查看: 1906|回复: 1
群晖断电不能启动了!一直重启!
发表于 2024-8-19 19:31:48 | 显示全部楼层 |阅读模式
BootROM 1.20
Booting from SPI flash
High speed PHY - Version: 2.1.2 (COM-PHY-V20)
Update PEX Device ID 0x78230
High speed PHY - Ended Successfully
                                   DDR3 Training Sequence - Ver 4.5.0
DDR3 Training Sequence - Ended Successfully
Status = MV_OK
BootROM: Image checksum verification PASSED
__   __                      _ _
|  \/  | __ _ _ ____   _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| |  | | (_| | |   \ V /  __/ | |
|_|  |_|\__,_|_|    \_/ \___|_|_|
         _   _     ____              _
        | | | |   | __ )  ___   ___ | |_
        | | | |___|  _ \ / _ \ / _ \| __|
        | |_| |___| |_) | (_) | (_) | |_
         \___/    |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2011.12-SYNO-d7bdf8d-2013-12-11 (Dec 11 2013 - 17:58:54) Marvell version: v2011.12 2013_Q1.2
Board: Synology AXP 78230 4-bay/2-bay
SoC:   MV78230 B0
       running 2 CPUs
       Custom configuration
CPU:   Marvell PJ4B (584) v7 (Rev 2) LE
       CPU 0
       CPU    @ 1333 [MHz]
       L2     @ 667 [MHz]
       TClock @ 250 [MHz]
       DDR    @ 667 [MHz]
       DDR 32Bit Width, FastPath Memory Access
       DDR ECC Disabled
DRAM:  1 GiB
Map:   Code:            0x3fefb000:0x3ff9f630
       BSS:             0x3ffef33c
       Stack:           0x3f9eaef8
       Heap:            0x3f9eb000:0x3fefb000
MMC:   MRVL_MMC: 0
SF: Detected M25P64 with page size 64 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
PEX 0.0(0): Detected No Link.
PEX 1.0(1): Root Complex Interface, Detected Link X1, GEN 2.0
PEX 1.1(2): Detected No Link.
PEX 1.2(3): Detected No Link.
FPU initialized to Run Fast Mode.
USB 0: Host Mode
USB 1: Host Mode
USB 2: Device Mode
Modules Detected:
Synology Model: DS414r1
Fan Status: Not Good
Fan 1: Good
Fan 2: Not Good
Net:   egiga0 [PRIME], egiga1
Press Ctrl+C to abort autoboot in 3 second
## Booting kernel from Legacy Image at f40d0000 ...
   Image Name:   Linux-3.2.101
   Created:      2023-03-23  16:28:20 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1843768 Bytes = 1.8 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at f43a0000 ...
   Image Name:   synology_armadaxp_ds414 42962
   Created:      2023-04-07  16:32:27 UTC
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    3644566 Bytes = 3.5 MiB
   Load Address: 08000000
   Entry Point:  08000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Linux version 3.2.101 (root@build6) (gcc version 8.5.0 (GCC) ) #42962 SMP Fri Mar 24 00:28:03 CST 2023
[    0.000000] CPU: Marvell PJ4Bv7 Processor [562f5842] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine: Marvell Armada XP Development Board
[    0.000000] Using UBoot passing parameters structure
[    0.000000] Reserving training memory: base=0x  (null) size=0x2800
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] SMP: init cpus
[    0.000000] PERCPU: Embedded 7 pages/cpu @80d25000 s5280 r8192 d15200 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
[    0.000000] Kernel command line: console=ttyS0,115200 ip=off initrd=0x8000040,8M root=/dev/md0 rw syno_hw_version=DS414r1 ihd_num=4 netif_num=2 flash_size=8 SataLedSpecial=1 HddHotplug=1
[    0.000000] Synology Hardware Version: DS414r1-j
[    0.000000] Internal HD num: 4
[    0.000000] Internal netif num: 2
[    0.000000] Special Sata LEDs.
[    0.000000] Support HDD Hotplug.
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 1025996k/1025996k available, 22580k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xc0800000 - 0xfa800000   ( 928 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x80470000   (4512 kB)
[    0.000000]       .init : 0x80470000 - 0x8049f4a0   ( 190 kB)
[    0.000000]       .data : 0x804a0000 - 0x804c4140   ( 145 kB)
[    0.000000]        .bss : 0x804c4164 - 0x8051e06c   ( 360 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:211
[    0.000000] Initializing ArmadaXP SOC Timer 0
[    0.000000] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 171798ms
[  146.995816] Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
[  147.085739] pid_max: default: 32768 minimum: 301
[  147.085867] Security Framework initialized
[  147.085892] AppArmor: AppArmor initialized
[  147.085949] Mount-cache hash table entries: 512
[  147.086408] CPU: Testing write buffer coherency: ok
[  147.086534] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[  147.086546] SMP: prepare CPUs (4 cores)
[  147.086725] Setting Clocks for secondary CPUs
[  147.087524] SMP: CPU 0 Waking up CPU 1
[  147.094209] CPU1: Booted secondary processor
[  147.125729] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[  147.125785] Brought up 2 CPUs
[  147.125798] SMP: Total of 2 processors activated (2664.03 BogoMIPS).
[  147.126423] devtmpfs: initialized
[  147.129940] NET: Registered protocol family 16
[  147.132270] L0 cache Enabled
[  147.132279] Speculative Prefetch Disabled
[  147.132300] Aurora L2 Cache Enabled
[  147.132480] Support IO coherency.
[  147.235501]
[  147.235506]   Marvell Armada-XP Synology AXP 78230 Board -  Soc: MV78230 B0 LE
[  147.235523]   Detected Tclk 250000000, SysClk 667000000, FabricClk 667000000, PClk 1333000000
[  147.235531]   LSP version: linux-3.2.y-2013_Q1.2p2
[  147.235536]
[  147.236794] Synology ArmadaXP 4-bay GPIO Init
[  147.237123] registered dev#0 asa ehci_marvell
[  147.237418] Marvell USB EHCI Host controller #0: bf8aca00
[  147.237529] registered dev#1 asa ehci_marvell
[  147.237819] Marvell USB EHCI Host controller #1: bf8ac800
[  147.237932] registered dev#2 asa mv_udc
[  147.238222] Marvell USB Gadget controller #2: bf8ac600
[  147.244417] bio: create slab <bio-0> at 0
[  147.245181] SCSI subsystem initialized
[  147.246389] Switching to clocksource axp_clocksource
[  147.246656] AppArmor: AppArmor Filesystem Enabled
[  147.248435] NET: Registered protocol family 2
[  147.252849] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[  147.253108] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[  147.254017] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[  147.254421] TCP: Hash tables configured (established 131072 bind 65536)
[  147.254429] TCP reno registered
[  147.254437] UDP hash table entries: 512 (order: 2, 16384 bytes)
[  147.254462] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[  147.254594] NET: Registered protocol family 1
[  147.254755] Trying to unpack rootfs image as initramfs...
[  149.030275] rootfs image is not initramfs (no cpio magic); looks like an initrd
[  149.044557] Freeing initrd memory: 8192K
[  149.044633] PCI-E: Cheking physical bus #0 (controller #0): Enabled - No Link
[  149.044798] PCI-E: Cheking physical bus #1 (controller #4): Enabled - Link UP
[  149.044958] PCI-E: Cheking physical bus #2 (controller #5): Enabled - No Link
[  149.045108] PCI-E: Cheking physical bus #3 (controller #6): Enabled - No Link
[  149.045852] PCI: bus0: Fast back to back transfers disabled
[  149.046061] pci 0000:00:00.0: BAR 0: assigned [mem 0xf2800000-0xf2807fff 64bit]
[  149.046077] pci 0000:00:00.0: BAR 0: set to [mem 0xf2800000-0xf2807fff 64bit] (PCI address [0xf2800000-0xf2807fff])
[  149.046550] cesadev_init(80478d90)
[  149.047109] Armada XP hwmon thermal sensor initialized.
[  149.047201] ArmadaXP Power Managament Suspend Operations Initialized
[  149.047209] Initializing Armada-XP CPU power management  (WFI)
[  149.047832] audit: initializing netlink socket (disabled)
[  149.047859] type=2000 audit(2.050:1): initialized
[  149.048342] VFS: Disk quotas dquot_6.5.2
[  149.048408] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[  149.048893] msgmni has been set to 2019
[  149.049860] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[  149.049870] io scheduler noop registered
[  149.049914] io scheduler cfq registered (default)
[  149.050130] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[  149.136627] serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 41) is a 16550A
[  149.707649] console [ttyS0] enabled
[  149.746599] serial8250.1: ttyS1 at MMIO 0xf1012100 (irq = 42) is a 16550A
[  149.792421] brd: module loaded
[  149.795488] Loading iSCSI transport class v2.0-870.
[  149.801309] sata_mv sata_mv.0: cannot get clkdev
[  149.806018] sata_mv sata_mv.0: slots 32 ports 2
[  149.811723] scsi0 : sata_mv
[  149.814897] scsi1 : sata_mv
[  149.817993] ata1: SATA max UDMA/133 irq 55
[  149.822103] ata2: SATA max UDMA/133 irq 55
[  153.166435] ata1: SATA link down (SStatus 0 SControl F300)
[  156.170307] Delay 5 seconds to wait for disk 2 ready.
[  162.236429] ata2: failed to resume link (SControl 4)
[  162.241416] ata2: SATA link down (SStatus 0 SControl 4)
[  162.247595] physmap platform flash device: 00800000 at f0000000
[  162.256275] SPI Serial flash detected @ 0xf0000000, 8192KB (128sec x 64KB)
[  162.263207] Searching for RedBoot partition table in SYNOMTD-0 at offset 0x7f0000
[  162.308951] 6 RedBoot partitions found on MTD device SYNOMTD-0
[  162.314802] SYNOMTD flash bank 0: Using RedBoot partition definition
[  162.321179] Creating 6 MTD partitions on "SYNOMTD-0":
[  162.326248] 0x000000000000-0x0000000d0000 : "RedBoot"
[  162.332165] 0x0000000d0000-0x0000003a0000 : "zImage"
[  162.337935] 0x0000003a0000-0x0000007d0000 : "rd.gz"
[  162.343597] 0x0000007d0000-0x0000007e0000 : "vendor"
[  162.348670] vender Mac0 address : 00:11:32:47:1e:77
[  162.353566] vender Mac1 address : 00:11:32:47:1e:78
[  162.358464] vender Mac2 doesn't set ucSum:0x00 Buf:0x00 Sum:0.
[  162.364314] vender Mac3 doesn't set ucSum:0x00 Buf:0x00 Sum:0.
[  162.370171] serial number='1530MEN132502'
[  162.374802] 0x0000007e0000-0x0000007f0000 : "RedBoot Config"
[  162.381470] 0x0000007f0000-0x000000800000 : "FIS directory"
[  162.387974] mv_eth_probe: port_mask=0xf, cpu_mask=0x3
[  162.393307]   o 4 Giga ports supported
[  162.397098]   o SKB recycle supported (Enabled)
[  162.401641]   o NETA acceleration mode 2
[  162.405573]   o BM supported for CPU: 4 BM pools
[  162.410210]   o RX Queue support: 1 Queues * 128 Descriptors
[  162.415886]   o TX Queue support: 1 Queues * 532 Descriptors
[  162.421564]   o GSO supported
[  162.424539]   o GRO supported
[  162.427519]   o Receive checksum offload supported
[  162.432323]   o Transmit checksum offload supported
[  162.437217]   o Driver ERROR statistics enabled
[  162.441758]
[  162.443431]   o Loading network interface(s)
[  162.447728]
[  162.449224]   o Port 0 is connected to Linux netdevice
[  162.454779]  giga p=0: mtu=1500, mac=bf835e44
[  162.463041]     o eth0, ifindex = 2, GbE port = 0
[  162.467609]     o eth0, phy chipid = 1410dd0, Support WOL = 32
[  162.473642]
[  162.475145]
[  162.476654]   o Port 1 is connected to Linux netdevice
[  162.482218]  giga p=1: mtu=1500, mac=bf835e44
[  162.490449]     o eth1, ifindex = 3, GbE port = 1
[  162.494993]     o eth1, phy chipid = 1410dd0, Support WOL = 32
[  162.501037]
[  162.502533]
[  162.502535]   o Warning: GbE port 2 is powered off
[  162.502539]
[  162.510331]
[  162.512052] i2c /dev entries driver
[  162.516084] Syno_HddMon: Initialization completed.
[  162.520910] md: raid1 personality registered for level 1
[  162.526477] cpuidle: using governor ladder
[  162.530918] cpuidle: using governor menu
[  162.534990] TCP cubic registered
[  162.538240] NET: Registered protocol family 17
[  162.542708] Registering the dns_resolver key type
[  162.547507] VFP support v0.3: implementor 56 architecture 2 part 20 variant 9 rev 6
[  162.555656] registered taskstats version 1
[  162.560010] md: Waiting for all devices to be available before autodetect
[  162.566826] md: If you don't use raid, use raid=noautodetect
[  162.573004] md: Autodetecting RAID arrays.
[  162.577135] md: Scanned 0 and added 0 devices.
[  162.581590] md: autorun ...
[  162.584391] md: ... autorun DONE.
[  162.587808] RAMDISK: lzma image found at block 0
[  164.490469] VFS: Mounted root (ext2 filesystem) on device 1:0.
START /linuxrc.syno
START /linuxrc.syno.impl
Insert basic USB modules...
:: Loading module usb-common ... [  OK  ]
:: Loading module usbcore[  164.726595] usbcore: registered new interface driver usbfs
[  164.735481] usbcore: registered new interface driver hub
[  164.752223] usbcore: registered new interface driver ethub
[  164.765339] usbcore: registered new device driver usb
... [  OK  ]
:: Loading module ehci-hcd[  164.800236] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[  164.806845] ehci_marvell ehci_marvell.0: Marvell Orion EHCI
[  164.812522] ehci_marvell ehci_marvell.0: new USB bus registered, assigned bus number 1
[  164.846444] ehci_marvell ehci_marvell.0: irq 45, io base 0xfbc50100
[  164.866445] ehci_marvell ehci_marvell.0: USB 2.0 started, EHCI 1.00
[  164.873515] hub 1-0:1.0: USB hub found
[  164.877300] hub 1-0:1.0: 1 port detected
[  164.883914] ehci_marvell ehci_marvell.1: Marvell Orion EHCI
[  164.889571] ehci_marvell ehci_marvell.1: new USB bus registered, assigned bus number 2
[  164.926472] ehci_marvell ehci_marvell.1: irq 46, io base 0xfbc51100
[  164.946446] ehci_marvell ehci_marvell.1: USB 2.0 started, EHCI 1.00
[  164.953547] hub 2-0:1.0: USB hub found
[  164.957382] hub 2-0:1.0: 1 port detected
... [  OK  ]
:: Loading module xhci-hcd ... [  OK  ]
[  165.071083] etxhci_hcd-161118 0000:00:00.0: Etron xHCI Host Controller
[  165.077740] etxhci_hcd-161118 0000:00:00.0: new USB bus registered, assigned bus number 3
[  165.095048] etxhci_hcd-161118 0000:00:00.0: Etron chip found.
[  165.102281] ethub 3-0:1.0: USB hub found
[  165.106235] ethub 3-0:1.0: 2 ports detected
[  165.113180] etxhci_hcd-161118 0000:00:00.0: Etron xHCI Host Controller
[  165.119776] etxhci_hcd-161118 0000:00:00.0: new USB bus registered, assigned bus number 4
[  165.133955] ethub 4-0:1.0: USB hub found
[  165.137931] ethub 4-0:1.0: 2 ports detected
Insert net driver(Mindspeed only)...
[  165.198160] ds414_synobios: module license 'Synology Inc.' taints kernel.
[  165.204980] Disabling lock debugging due to kernel taint
[  165.211997] synobios open /dev/ttyS1 success
[  165.216772] correction with 0x03
[  165.221913] 2000-1-1 1:1:25 UTC
[  165.225072] synobios: load, major number 201
[  165.229419] Brand: Synology
[  165.232222] Model: DS-414
[  165.234848] This is default settings: set group disks wakeup number to 1, spinup time deno 1
[  165.243352] synobios cpu_arch proc entry initialized
[  165.248341] synobios crypto_hw proc entry initialized
[  165.253410] synobios syno_platform proc entry initialized
Starting /usr/syno/bin/synocfgen...
/usr/syno/bin/synocfgen returns 0
[  165.276392] Module [ds414_synobios] is removed.
[  165.281144] synobios: unload
Exit on error [1] DISK NOT INSTALLED...
Sat Jan  1 01:01:25 UTC 2000
kill: can't kill pid 318: No such process
umount: /etc/mtab: No such file or directory
linuxrc.syno failed on 1
starting pid 726, tty '': '/etc/rc'
:: Starting /etc/rc
:: Mounting procfs ... [  OK  ]
:: Mounting tmpfs ... [  OK  ]
:: Mounting devtmpfs ... [  OK  ]
:: Mounting devpts ... [  OK  ]
:: Mounting sysfs ... [  OK  ]
:: Loading module fat ... [  OK  ]
:: Loading module vfat ... [  OK  ]
:: Loading module sunrpc[  166.078551] RPC: Registered named UNIX socket transport module.
[  166.084497] RPC: Registered udp transport module.
[  166.089251] RPC: Registered tcp transport module.
[  166.093970] RPC: Registered tcp NFSv4.1 backchannel transport module.
... [  OK  ]
:: Loading module auth_rpcgss ... [  OK  ]
:: Loading module lockd ... [  OK  ]
:: Loading module nfs ... [  OK  ]
:: Mounting usbfs ... [  OK  ]
:: Loading module synobios[  166.290603] synobios open /dev/ttyS1 success
[  166.295175] correction with 0x03
[  166.300348] 2000-1-1 1:1:26 UTC
[  166.303505] synobios: load, major number 201
[  166.307809] Brand: Synology
[  166.310610] Model: DS-414
[  166.313237] This is default settings: set group disks wakeup number to 1, spinup time deno 1
[  166.321726] synobios cpu_arch proc entry initialized
[  166.326712] synobios crypto_hw proc entry initialized
[  166.331781] synobios syno_platform proc entry initialized
... [  OK  ]
cat: can't open '/proc/sys/kernel/syno_skip_vender_mac_interfaces': No such file[  166.543830] eth0: mac address changed
or directory
cat: can't open '/proc/sys/kernel/syno_skip_vender_mac_interfaces': No such file or directory
[  166.569112] eth1: mac address changed
[  166.768992] pool #0: pkt_size=1536, buf_size=1632 - 2048 of 2048 buffers added
[  166.779703] pool #2: pkt_size=256, buf_size=352 - 3072 of 3072 buffers added
[  166.786849] eth0: started
udhcpc: started, v1.30.1
[  167.851413] pool #1: pkt_size=1536, buf_size=1632 - 2048 of 2048 buffers added
[  167.862100] pool #3: pkt_size=256, buf_size=352 - 3072 of 3072 buffers added
[  167.869223] eth1: link up
[  167.871875] eth1: started
eth0      Link encap:Ethernet  HWaddr 00:11:32:47:1E:77
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:532
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:8
eth1      Link encap:Ethernet  HWaddr 00:11:32:47:1E:78
          inet addr:192.168.50.10  Bcast:192.168.50.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1180 (1.1 KiB)  TX bytes:989 (989.0 B)
          Interrupt:10
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          collisions:0 txqueuelen:0
:: Starting syslogd ... [  OK  ]
/etc/rc: line 302: /usr/syno/bin/syno_pstore_collect: not found
:: Starting scemd
[  174.001117] Unable to handle kernel paging request at virtual address c07f809c
[  174.008365] pgd = b9c08000
[  174.011078] [c07f809c] *pgd=00000000
[  174.014678] Internal error: Oops: 15 [#1] SMP
[  174.019046] Modules linked in: ds414_synobios(P) nfs lockd auth_rpcgss sunrpc vfat fat etxhci_hcd xhci_hcd ehci_hcd usbcore usb_common [last unloaded: ds414_synobios]
[  174.034128] CPU: 0    Tainted: P           O  (3.2.101 #42962)
[  174.039986] PC is at syno_sata_mv_gpio_write+0x50/0x84
[  174.045141] LR is at kobject_put+0x34/0x60
[  174.049251] pc : [<80286aa8>]    lr : [<801fb250>]    psr: a0070013
[  174.049255] sp : b9c07c00  ip : b9c07bb0  fp : b9c07c14
[  174.060772] r10: 00000000  r9 : b9c06000  r8 : 00000005
[  174.066012] r7 : bf3be6c0  r6 : 7f16ec98  r5 : 00000000  r4 : 00000000
[  174.072558] r3 : c07f8000  r2 : 00000001  r1 : bb880000  r0 : bb702c00
[  174.079105] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  174.086261] Control: 10c53c7d  Table: 39c0806a  DAC: 00000015
[  174.092023] Process scemd (pid: 1543, stack limit = 0xb9c062f0)
[  174.097959] Stack: (0xb9c07c00 to 0xb9c08000)
[  174.102332] 7c00: 7f16ec88 00000000 b9c07c24 b9c07c18 7f16b5a4 80286a64 b9c07c34 b9c07c28
[  174.110537] 7c20: 7f16bbac 7f16b580 b9c07efc b9c07c38 7f1679e0 7f16bba8 00000000 00000001
[  174.118742] 7c40: 00000000 804c3660 00000000 804aa7a0 bf3e0338 00000000 00000001 00000000
[  174.126947] 7c60: 00000001 0d696914 b9c07d1c b9c07c78 800a6ad0 800a6474 00000002 00000041
[  174.135151] 7c80: 804c3660 00000002 b9c07cbc 00000000 b9c07d2c b9c07ca0 800a6578 800a45c4
[  174.143356] 7ca0: 00000041 0003ba7e 8041c7a4 804ec154 00000000 ffffffff 00000000 00000000
[  174.151561] 7cc0: 804c3f64 00000020 00000002 00000002 b9c07d7c b9c07ce0 000200da b9c06000
[  174.159765] 7ce0: 0000001c 804aa980 00000000 80d2880c 00000000 00000001 800ef6bc 804c3660
[  174.167969] 7d00: 00000000 804aa7a0 bf38d128 00000000 00000000 00000002 000200da 804c3f60
[  174.176174] 7d20: b9c07dd4 b9c07d30 b9c07d4c b9c07d38 800d8df4 801fb070 bf990f60 0c900000
[  174.184379] 7d40: b9c07d5c b9c07d50 800d8e30 800d8dac b9c07d9c b9c07d60 80241978 800851a4
[  174.192583] 7d60: b9c06000 804aa980 000000c9 800d8978 801cba2c 804ecc88 00000000 bf43ab58
[  174.200788] 7d80: 800d909c bf37b4a0 bf3be6c0 bf43ab58 b9c07dcc b9c07da0 800d9194 7f164d64
[  174.208993] 7da0: b9c07dcc 00000000 00000000 bf3be6c0 bf43ab58 800d909c 00000000 bf3be6c0
[  174.217198] 7dc0: b9c07df4 b9c07dd0 800d1320 800a9f88 bf3be6c0 b9c07ecc b9c07e0c b9c07de8
[  174.225402] 7de0: b9c07e0c b9c07df0 800f86a0 800f6adc b9c07ecc 00020002 00000026 00000000
[  174.233607] 7e00: b9c07e1c b9c07e10 800f8788 800f865c b9c07e5c b9c07e20 b9c07e4c b9c07e28
[  174.241812] 7e20: b9c07e4c b9c07e30 800f86a0 800f6adc b9c07ecc bf3be6c0 b9c07f60 b9c06000
[  174.250017] 7e40: b9c07e5c b9c07e50 800f8788 800f865c b9c07ebc b9c07e60 800e845c 800e8338
[  174.258222] 7e60: b9c07e84 b9c08000 0003a000 bad39900 bf3d6968 b9c08000 00000000 00000000
[  174.266426] 7e80: b9c07ec4 00000000 bb8a8a00 bf43ab58 802008b4 00000001 b9c07f60 ffffff9c
[  174.274631] 7ea0: bb814000 fffff000 b9c06000 00000000 b9c07f54 b9c07ec0 800e895c 800e8374
[  174.282836] 7ec0: 00000001 80073e74 00000800 bb8a8a00 bf43ab58 ccabff6f 00000008 bf37b4a0
[  174.291040] 7ee0: 7ecf5a1c 00000000 bf3be6c0 00000005 b9c07f74 b9c07f00 800eb1dc 7f165dd8
[  174.299245] 7f00: 804aa9d0 00000001 00000005 00000001 bf3be6c8 00000020 bf8868c0 00000000
[  174.307449] 7f20: 00000000 00000000 b9c07f54 b9c07f38 800d19a0 8037c664 00000005 bf3be6c0
[  174.315654] 7f40: bf3be6c8 bb814000 b9c07f94 b9c07f58 00000000 c0104b0a 7ecf5a1c bf3be6c0
[  174.323859] 7f60: 00000005 b9c06000 b9c07fa4 b9c07f78 800eba8c 800eb098 00104b70 00000000
[  174.332064] 7f80: 8000e388 00000005 7ecf5a1c 00104b70 00000036 8000e388 00000000 b9c07fa8
[  174.340268] 7fa0: 8000e1e0 800eba44 00000005 7ecf5a1c 00000005 c0104b0a 7ecf5a1c 00000000
[  174.348473] 7fc0: 00000005 7ecf5a1c 00104b70 00000036 00000004 00000000 000d906f 000e62ff
[  174.356677] 7fe0: 000fb1ac 7ecf59bc 0003a754 2ad11a1c 20070010 00000005 3fffe821 3fffec21
[  174.364876] Backtrace:
[  174.367357] [<80286a58>] (syno_sata_mv_gpio_write+0x0/0x84) from [<7f16b5a4>] (SetDiskLedStatusBySataMvGPIO+0x30/0x40 [ds414_synobios])
[  174.379564]  r5:00000000 r4:7f16ec88
[  174.383186] [<7f16b574>] (SetDiskLedStatusBySataMvGPIO+0x0/0x40 [ds414_synobios]) from [<7f16bbac>] (SetDiskLedStatus+0x10/0x14 [ds414_synobios])
[  174.396275] [<7f16bb9c>] (SetDiskLedStatus+0x0/0x14 [ds414_synobios]) from [<7f1679e0>] (synobios_ioctl+0x1c14/0x2650 [ds414_synobios])
[  174.408494] [<7f165dcc>] (synobios_ioctl+0x0/0x2650 [ds414_synobios]) from [<800eb1dc>] (do_vfs_ioctl+0x150/0x9ac)
[  174.418870]  r8:00000005 r7:bf3be6c0 r6:00000000 r5:7ecf5a1c r4:bf37b4a0
[  174.425658] [<800eb08c>] (do_vfs_ioctl+0x0/0x9ac) from [<800eba8c>] (sys_ioctl+0x54/0x8c)
[  174.433858]  r9:b9c06000 r8:00000005 r7:bf3be6c0 r6:7ecf5a1c r5:c0104b0a
[  174.440454] r4:00000000
[  174.443112] [<800eba38>] (sys_ioctl+0x0/0x8c) from [<8000e1e0>] (ret_fast_syscall+0x0/0x30)
[  174.451486]  r8:8000e388 r7:00000036 r6:00104b70 r5:7ecf5a1c r4:00000005
[  174.458273] Code: 0a00000d e5911040 e2833906 e5922084 (e593c09c)
[  174.464425] ---[ end trace 34ccc23bd93b183d ]---
Segmentation fault
:: Failed to start scemd. Reboot and get into steel plan or network install mode. ... [  !!  ]
:: Starting services in background
Starting JuniorExpansionPack
Starting findhostd in flash_rd...
Starting services in flash_rd...
Running /usr/syno/etc/rc.d/J01httpd.sh...
Starting httpd:80 in flash_rd...
Starting httpd:5000 in flash_rd...
Running /usr/syno/etc/rc.d/J03ssdpd.sh...
/usr/bin/minissdpd -i eth0 -i eth1
eth0 not RUNNING
(15): upnp:rootdevice
(51): uuid:upnp_SynologyNAS-001132471e78::upnp:rootdevice
(56): Synology/synology_armadaxp_ds414/7.1-42962/192.168.50.10
(46): http://192.168.50.10:5000/description-eth1.xml
Connected.
done.
/usr/syno/bin/reg_ssdp_service 192.168.50.10 001132471e78 7.1-42962 synology_armadaxp_ds414 eth1
Running /usr/syno/etc/rc.d/J04synoagentregisterd.sh...
Starting synoagentregisterd...
Running /usr/syno/etc/rc.d/J30DisableNCQ.sh...
cat: can't open '/sys/block/sd*/device//model': No such file or directory
Running /usr/syno/etc/rc.d/J80ADTFanControl.sh...
Running /usr/syno/etc/rc.d/J98nbnsd.sh...
Starting nbnsd...
Running /usr/syno/etc/rc.d/J99avahi.sh...
Starting Avahi mDNS/DNS-SD Daemon
/usr/syno/sbin/avahi-daemon: error while loading shared libraries: libm.so.6: cannot open shared object file: No such file or directory
:: Loading module usb-storage[  174.930655] Initializing USB Mass Storage driver...
[  174.935884] usbcore: registered new interface driver usb-storage
[  174.941949] USB Mass Storage support registered.
... [  OK  ]
Excution Error
============ Date ============
Sat Jan  1 01:01:34 UTC 2000
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to[  176.007018] Module [usb_storage] is removed.
all processes
[  176.012299] usbcore: deregistering interface driver usb-storage
rmmod usb_storage
Requesting system reboot
[  181.036475] Shutting Down Marvell Ethernet Driver
[  181.041237] Restarting system.
 楼主| 发表于 2024-8-19 19:32:20 | 显示全部楼层
感觉是引导文件丢失了,不知道怎么才能搞回去
GMT+8, 2025-7-21 22:29 , Processed in 0.218400 second(s), 12 queries , Redis On.
