查看: 1953|回复: 25
[闪存] SLC传家宝U盘
发表于 2024-6-25 09:51:31 | 显示全部楼层 |阅读模式
找到一块N年前的USB2.0的U盘,居然还是SLC的。
90nm SLC,10万次擦除寿命,应该属于牢不可破,坚固无比的了。
Reliable CMOS Floating-Gate Technology
- Endurance : 100K Program/Erase Cycles
- Data Retention : 10 Years
可惜是USB2.0,老掉牙的主控。
 主控厂商: SMI(慧荣)
 主控型号: SM323AD - ISP 2005-08-19
闪存识别码: ECDCC115 - Samsung(三星) K9K4G08U0M - 1CE/双通道 [SLC-2K] -> 总容量 = 1GB
可能的闪存型号
[1CE]K9K4G08U0M(90nm) x 1片/通道 x 2通道
FEATURES
· Voltage Supply
-1.8V device(K9K4GXXQ0M): 1.70V~1.95V
-3.3V device(K9XXGXXUXM): 2.7 V ~3.6 V
· Organization
- Memory Cell Array
-X8 device(K9XXG08XXM) : (512M + 16,384K)bit x 8bit
-X16 device(K9XXG16XXM) : (256M + 8,192K)bit x 16bit
- Data Register
-X8 device(K9XXG08XXM): (2K + 64)bit x8bit
-X16 device(K9XXG16XXM): (1K + 32)bit x16bit
- Cache Register
-X8 device(K9XXG08XXM) : (2K + 64)bit x8bit
-X16 device(K9XXG16XXM) : (1K + 32)bit x16bit
· Automatic Program and Erase
- Page Program
-X8 device(K9XXG08XXM) : (2K + 64)Byte
-X16 device(K9XXG16XXM) : (1K + 32)Word
- Block Erase
-X8 device(K9XXG08XXM) : (128K + 4K)Byte
-X16 device(K9XXG16XXM) : (64K + 2K)Word
· Page Read Operation
- Page Size
- X8 device(K9XXG08XXM) : 2K-Byte
- X16 device(K9XXG16XXM) : 1K-Word
- Random Read : 25ms(Max.)
- Serial Access : 50ns(Min.)
30ns(Min., K9XXG08UXM only)
· Fast Write Cycle Time
- Program time : 300ms(Typ.)
- Block Erase Time : 2ms(Typ.)
· Command/Address/Data Multiplexed I/O Port
· Hardware Data Protection
- Program/Erase Lockout During Power Transitions
· Reliable CMOS Floating-Gate Technology
· Command Register Operation
· Cache Program Operation for High Performance Program
· Power-On Auto-Read Operation
· Intelligent Copy-Back Operation
· Unique ID for Copyright Protection
· Package :
- K9XXGXXXXM-YCB0/YIB0
48 - Pin TSOP I (12 x 20 / 0.5 mm pitch)
- K9W8G08U1M-YCB0/YIB0 : Two K9K4G08U0M stacked.
- K9XXGXXXXM-PCB0/PIB0
- K9W8G08U1M-PCB0/PIB0 : Two K9K4G08U0M stacked.
Offered in 512Mx8bit or 256Mx16bit, the K9XXGXXXXM is 4G bit with spare 128M bit capacity. Its NAND cell provides the most
cost-effective solution for the solid state mass storage market. A program operation can be performed in typical 300ms on the 2112-
byte(X8 device) or 1056-word(X16 device) page and an erase operation can be performed in typical 2ms on a 128K-byte(X8 device)
or 64K-word(X16 device) block. Data in the data page can be read out at 50ns cycle time per byte(30ns, only X8 3.3v device) or
word(X16 device). The I/O pins serve as the ports for address and data input/output as well as command input. The on-chip write
controller automates all program and erase functions including pulse repetition, where required, and internal verification and margin
ng of data. Even the write-intensive systems can take advantage of the K9XXGXXXXM¢s extended reliability of 100K program/erase
cycles by providing ECC(Error Correcting Code) with real time mapping-out algorithm. The K9XXGXXXXM is an optimum solution for
arge nonvolatile storage applications such as solid state file storage and other portable applications requiring non-volatility. An ultra
high density solution having two 4Gb stacked with two chip selects is also available in standard TSOPI package.
512M x 8 Bit / 256M x 16 Bit NAND Flash Memory
发表于 2024-6-25 09:54:50 | 显示全部楼层
以前买过一个128M的U盘,后来拿来做PE系统,想想已经很多年没装过系统了。
发表于 2024-6-25 09:56:48 | 显示全部楼层
确实是传家宝系列,可以存重要资料。
发表于 2024-6-25 10:09:32 来自手机浏览器 | 显示全部楼层
我有一个16g的slc,应该可以做传家宝了,好像是15年买的,3.0的,几百兆的都丢完了,就剩下这个贵的了
发表于 2024-6-25 10:10:58 | 显示全部楼层
1G的容量可以存好多好多的小说哦
手中也一个被我用挂了然后量产了又做了个小PE盘
发表于 2024-6-25 10:18:07 | 显示全部楼层
我有一个16G的
发表于 2024-6-25 10:18:38 | 显示全部楼层
我好像也有一个这样的老优盘
 楼主| 发表于 2024-6-25 10:24:37 | 显示全部楼层
nesw 发表于 2024-6-25 10:09
我有一个16g的slc,应该可以做传家宝了,好像是15年买的,3.0的,几百兆的都丢完了,就剩下这个贵的了 ...
16G 3.0还是挺实用的。
发表于 2024-6-25 10:25:20 | 显示全部楼层
容量有点小
发表于 2024-6-25 10:26:43 | 显示全部楼层
我有一个MLC的  ,而且是USB3.0
发表于 2024-6-25 10:26:45 | 显示全部楼层
其它元器件估计也会自然抽坏,所以别想传家
发表于 2024-6-25 10:31:05 | 显示全部楼层
我有一个32G的,银灿902主控,发热量有点大
发表于 2024-6-25 10:44:14 | 显示全部楼层
第一个U盘好像是97块钱买的金士顿1G
发表于 2024-6-25 10:44:51 | 显示全部楼层
SSD有几个SLC的,当时不便宜,一个128G的,一个256G的,大的当时好像一千多吧。现在看只能用作系统盘了。
 楼主| 发表于 2024-6-25 10:54:16 | 显示全部楼层
hzw6834 发表于 2024-6-25 10:44
SSD有几个SLC的,当时不便宜,一个128G的,一个256G的,大的当时好像一千多吧。现在看只能用作系统盘了。 ...
如果SLC容量不太大的话,当虚拟内存、系统缓存(Temp目录)还是挺好用的。这样系统盘可以用上更大容量的TLC,写盘的压力则主要在SLC上。
发表于 2024-6-25 11:08:05 | 显示全部楼层
老古董的U盘,TF卡,SD卡,容量确实有点小,但是也还是有用处的,拷贝一些小文件还是很实用的,留着吧,传个几代人。
发表于 2024-6-25 12:02:58 | 显示全部楼层
这玩意真能留给下一代啊,这么耐操么。
发表于 2024-6-25 12:30:59 | 显示全部楼层
速度慢点不要紧,可靠性高就行!!!
发表于 2024-6-25 13:05:21 | 显示全部楼层
应该说属于传家宝的,以前的老U盘,性能比较稳定
发表于 2024-6-25 16:43:37 | 显示全部楼层
做了好几个128M、512M、1G、2G、16G的SLC U盘。
GMT+8, 2025-7-19 17:01 , Processed in 0.187200 second(s), 11 queries , Redis On.
