发表于 2019-12-15 00:49:27
显示全部楼层
Before presenting any questions, you'd better read the datasheet which is issued by the manufacturer carefully, all the details will be demonstrated on it.
Here are several sentences from the datasheet that may be helpful:
At the beginning of each cycle, the synchronous high-side MOSFET is turned on, or becomes ON-state. This MOSFET is turned off, or becomes OFF-state, after the internal one-shot timer expires. This one-shot is determined by VIN and VOUT to keep the frequency fairly constant over the input voltage range at steady-state, hence it is called adaptive on-time control or fixed frequency emulated on-time control (see PWM Frequency and Adaptive On-Time Control). The MOSFET is turned on again when both feedback information, monitored at VFB voltage, indicates insufficient output voltage and inductor current information indicates below the overcurrent limit. Repeating the operation in this manner, the controller regulates the output voltage. The synchronous lowside or rectifying MOSFET is turned on each OFF-state to keep the conduction loss to a minimum.
