration 22142
[Mon 08/02/2021 10:29:02] - Manufacturing image extracted: 22142_mf_mlc_Micron_32Gb_MT29F128G08CKCBBH2_2Q_2C_2D_PP_R00483_s512.vic
[Mon 08/02/2021 10:29:02] - Proceeding in ROM mode, download feature 3...
[Mon 08/02/2021 10:29:03] - Successfully downloaded MFB to the drive...
[Mon 08/02/2021 10:29:03] - Waiting (5 sec) for the drive to settle...
[Mon 08/02/2021 10:29:08] - Successfully received the IDENTIFY data from the drive...
[Mon 08/02/2021 10:29:08] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Mon 08/02/2021 10:29:08] - Successfully enabled SMART capabilities...
[Mon 08/02/2021 10:29:11] - Successfully issued a diagnostic unlock...
[Mon 08/02/2021 10:29:12] - Performing the flash test of block 0 (0x0000)...
[Mon 08/02/2021 10:29:13] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 2
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 1    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 1    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 1    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 32
            Number of failures: 16
         Number of Passed with warnings: 0
      No. Passed without warnings: 16
[Mon 08/02/2021 10:29:13] - End of Genesis manufacturing log.
[Mon 08/02/2021 10:29:13] - Exiting...
[Mon 08/02/2021 10:29:13] - Overall Result for Device: /dev/sg2 ****** FAIL ******
发表于 2024-10-31 16:13:38 | 显示全部楼层
一样标识的Adata SX300 128GB mSATA,掉固件后不识别
短接J1后进入rom模式,用 SandForce SSD Information v0.431a by vlo 测试结果如下:
NAND ID     : 0x89, 0x88, 0x24, 0x4b, 0xa9, 0x0, 0x0, 0x0
Flash CE    : 32
Bank00: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank01: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank02: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank03: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank08: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank09: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank10: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank11: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank16: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank17: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank18: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank19: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank24: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank25: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank26: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
Bank27: 0x89,0x88,0x24,0x4b,0xa9,0x0,0x0,0x0 - Intel 25nm(L74A) MLC 64Gb/CE 64Gb/die
补充内容 (2024-11-2 13:27):
ADATA SX300 mSATA 128GB,颗粒编号60073200,按sf_info的信息,闪存id为 8988244BA900,4片闪存,每片4CE
发表于 2021-8-15 11:12:56 | 显示全部楼层
用我2281开卡经验来看 ,你最好拆一颗测正在的id   应该是代码选错了
发表于 2021-8-11 01:40:21 | 显示全部楼层
这个盘应该就是BGA100的NQ314 实在不行拆一颗上测试架看看
 楼主| 发表于 2021-8-10 19:27:05 | 显示全部楼层
wzcgx 发表于 2021-8-4 15:49
有时候开威刚的盘可能要另想办法,必须读出闪存ID
谢谢您的回复,这个不识别只能进ROM模式,进这个模式对不出ID。
Starting command:[/root/Desktop/sf2281/SF_Genesis-v1.7/SF_Genesis -READ_FLASH_ID 91:0:0:0 LOG="/root/Desktop/sf2281/ID /1_localhost.localdomain_DATETIMESTAMP_91.0.0.0_READ_FLASH_ID_RESULT.log" 19:0:0:0]...
[Tue 08/10/2021 19:23:47] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -READ_FLASH_ID
                      argv[2]: 91:0:0:0
                      argv[3]: LOG=/root/Desktop/sf2281/ID /1_localhost.localdomain_DATETIMESTAMP_91.0.0.0_READ_FLASH_ID_RESULT.log
                      argv[4]: 19:0:0:0
[Tue 08/10/2021 19:23:47] - Instructing the operating system to purge any existing cached data for device: '91:0:0:0'
[Tue 08/10/2021 19:23:52] - Issuing a discovery command for device: '91:0:0:0'
[Tue 08/10/2021 19:23:57] - Discovery command completed...
[Tue 08/10/2021 19:23:57] - Waiting 5 seconds for the system to settle...
[Tue 08/10/2021 19:24:02] - Device designation string '91:0:0:0' is mapped to node '/dev/sg2'
[Tue 08/10/2021 19:24:03] - FATAL_ERROR: Read Flash ID operation failed.
[Tue 08/10/2021 19:24:03] - End of Genesis manufacturing log.
[Tue 08/10/2021 19:24:03] - Exiting...
[Tue 08/10/2021 19:24:03] - Overall Result for Device:  ****** FAIL ******
Process exited with code 1
发表于 2021-8-4 15:49:40 | 显示全部楼层
发表于 2021-8-4 15:48:27 | 显示全部楼层
现在用开卡软件读一下闪存ID
 楼主| 发表于 2021-8-4 15:03:31 | 显示全部楼层
wzcgx 发表于 2021-8-4 14:57
明显是不对的,因为NQ314是单颗4ce的,你这个颗粒是单颗8ce的.硬盘是多大的?
我这是四个颗粒的,容量总共是128G的
发表于 2021-8-4 14:57:46 | 显示全部楼层
 楼主| 发表于 2021-8-3 18:02:08 | 显示全部楼层
sjzjiawei 发表于 2021-8-3 09:25
让你用22144的ID开卡。你为什么选22142的ID开呢?
试了好多ID都不可以。然后有大神说可能是NQ314,查了下NQ314是镁光34制程的所以用22144.22143,22142错误都是这样一半颗粒测试不通过。其他都是说固件错误。
发表于 2021-8-3 09:25:14 | 显示全部楼层
 楼主| 发表于 2021-8-2 22:28:13 来自手机浏览器 | 显示全部楼层
luo0271127 发表于 2021-8-2 18:25
这里是主控核心供电,阻值低是正常的。应该不是这的问题。
啊,是这样啊,那就不知道哪里问题了。
发表于 2021-8-2 18:25:10 | 显示全部楼层
danny@zzc 发表于 2021-8-2 15:34
谢谢大神回复,测了电容,手指的两个电容是导通的。
 楼主| 发表于 2021-8-2 15:34:33 来自手机浏览器 | 显示全部楼层
丶陪妳看流星 发表于 2021-8-2 15:00
像这种有规律的一半可以过不了测试,查一下板子,肯定是哪里有问题
 楼主| 发表于 2021-8-2 15:00:35 | 显示全部楼层
527945545 发表于 2021-8-2 13:40
有一半颗粒测试不过啊
是的,大神,问下这个能开一半容量吗?
发表于 2021-8-2 15:00:03 | 显示全部楼层
发表于 2021-8-2 13:40:09 | 显示全部楼层
有一半颗粒测试不过啊
GMT+8, 2025-7-20 01:15 , Processed in 0.234000 second(s), 12 queries , Redis On.
