查看: 1711|回复: 5
[Other] SM2246XT+RTL9200=可以接受的OTG方案
发表于 2023-7-15 17:30:19 | 显示全部楼层 |阅读模式
v0.567a
Drive: 7(USB)
OS: 6.1 build 7601 Service Pack 1
Model: Teclast 128GB NS550-2280
Fw   : Q0927A
Size : 122104 MB [128.0 GB]
From smart : [SMI2246XT] [2017-09-27]
Controller : SM2246XT bufferless
Bank00: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank01: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank02: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank03: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank04: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank05: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank06: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Bank07: 0x45,0x3a,0x94,0x93,0x76,0xd1,0xa,0x0 - Sandisk 15nm MLC 16k 128Gb/CE 128Gb/die 2Plane/die
Channel: 4
CE     : 2
TotDie : 8
Plane  : 2
Die/Ce : 1
Ch map : 0x0F
CE map : 0x03
Inter. : 2
First Fblock  :    8
Total Fblock  : 2106
Total Hblock  : 1908
Fblock Per Ce : 2106
Fblock Per Die: 2106
Original Spare Block Count :   171
Vendor Marked Bad Block    :     0
Bad Block From Pretest     :    19
用的是RTL9200盒子和Teclast 128GB NS550-2280,总体来说可以接受其实,至于插线与否的问题其实完全可以略过,因为用多了直插型以后你会跟我一样选择带线款式的,相信我
此处 @yangg429
发表于 2023-7-15 18:20:38 | 显示全部楼层
大佬 你上面的写的啥 看不懂呀  全是代码
 楼主| 发表于 2023-7-15 19:06:30 | 显示全部楼层
最上面是主控和颗粒信息等,这是SM2246XT无缓方案,双颗粒各4CE,但是量产的时候是分成每个通道2CE也就是4通道去连接主控,初期量产屏蔽的坏快19个,初期量产保留的备用块171个
 楼主| 发表于 2023-7-15 19:07:15 | 显示全部楼层
重新编辑并添加了跑分测试,你看看
参与人数 1家元 +20 收起 理由
yangg429 + 20
发表于 2023-7-16 19:51:38 | 显示全部楼层
好像还可以啊
 楼主| 发表于 2023-7-16 21:29:54 | 显示全部楼层
成本还低,连SSD带盒子才不到50的成本,现在盒子和SSD都接近白送的价格了哈哈
GMT+8, 2025-7-19 17:09 , Processed in 0.171601 second(s), 12 queries , Redis On.
