查看: 1607|回复: 4
[SandForce] 求助大神帮忙看看这个OWC的SSD还有救没?(已开卡成功)
发表于 2020-3-8 22:16:49 | 显示全部楼层 |阅读模式
2281的主控,240G,NAND上印着10-2091-03-to-xap  tufg1316131600404,不知道是哪个厂家的,估计是丢固件了,想重新开卡,NAND可以慢慢试验,但无奈不知道哪里才是需要短路的地方,求大神指点一下。
更新:
原来这个SSD什么都不用短接,一开始用22261开,出来NAND好多FAIL,用风枪吹一下主控,焊锡溶后镊子轻轻碰一下,等后冷却再开,NAND检测就全PASS了,但又出来bad block list full的错误,此时发现能读取到NAND ID了,查了一下型号对应的应该是29081,重新用29081开一次,就成功了,撒花~~第一次修SSD就成功了,开心~~~
参与人数 1家元 +20 收起 理由
家睦 + 20
发表于 2020-3-9 00:46:51 | 显示全部楼层
这个像是苹果盘
 楼主| 发表于 2020-3-9 00:57:36 | 显示全部楼层
是的。实在不知道怎么短接,直接接上电脑用22261开卡,结果出来下面的LOG,这是颗粒挂了?还是应为选不对的原因?
  1. <?xml version = "1.0"?>
  2. <Genesis_Log>
  3.     <Log_Body>
  4. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  5. Overall Summary:
  6. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  7.                 Start Time: Mon, 03/09/2020 [url=home.php?mod=space&uid=3057940]@[/url] 08:31:22
  8.                   End Time: Mon, 03/09/2020 @ 08:32:03
  9.              OverallResult: FAIL
  10.                   ExitCode: (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR)
  11. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  12. Environment Settings:
  13. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  14.           Input Parameters:
  15.                   argv[1]: -PROCESS_SSD
  16.                   argv[2]: 0:0:0:0
  17.                   argv[3]: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
  18.                   argv[4]: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22261.123456.driveconfig
  19.                   argv[5]: 12345
  20.                   argv[6]: www_123
  21.                   argv[7]: log=/me.log
  22.                   Log File: SF_Genesis_Main_Log__Mon_03.09.2020_08.31.22.log
  23.                   Hostname: localhost.localdomain
  24.            Host IP Address: 127.0.0.1
  25.                Port Number: 0
  26.                 DeviceName: /dev/sg0
  27.         SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
  28.    SF_Core Library Version: v1.7.1.20130612-fc14-32bit
  29.          SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
  30. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  31. Post Processing Device Information:
  32. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  33.                    WWN OUI: UNKNOWN
  34.               WWN UniqueID: UNKNOWN
  35.                 Serial No.: UNKNOWN
  36.                  Model No.: UNKNOWN
  37.          Firmware Revision: UNKNOWN
  38.               ROM Revision: UNKNOWN
  39.             NAND Page Size: UNKNOWN
  40.      Number Of Chip Enable: UNKNOWN
  41.            Logical Sectors: UNKNOWN
  42.                    NAND ID: UNKNOWN
  43.         Flash Manufacturer: UNKNOWN
  44.               Flash Device: UNKNOWN
  45. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  46. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  47. SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
  48. SF_Core Library: v1.7.1.20130612-fc14-32bit
  49. Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
  50. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  51. [Mon 03/09/2020 08:31:22] - SF_Genesis has been invoked with the following parameters:
  52.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  53.                       argv[1]: -PROCESS_SSD
  54.                       argv[2]: 0:0:0:0
  55.                       argv[3]: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
  56.                       argv[4]: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22261.123456.driveconfig
  57.                       argv[5]: 12345
  58.                       argv[6]: www_123
  59.                       argv[7]: log=/me.log
  60.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  61. [Mon 03/09/2020 08:31:22] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
  62. [Mon 03/09/2020 08:31:43] - Issuing a discovery command for device: '0:0:0:0'
  63. [Mon 03/09/2020 08:31:48] - Discovery command completed...
  64. [Mon 03/09/2020 08:31:48] - Waiting 5 seconds for the system to settle...
  65. [Mon 03/09/2020 08:31:53] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
  66. [Mon 03/09/2020 08:31:53] - Proceeding to process SSD device with the following parameters:
  67.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  68.               DeviceName = /dev/sg0
  69.     MFP Package Filename = /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
  70.       Configuration File = /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22261.123456.driveconfig
  71.               Serial No. = 12345
  72.          World Wide Name = www_123
  73.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  74. [Mon 03/09/2020 08:31:53] - Successfully received the IDENTIFY data from the drive...
  75. [Mon 03/09/2020 08:31:53] - Validating Manufacturing Firmware Package: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
  76. [Mon 03/09/2020 08:31:53] - Successfully opened the package: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
  77. [Mon 03/09/2020 08:31:53] - file  /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22261.123456.driveconfig Loaded successfully
  78. [Mon 03/09/2020 08:31:53] - Warning:  Unable to query diagnostics information to perform power management settings check
  79. [Mon 03/09/2020 08:31:53] - B01 Power Management configuration request detected
  80. [Mon 03/09/2020 08:31:53] - Successfully extracted *.DriveConfig file: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22261.123456.driveconfig
  81. [Mon 03/09/2020 08:31:53] - Extracted Config_ID: 1 (22261) in DriveConfig file: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22261.123456.driveconfig
  82. [Mon 03/09/2020 08:31:53] - Extracted SerialOutputControl: 0
  83. [Mon 03/09/2020 08:31:53] - Searching for flashware image for configuration 22261
  84. [Mon 03/09/2020 08:31:53] - Manifest found for configuration 22261
  85. [Mon 03/09/2020 08:31:53] - Flashware image extracted: 22261_fw_cl_mlc_Toshiba_64Gb_TH58TEG8D2HBA8C_2Q_4C_1D_PP_R00886_s512.vic
  86. [Mon 03/09/2020 08:31:53] - Searching for manufacturing image for configuration 22261
  87. [Mon 03/09/2020 08:31:53] - Manifest found for configuration 22261
  88. [Mon 03/09/2020 08:31:53] - Manufacturing image extracted: 22261_mf_mlc_Toshiba_64Gb_TH58TEG8D2HBA8C_2Q_4C_1D_PP_R00886_s512.vic
  89. [Mon 03/09/2020 08:31:53] - Proceeding in ROM mode, download feature 3...
  90. [Mon 03/09/2020 08:31:54] - Successfully downloaded MFB to the drive...
  91. [Mon 03/09/2020 08:31:54] - Waiting (5 sec) for the drive to settle...
  92. [Mon 03/09/2020 08:31:59] - Successfully received the IDENTIFY data from the drive...
  93. [Mon 03/09/2020 08:31:59] - Firmware revision reported to be: '582ABBM0'.  This indicates MFB download was successful.
  94. [Mon 03/09/2020 08:31:59] - Successfully enabled SMART capabilities...
  95. [Mon 03/09/2020 08:32:01] - Successfully issued a diagnostic unlock...
  96. [Mon 03/09/2020 08:32:02] - Performing the flash test of block 0 (0x0000)...
  97. [Mon 03/09/2020 08:32:03] - Flash Test Results:
  98. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  99. -----------------------------------------------------------------------------
  100. Flash Test Parameters:
  101. -----------------------------------------------------------------------------
  102.                Block Count: 0
  103.                 Page Count: 1
  104.                  Bus Count: 2
  105.         Chip Enabled Count: 4
  106.                  Die Count: 1
  107.                 Lane Count: 4
  108.                Plane Count: 2
  109. -----------------------------------------------------------------------------
  110. Results Notes:
  111. -----------------------
  112.    N1 - At least one page tested and passed with no bit errors.
  113.    N2 - No test data available.  Test may have aborted, or failed during the testing.
  114.    N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
  115.    N4 - At least  one erased page tested had bit error rate greater than half the correction power.
  116.    N5 - Walking zeros test failed.
  117.    N6 - Walking ones test failed.
  118.    N7 - Block contained factory bad block markings and testing was skipped.
  119.    N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
  120.    N9 - Block in plane 0 was marked as a factory bad block.
  121.   N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  122.   N11 - Block in plane 1 was marked as a factory bad block.
  123. -----------------------------------------------------------------------------
  124. +------+------+------+------+--------+--------------------------------------------+---------+
  125. | Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
  126. +------+------+------+------+--------+--------------------------------------------+---------+
  127. | 0    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  128. +------+------+------+------+--------+--------------------------------------------+---------+
  129. | 0    | 0    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  130. +------+------+------+------+--------+--------------------------------------------+---------+
  131. | 0    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  132. +------+------+------+------+--------+--------------------------------------------+---------+
  133. | 0    | 0    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  134. +------+------+------+------+--------+--------------------------------------------+---------+
  135. | 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  136. +------+------+------+------+--------+--------------------------------------------+---------+
  137. | 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
  138. +------+------+------+------+--------+--------------------------------------------+---------+
  139. | 0    | 1    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  140. +------+------+------+------+--------+--------------------------------------------+---------+
  141. | 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  142. +------+------+------+------+--------+--------------------------------------------+---------+
  143. | 0    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  144. +------+------+------+------+--------+--------------------------------------------+---------+
  145. | 0    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
  146. +------+------+------+------+--------+--------------------------------------------+---------+
  147. | 0    | 2    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  148. +------+------+------+------+--------+--------------------------------------------+---------+
  149. | 0    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  150. +------+------+------+------+--------+--------------------------------------------+---------+
  151. | 0    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  152. +------+------+------+------+--------+--------------------------------------------+---------+
  153. | 0    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
  154. +------+------+------+------+--------+--------------------------------------------+---------+
  155. | 0    | 3    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  156. +------+------+------+------+--------+--------------------------------------------+---------+
  157. | 0    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  158. +------+------+------+------+--------+--------------------------------------------+---------+
  159. | 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  160. +------+------+------+------+--------+--------------------------------------------+---------+
  161. | 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
  162. +------+------+------+------+--------+--------------------------------------------+---------+
  163. | 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
  164. +------+------+------+------+--------+--------------------------------------------+---------+
  165. | 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  166. +------+------+------+------+--------+--------------------------------------------+---------+
  167. | 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  168. +------+------+------+------+--------+--------------------------------------------+---------+
  169. | 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
  170. +------+------+------+------+--------+--------------------------------------------+---------+
  171. | 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
  172. +------+------+------+------+--------+--------------------------------------------+---------+
  173. | 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  174. +------+------+------+------+--------+--------------------------------------------+---------+
  175. | 1    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  176. +------+------+------+------+--------+--------------------------------------------+---------+
  177. | 1    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
  178. +------+------+------+------+--------+--------------------------------------------+---------+
  179. | 1    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
  180. +------+------+------+------+--------+--------------------------------------------+---------+
  181. | 1    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  182. +------+------+------+------+--------+--------------------------------------------+---------+
  183. | 1    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  184. +------+------+------+------+--------+--------------------------------------------+---------+
  185. | 1    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
  186. +------+------+------+------+--------+--------------------------------------------+---------+
  187. | 1    | 3    | 0    | 2    | 0x0001 | N1                                         |    PASS |
  188. +------+------+------+------+--------+--------------------------------------------+---------+
  189. | 1    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  190. +------+------+------+------+--------+--------------------------------------------+---------+
  191. -----------------------------------------------------------------------------
  192.   Total Number of test results: 32
  193.             Number of failures: 7
  194.          Number of Passed with warnings: 0
  195.       No. Passed without warnings: 25
  196. -----------------------------------------------------------------------------
  197. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  198. [Mon 03/09/2020 08:32:03] - End of Genesis manufacturing log.
  199. [Mon 03/09/2020 08:32:03] - Exiting...
  200.     </Log_Body>
  201.     <Overall_Summary>
  202.         <Start_Time> Mon, 03/09/2020 @ 08:31:22 </Start_Time>
  203.         <End_Time> Mon, 03/09/2020 @ 08:32:03 </End_Time>
  204.         <Overall_Result> FAIL </Overall_Result>
  205.         <Exit_Code> (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR) </Exit_Code>
  206.     </Overall_Summary>
  207.     <Environment_Settings>
  208.         <Input_Parameters>
  209.                   argv[1]: -PROCESS_SSD
  210.                   argv[2]: 0:0:0:0
  211.                   argv[3]: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
  212.                   argv[4]: /home/hyf/pkg/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22261.123456.driveconfig
  213.                   argv[5]: 12345
  214.                   argv[6]: www_123
  215.                   argv[7]: log=/me.log
  216.         </Input_Parameters>
  217.         <Log_File> SF_Genesis_Main_Log__Mon_03.09.2020_08.31.22.log </Log_File>
  218.         <Hostname> localhost.localdomain </Hostname>
  219.         <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
  220.         <Port_Number> 0 </Port_Number>
  221.         <Device_Name> /dev/sg0 </Device_Name>
  222.         <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
  223.         <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
  224.         <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
  225.     </Environment_Settings>
  226.     <Post_Processing_Device_Info>
  227.         <WWN_OUI> UNKNOWN </WWN_OUI>
  228.         <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
  229.         <Serial_Number> UNKNOWN </Serial_Number>
  230.         <Model_Number> UNKNOWN </Model_Number>
  231.         <Firmware_Revision> UNKNOWN </Firmware_Revision>
  232.         <ROM_Revision> UNKNOWN </ROM_Revision>
  233.         <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
  234.         <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
  235.         <Logical_Sectors> UNKNOWN </Logical_Sectors>
  236.         <NAND_ID> UNKNOWN </NAND_ID>
  237.         <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
  238.         <Flash_Device> UNKNOWN </Flash_Device>
  239.     </Post_Processing_Device_Info>
  240. </Genesis_Log>
  241. [Mon 03/09/2020 08:32:03] - Overall Result for Device: /dev/sg0 ****** FAIL ******
复制代码
发表于 2020-3-9 12:37:50 | 显示全部楼层
短接不就是屁股那2组洞么 这个是苹果垃圾桶的阵列盘 看你这个颗粒有FAIL了
 楼主| 发表于 2020-3-9 13:29:21 来自手机浏览器 | 显示全部楼层
527945545 发表于 2020-3-9 12:37
短接不就是屁股那2组洞么 这个是苹果垃圾桶的阵列盘 看你这个颗粒有FAIL了  ...
是苹果的,我看了又看,觉得颗粒FAIL的有点奇怪,不可能这么巧连着前面四颗都FAIL,就390度把主控吹了一会,现在不FAIL了,现在卡在bad block list full了,真折腾。
GMT+8, 2025-8-21 13:22 , Processed in 0.140400 second(s), 12 queries , Redis On.
