查看: 1722|回复: 10
[综合] 请教一下 ASM1153 带E 和不带E的两款芯片有啥区别
发表于 2024-12-7 13:01:17 | 显示全部楼层 |阅读模式
发表于 2024-12-7 13:28:28 | 显示全部楼层
看DATASHEET呗...
二○二四年十二月七日
发表于 2024-12-7 13:47:47 | 显示全部楼层
将芯片的数据手册详细读一遍。
发表于 2024-12-7 14:18:52 | 显示全部楼层
ASM1153E
5G SATA Device
ASM1153E is the ASMedia third generation single chip solution, bridging the USB3.2 Gen1 to Serial SATA host interface with highly integrated SuperSpeed USB3.2 Gen1, High Speed USDB2.0 and SATA1.5/3.0/6.0 Gbps ASMedia self -designed PHYs. Along with excellent compatibility with USB3.2 host and SATA device, ASM1153E uses advanced process technology to optimize the chip power consumption. Furthermore, it is also pit-to-pin backward compatible with existing ASM1053.
ASM1153
5G SATA Device
ASM1153 is the ASMedia third generation single chip solution, bridging the USB3.2 Gen1 to Serial SATA host interface with highly integrated SuperSpeed USB3.0, High Speed USB2.0 and SATA1.5/3.0 Gbps ASMedia self -designed PHYs. Along with excellent compatibility with USB3.0 host and SATA device, ASM1053 uses advanced process technology to optimize the chip power consumption. Furthermore, it is also pit-to -pin backward compatible with existing ASM1053.
发表于 2024-12-7 14:23:46 | 显示全部楼层
看到红字以为不一样?
一个叫大毛一个叫一毛
 楼主| 发表于 2024-12-7 15:36:25 | 显示全部楼层
非常感谢
发表于 2025-4-9 14:44:26 | 显示全部楼层
没注意一个是3GB一个是6GB嘛?
发表于 2025-4-14 15:16:46 | 显示全部楼层
确实有差别 3Gb和6Gb之差
发表于 2025-4-15 01:56:13 | 显示全部楼层
另外1153不支持TRIM  1153E支持TRIM,这对固态硬盘很重要。
发表于 2025-4-15 12:19:50 | 显示全部楼层
真详细
发表于 2025-4-16 10:31:04 | 显示全部楼层
3Gb和6Gb之差
GMT+8, 2025-7-18 15:16 , Processed in 0.093600 second(s), 9 queries , Redis On.
