MA5626(config)#display board
{ desc<K>|frameid[/slotid]<S><Length 1-15> }:0
Command:
display board 0
SlotID BoardName Status SubType0 SubType1 Online/Offline
0 H822EPUB Active_normal UP2A
1 H821EPFE Normal
2
MA5626(config)#display board 0/0
Board Name : H822EPUB
Board Status : Active normal
Subboard[0]: H831UP2A Status: Normal
Port Port Optic MDI Speed Duplex Flow- Active Link
Type Status (Mbps) Ctrl State
1 GE normal - auto auto off active offline
2 GE normal - auto auto off active offline
Note: For a 1000 M, electrical port in the full-duplex mode, setting MDI to
any value is invalid
MA5626(config)#display board 0/1
Board Name : H821EPFE
Board Status : Normal
1 GE - auto auto auto off active offline
2 GE - auto auto_1000 auto_full off active online
3 GE - auto auto_1000 auto_full off active online
4 GE - auto auto auto off active offline
5 FE - auto auto auto off active offline
6 FE - auto auto auto off active offline
7 FE - auto auto_100 auto_full off active online
8 FE - auto auto auto off active offline
MA5626(config)#load packetfile tftp 10.10.10.99 MA5620H822Epub_packetfile_all.bin
The new packet file will overwrite the old one
Rollback function will be disabled
Be sure that the system needn't this function
Are you sure to load new packet file? (y/n)[n]:y
Load(backup...) begins, please wait and notice the rate of progress Any
operation such as reboot will cause failure and unpredictable result
MA5626(config)#
The loading starts
PARAMETERS :FrameID: 0, SlotID: 0, Position: -1, Load type: Packet file, Load Object: Active control board
After loading file, you must reboot system to make file take effect
MA5626(config)#port mode
Command:
port mode
% Incomplete command, the error locates at '^'
MA5626(config)# reboot system
Please check whether data has saved, the unsaved data will lose if reboot
system, are you sure to reboot system? (y/n)[n]:y
MA5626(config)#
Platform System start ...
Memory Data Bus Test .................pass.
Memory Address Bus Test .................pass.
Press 'Ctrl+T' To Start Memory Complete Test
Trace code : 0x11060A01
Copy from ROM to RAM ...... OK!
Uncompress from ROM to RAM ...... OK!
System Vfs init...OK
The latest reboot is caused by : others
Copyright (c) 1998 - 2015 by Huawei Technologies Co.,Ltd.
All Rights Reserved.
The last update date of base BIOS B is : Mar 3 2015 19:58:38
BOARD INFORMATION :
CPU: ARM Integrator - ARM1176JF (ARM). Processor running at 533Mhz
256M bytes DDRAM, 64M bytes flash memory installed on board
Baudrate of serial channel is 9600bps
Board's LAN IP address is 10.11.104.2
Board's LAN Subnet mask is 255.255.255.0
Board's LAN MAC address is 5C:4C:A9:13:4E:70
System is booting from base BIOS...
Base BIOS version is 116
Press <D> key to stop auto-boot 0
Now system will boot from flash memory.
Last update bios succeed, synchronize data ...OK!
Transferring control to the loaded program...OK!
System is upgrading database.... start
System is upgrading database.... 3%
System is upgrading database.... 15%
System is upgrading database.... 30%
System is upgrading database.... 45%
System is upgrading database.... 51%
System is upgrading database.... 90%
System is upgrading database.... 91%
System is upgrading database.... 100%
System is upgrading database.... success
Trace code : 0x11060A02
The last update date of base BIOS A is : Mar 3 2015 19:58:38
BOARD INFORMATION :
Testing Flash memory...OK!
Select area information : Program Area B ,Data Area B .
Begin to expand program... OK!
Starting system application init......successfully!
Starting system configuration data init...successfully!
Press any key to get started
>>User name:root
>>User password:
Huawei Integrated Access Software (MA5620).
Copyright(C) Huawei Technologies Co., Ltd. 2002-2012. All rights reserved.
MA5626>
User root has used a default password. Change the password in time.
MA5626>enable
MA5626#config
MA5626(config)#interface eth 0/1
MA5626(config-if-eth-0/1)#poe ?
Command of eth Mode:
all All ports
legacy Poe legacy state
portid<U><1,8> Port ID
power-management PD equipment power-management
temperature-protection
Set poe temperature-protection
MA5626(config-if-eth-0/1)#display poe all
PortId PowerSwitch POEStatus PowerMode Priority MaxPower(mW) PowerStatus
1 enable disable signalmode low 15400 detecting
2 enable disable signalmode low 15400 detecting
3 enable disable signalmode low 15400 detecting
4 enable disable signalmode low 15400 detecting
5 enable disable signalmode low 15400 detecting
6 enable disable signalmode low 15400 detecting
7 enable disable signalmode low 15400 detecting
8 enable disable signalmode low 15400 power_ready
MA5626(config-if-eth-0/1)#poe 5 enable mode signal priority low max-power 30000
MA5626(config-if-eth-0/1)#poe 6 enable mode signal priority low max-power 30000
MA5626(config-if-eth-0/1)#poe 7 enable mode signal priority low max-power 30000
MA5626(config-if-eth-0/1)#poe 8 enable mode signal priority low max-power 30000
5 enable disable signalmode low 30000 detecting
6 enable disable signalmode low 30000 detecting
7 enable disable signalmode low 30000 detecting
8 enable enable signalmode low 30000 powered
MA5626>display patch all
Software Version:MA5626V800R312C00
SPC200
SPH219
HP2118
Current Patch State:
Patch Name Patch State Delivery Attribute Dependency
SPC200 running common cold patch NO
SPH219 running common hot patch NO
HP2118 running common hot patch NO
Total:3
Patches in the system cannot be rolled back
MA5626>display version
{ <cr>|backplane<K>|frameid/slotid<S><Length 1-15> }:
Command:
display version
VERSION : MA5626V800R312C00
PATCH : SPC200 SPH219 HP2118
PRODUCT : MA5626
Mainboard Running Area Information:
Current Program Area : Area B
Current Data Area : Area B
Program Area A Version : MA562XV800R308C00
Program Area B Version : MA5620V800R312C00
Data Area A Version : MA562XV800R308C00
Data Area B Version : MA5620V800R312C00
Copyright (c) Huawei Technologies Co., Ltd. 2002-2012 All rights reserved
Uptime is 0 day(s), 0 hour(s), 19 minute(s), 15 second(s)
