ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
Input Parameters:
argv[1]: -PROCESS_SSD
argv[2]: 8:0:0:0
argv[3]:/home/scoken/fw/FW_PPRO_5_8_2_Release.906190.release--0/FW_PPRO_5_8_2_Release.906190.release.0.mfp
argv[4]:/home/scoken/fw/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22735.0.B1.driveconfig
argv[5]: 12345
argv[6]: www_123
argv[7]:log=/home/scoken/log/
Hostname: SandForce
Port Number: 3
DeviceName: /dev/sg3
SF_Genesis Version:v1.7.0.01020130612-fc14-32bit
SF_Core Library Version:v1.7.1.20130612-fc14-32bit
SF_OS_Information: Linux2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
SandForce Genesis Utilityv1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, AllRights Reserved Worldwide.
[Mon] - SF_Genesis has been invoked withthe following parameters:
argv[2]: 8:0:0:0
argv[5]: 12345
argv[6]: www_123
[Mon] - Instructing the operating system topurge any existing cached data for device: '8:0:0:0'
[Mon] - Issuing a discovery command fordevice: '8:0:0:0'
[Mon] - Discovery command completed...
[Mon] - Waiting 5 seconds for the system tosettle...
[Mon] - Device designation string '8:0:0:0'is mapped to node '/dev/sg3'
[Mon] - Proceeding to process SSD devicewith the following parameters:
DeviceName = /dev/sg3
MFP Package Filename =/home/scoken/fw/FW_PPRO_5_8_2_Release.906190.release--0/FW_PPRO_5_8_2_Release.906190.release.0.mfp
Configuration File = /home/scoken/fw/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22735.0.B1.driveconfig
Serial No. = 12345
World Wide Name = www_123
[Mon] - Successfully received the IDENTIFYdata from the drive...
[Mon] - Validating Manufacturing FirmwarePackage:
[Mon] - Successfully opened the package:
[Mon] - file
/home/scoken/fw/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22735.0.B1.driveconfigLoaded successfully
[Mon] - Warning: Unable to query diagnostics information toperform power management settings check
[Mon] - B01 Power Management configurationrequest detected
[Mon] - Successfully extracted*.DriveConfig file:
[Mon] - Extracted Config_ID: 1 (22735) inDriveConfig file:
[Mon] - Extracted SerialOutputControl: 0
[Mon] - Searching for flashware image forconfiguration 22735
[Mon] - Manifest found for configuration22735
[Mon] - Flashware image extracted:22735_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Mon] - Searching for manufacturing imagefor configuration 22735
[Mon] - Manufacturing image extracted:22735_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Mon] - Proceeding in ROM mode, downloadfeature 3...
[Mon] - Successfully downloaded MFB to thedrive...
[Mon] - Waiting (5 sec) for the drive tosettle...
[Mon] - Firmware revision reported to be:'582ABBM0'. This indicates MFB downloadwas successful.
[Mon] - Successfully enabled SMARTcapabilities...
[Mon] - Successfully issued a diagnosticunlock...
[Mon] - Performing the flash test of block0 (0x0000)...
[Mon] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 2
Chip Enabled Count: 4
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0002 | N3 |WARNING |
| 0 | 0 | 0 | 1 | 0x0002 | N3 |WARNING |
| 0 | 0 | 0 | 2 | 0x0002 | N3 |WARNING |
| 0 | 0 | 0 | 3 | 0x0002 | N3 |WARNING |
| 0 | 1 | 0 | 0 | 0x0002 | N3 |WARNING |
| 0 | 1 | 0 | 1 | 0x0002 | N3 |WARNING |
| 0 | 1 | 0 | 2 | 0x0002 | N3 | WARNING|
| 0 | 1 | 0 | 3 | 0x0002 | N3 |WARNING |
| 0 | 2 | 0 | 0 | 0x0002 | N3 |WARNING |
| 0 | 2 | 0 | 1 | 0x0002 | N3 |WARNING |
| 0 | 2 | 0 | 2 | 0x0002 | N3 | WARNING |
| 0 | 2 | 0 | 3 | 0x0002 | N3 |WARNING |
| 0 | 3 | 0 | 0 | 0x0022 | N3,N5 | WARNING|
| 0 | 3 | 0 | 1 | 0x0062 | N3,N5,N6 | WARNING |
| 0 | 3 | 0 | 2 | 0x0002 | N3 | WARNING |
| 0 | 3 | 0 | 3 | 0x0042 | N3,N6 | WARNING|
| 1 | 0 | 0 | 0 | 0x0042 | N3,N6 | WARNING|
| 1 | 0 | 0 | 1 | 0x0022 | N3,N5 | WARNING|
| 1 | 0 | 0 | 2 | 0x0002 | N3 |WARNING |
| 1 | 0 | 0 | 3 | 0x0022 | N3,N5 | WARNING|
| 1 | 1 | 0 | 0 | 0x0002 | N3 |WARNING |
| 1 | 1 | 0 | 1 | 0x0002 | N3 |WARNING |
| 1 | 1 | 0 | 2 | 0x0002 | N3 |WARNING |
| 1 | 1 | 0 | 3 | 0x0002 | N3 |WARNING |
| 1 | 2 | 0 | 0 | 0x0002 | N3 |WARNING |
| 1 | 2 | 0 | 1 | 0x0002 | N3 | WARNING |
| 1 | 2 | 0 | 2 | 0x0002 | N3 |WARNING |
| 1 | 2 | 0 | 3 | 0x0002 | N3 |WARNING |
| 1 | 3 | 0 | 0 | 0x0002 | N3 |WARNING |
| 1 | 3 | 0 | 1 | 0x0042 | N3,N6 | WARNING |
| 1 | 3 | 0 | 2 | 0x0042 | N3,N6 | WARNING|
| 1 | 3 | 0 | 3 | 0x0042 | N3,N6 | WARNING|
Total Number of test results: 32
Number of failures: 0
Number of Passed with warnings: 32
No. Passed without warnings: 0
[Mon] - Performing the FORMAT Command withthe following parameters:
MemoryWearCycleCapability = 0
CurrentPE_CycleCount = 0
LifeInSeconds = 157680000
LogicalCapacity = 500118192
SectorSize = 512
SectorAlignmentOffset = 0
ExpectedMemoryID = 34953(0x8889)
ExpectedNumDies = 0
SerialOutputControl = 0
Time[8] =0x0000000000000000
MiscFlag_Erase_R_Block = 0
MiscFlag_PanicHandlingEnabled = 0
MiscFlag_PanicOnSATA_Error = 0
MiscFlag_WriteThrottlingTestMode = 0
MiscFlag_DisableUserBandECCX = 1
L_PageSize = 0
E_PageSize = 0
ErrorCorrectionPower = 0
ConfigDeviceReadDisturbCount = 0
ConfigDeviceReadDisturbCountLow = 0
ExtraOptions_0_1 = 0
[Mon] - FORMAT command completed...
[Mon] - Waiting (2 sec) for the drive tosettle...
[Mon] - Setting up the stamp informationthrough CDU command...
[Mon] - Downloading the flashware to thedrive... feature 3
[Mon] - FATAL_ERROR: Could not downloadflashware to the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
ATA COMMAND : 0x0092 (146)
ATA FEATURE : 0x0003 (3)
Device Status: 0x0001 (1)
Driver Status: 0x0000 (0)
Host Status: 0x0008 (8)
Sense Data:
0 - No Sense: 114 (0x72) OK
1- Recovered Error: 11 (0x0B) FAIL
2- Not Ready: 0 (0x00) OK
3- Medium Error: 0 (0x00) OK
4- Hardware Error: 0 (0x00) OK
5- Illegal Request: 0 (0x00) OK
6- Unit Attention: 0 (0x00) OK
7- Data Protect: 14 (0x0E) OK
8- Blank Check: 9 (0x09) OK
9- Vendor Specific: 12 (0x0C) OK
10- Copy Aborted: 0 (0x00) OK
11- Aborted Command: 4 (0x04) FAIL
12 -Equal Comparison: 0 (0x00) NA
13- Volume Overflow: 128 (0x80) NA
14- Miscompare: 0 (0x00) OK
15- Reserved: 0 (0x00) NA
System Trace:
[ 667.778757] 72 01 04 1d 0000 00 0e 09 0c 00 00 00 00 00 00
[ 667.778766] 00 4f 00 c2 0050
[ 667.778772] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 667.799112] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 667.799120] Descriptor sense data with sense descriptors (in hex):
[ 667.799122] 72 01 04 1d 0000 00 0e 09 0c 00 00 00 00 00 01
[ 667.799132] 00 00 00 00 e050
[ 667.799137] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 668.856512] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 668.856519] Descriptor sense data with sense descriptors (in hex):
[ 668.856522] 72 01 04 1d 0000 00 0e 09 0c 00 00 00 00 00 01
[ 668.856531] 00 00 00 00 e050
[ 668.856536] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 669.893996] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 669.894003] Descriptor sense data with sense descriptors (in hex):
[ 669.894006] 72 01 04 1d 0000 00 0e 09 0c 00 00 00 00 00 01
[ 669.894016] 00 00 00 00 e050
[ 669.894021] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 671.041107] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 671.041114] Descriptor sense data with sense descriptors (in hex):
[ 671.041117] 72 01 04 1d 00 00 00 0e 09 0c 00 00 00 0000 01
[ 671.041126] 00 00 00 00 e050
[ 671.041131] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 673.895887] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 673.895894] Descriptor sense data with sense descriptors (in hex):
[ 673.895897] 72 01 04 1d 0000 00 0e 09 0c 00 00 00 00 00 01
[ 673.895907] 00 00 00 00 e050
[ 673.895912] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 740.214791] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 740.214798] Descriptor sense data with sense descriptors (in hex):
[ 740.214801] 72 01 04 1d 0000 00 0e 09 0c 00 00 00 00 00 01
[ 740.214811] 00 00 00 00 e050
[ 740.214816] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 741.282085] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 741.282099] Descriptor sense data with sense descriptors (in hex):
[ 741.282102] 72 01 04 1d 0000 00 0e 09 0c 00 00 00 00 00 01
[ 741.282111] 00 00 00 00 e050
[ 741.282116] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[ 742.331013] sd 8:0:0:0: [sg3] Sense Key : Recovered Error [current][descriptor]
[ 742.331021] Descriptor sense data with sense descriptors (in hex):
[ 742.331023] 72 01 04 1d 00 00 00 0e 09 0c 00 00 00 00 0006
[ 742.331033] 00 00 00 00 e050
[ 742.331038] sd 8:0:0:0: [sg3] ASC=0x4 ASCQ=0x1d
[Mon] - End of Genesis manufacturing log.
[Mon] - Exiting...
</Log_Body>
<Overall_Summary>
<Start_Time> Mon, 01/06/2020 @ 12:53:23 </Start_Time>
<End_Time> Mon, 01/06/2020 @ 12:55:01 </End_Time>
<Overall_Result> FAIL</Overall_Result>
<Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)</Exit_Code>
</Overall_Summary>
<Environment_Settings>
argv[2]: 8:0:0:0
argv[5]: 12345
argv[6]: www_123
</Input_Parameters>
<Log_File> SF_Genesis_Main_Log__Mon_01.06.2020_12.53.23.log</Log_File>
<Hostname> SandForce </Hostname>
<Host_IP_Address> 127.0.0.1 </Host_IP_Address>
<Port_Number> 3 </Port_Number>
<Device_Name> /dev/sg3 </Device_Name>
<SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit</SF_Genesis_Version>
<SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit</SF_Core_Library_Version>
<SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 1823:56:17 UTC 2010 i686 </SF_OS_Information>
</Environment_Settings>
[Mon]- Overall Result for Device: /dev/sg3 ****** FAIL ******
