贝壳RK3328扩容2G内存,颗粒是同型号颗粒,把背面的颗粒换到正面也正常启动。只要四个一起焊上,就出错,莫非固件不兼容?刷的小钢炮
背面空缺的ZQ电阻已补上。
DDR version 1.06 20170424
In
DDR3
786MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
ddrconfig:6
OUT
Boot1 Release Time: 2017-05-18, version: 2.43
ChipType = 0x11, 125
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 2
StorageInit ok = 20770
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa4e00
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):f947c7e
NOTICE: BL31: Built : 20:41:40, Nov 26 2018
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using rkfiq sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-armbian (Feb 08 2019 - 11:49:32 +0100)
Model: Pine64 Rock64
DRAM: 2 GiB
MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1
SF: unrecognized JEDEC id bytes: ff, ff, ff
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
misc_init_r
cpuid=55524b50303930323200000000161e2d
serial=a47710bd9505492
Net: eth0: ethernet@ff540000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
3006 bytes read in 13 ms (225.6 KiB/s)
## Executing script at 00500000
hacklog NanoDM Boot script loaded from mmc 0
166 bytes read in 13 ms (11.7 KiB/s)
3761535 bytes read in 107 ms (33.5 MiB/s)
18731016 bytes read in 2712 ms (6.6 MiB/s)
67864 bytes read in 13 ms (5 MiB/s)
** File not found /boot/dtb/rockchip/overlay/rockchip-fixup.scr **
## Loading init Ramdisk from Legacy Image at 04000000 ...
Image Name:
Image Type: AArch64 Linux RAMDisk Image (uncompressed)
Data Size: 3761471 Bytes = 3.6 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to 7db6a000, end 7df0053f ... OK
reserving fdt memory region: addr=1f00000 size=76000
Loading Device Tree to 000000007daf1000, end 000000007db69fff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.167 (hacklog@8700k) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05
revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP Mon May 6
01:01:07 CST 2019
[ entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] software IO TLB [mem 0x7fdb4000-0x7fdf4000] (0MB) mapped at [ffffffc07fdb4000-
ffffffc07fdf3fff]
[ 0.000000] Memory: 2034832K/2095104K available (11454K kernel code, 1524K rwdata, 4068K rodata,
1216K init, 785K bss, 60272K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff8008fb0000 - 0xffffff80090e0000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bb0000 ( 11456 KB)
[ 0.000000] .rodata : 0xffffff8008bb0000 - 0xffffff8008fb0000 ( 4096 KB)
[ 0.000000] .data : 0xffffff80090e0000 - 0xffffff800925d008 ( 1525 KB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual)
[ 0.000000] fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rockchip_mmc_get_phase: invalid clk rate
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0,
max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000995] Console: colour dummy device 80x25
[ 0.001021] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00
BogoMIPS (lpj=96000)
[ 0.001037] pid_max: default: 32768 minimum: 301
[ 0.001173] Security Framework initialized
[ 0.001185] Yama: becoming mindful.
[ 0.001209] AppArmor: AppArmor disabled by boot time parameter
[ 0.001274] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.001290] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.002141] Initializing cgroup subsys io
[ 0.002163] Initializing cgroup subsys memory
[ 0.002201] Initializing cgroup subsys devices
[ 0.002218] Initializing cgroup subsys freezer
[ 0.002235] Initializing cgroup subsys net_cls
[ 0.002255] Initializing cgroup subsys perf_event
[ 0.002273] Initializing cgroup subsys net_prio
[ 0.002293] Initializing cgroup subsys hugetlb
[ 0.002307] Initializing cgroup subsys pids
[ 0.002361] ftrace: allocating 43975 entries in 172 pages
[ 0.129537] sched-energy: CPU device node has no sched-energy-costs
[ 0.129557] Invalid sched_group_energy for CPU0
[ 0.129566] CPU0: update cpu_capacity 1024
[ 0.129622] ASID allocator initialised with 32768 entries
[ 0.132356] Detected VIPT I-cache on CPU1
[ 0.132413] Invalid sched_group_energy for CPU1
[ 0.132419] CPU1: update cpu_capacity 1024
[ 0.132425] CPU1: Booted secondary processor [410fd034]
[ 0.133126] Detected VIPT I-cache on CPU2
[ 0.133171] Invalid sched_group_energy for CPU2
[ 0.133176] CPU2: update cpu_capacity 1024
[ 0.133181] CPU2: Booted secondary processor [410fd034]
[ 0.133863] Detected VIPT I-cache on CPU3
[ 0.133909] Invalid sched_group_energy for CPU3
[ 0.133914] CPU3: update cpu_capacity 1024
[ 0.133919] CPU3: Booted secondary processor [410fd034]
[ 0.134017] Brought up 4 CPUs
[ 0.134078] SMP: Total of 4 processors activated.
[ 0.134093] CPU features: kernel page table isolation forced OFF by command line option
[ 0.134105] CPU features: detected feature: 32-bit EL0 Support
[ 0.134119] CPU: All CPU(s) started at EL2
[ 0.134157] alternatives: patching kernel code
[ 0.134402] Invalid sched_group_energy for CPU3
[ 0.134414] Invalid sched_group_energy for Cluster3
[ 0.134425] Invalid sched_group_energy for CPU2
[ 0.134434] Invalid sched_group_energy for Cluster2
[ 0.134443] Invalid sched_group_energy for CPU1
[ 0.134454] Invalid sched_group_energy for Cluster1
[ 0.134463] Invalid sched_group_energy for CPU0
[ 0.134472] Invalid sched_group_energy for Cluster0
[ 0.135220] devtmpfs: initialized
[ 0.157063] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns:
7645041785100000 ns
[ 0.157097] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.157697] xor: measuring software checksum speed
[ 0.197453] 8regs : 1080.000 MB/sec
[ 0.237539] 8regs_prefetch: 968.000 MB/sec
[ 0.277625] 32regs : 1458.000 MB/sec
[ 0.317712] 32regs_prefetch: 1224.000 MB/sec
[ 0.317724] xor: using function: 32regs (1458.000 MB/sec)
[ 0.317757] pinctrl core: initialized pinctrl subsystem
[ 0.318118] regulator-dummy: no parameters
[ 0.319072] NET: Registered protocol family 16
[ 0.329793] cpuidle: using governor ladder
[ 0.336730] cpuidle: using governor menu
[ 0.336767] Registered FIQ tty driver
[ 0.337602] vdso: 2 pages (1 code @ ffffff8008bb6000, 1 data @ ffffff80090e4000)
[ 0.337637] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.337794] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.351311] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[ 0.351457] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[ 0.351586] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[ 0.351725] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[ 0.361507] genirq: Setting trigger mode 8 for irq 161 failed (gic_set_type+0x0/0x64)
[ 0.429369] console [ttyFIQ0] enabled
[ 0.430084] Registered fiq debugger ttyFIQ0
[ 0.518412] raid6: int64x1 gen() 201 MB/s
[ 0.586296] raid6: int64x1 xor() 172 MB/s
[ 0.654540] raid6: int64x2 gen() 324 MB/s
[ 0.722517] raid6: int64x2 xor() 276 MB/s
[ 0.790706] raid6: int64x4 gen() 478 MB/s
[ 0.858797] raid6: int64x4 xor() 325 MB/s
[ 0.926907] raid6: int64x8 gen() 386 MB/s
[ 0.995063] raid6: int64x8 xor() 306 MB/s
[ 1.063269] raid6: neonx1 gen() 361 MB/s
[ 1.131304] raid6: neonx1 xor() 368 MB/s
[ 1.199458] raid6: neonx2 gen() 548 MB/s
[ 1.267562] raid6: neonx2 xor() 467 MB/s
[ 1.335667] raid6: neonx4 gen() 744 MB/s
[ 1.403813] raid6: neonx4 xor() 575 MB/s
[ 1.471922] raid6: neonx8 gen() 763 MB/s
[ 1.540018] raid6: neonx8 xor() 570 MB/s
[ 1.540400] raid6: using algorithm neonx8 gen() 763 MB/s
[ 1.540870] raid6: .... xor() 570 MB/s, rmw enabled
[ 1.541317] raid6: using intx1 recovery algorithm
[ 1.542188] mpp venc_srv: mpp_probe enter
[ 1.542582] mpp venc_srv: init success
[ 1.543708] of_get_named_gpiod_flags: can't parse 'gpio' property of node
'/regulators/regulator@0[0]'
[ 1.544547] vccio_1v8: 1800 mV
[ 1.545114] reg-fixed-voltage regulators:regulator@0: vccio_1v8 supplying 1800000uV
[ 1.545904] of_get_named_gpiod_flags: can't parse 'gpio' property of node
'/regulators/regulator@1[0]'
[ 1.546747] vccio_3v3: 3300 mV
[ 1.547324] reg-fixed-voltage regulators:regulator@1: vccio_3v3 supplying 3300000uV
[ 1.548083] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/host-vbus-regulator
[0]'
[ 1.548894] vcc_host_vbus: 5000 mV
[ 1.549458] reg-fixed-voltage host-vbus-regulator: vcc_host_vbus supplying 5000000uV
[ 1.550233] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[ 1.551031] vcc_phy: no parameters
[ 1.551598] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[ 1.552827] iommu: Adding device ff350000.vpu_service to group 0
[ 1.553435] iommu: Adding device ff351000.avsd to group 1
[ 1.553992] iommu: Adding device ff340000.vepu to group 2
[ 1.554588] iommu: Adding device ff370000.vop to group 3
[ 1.555574] rk_iommu ff350800.iommu: can't get sclk
[ 1.556398] rk_iommu ff360480.iommu: can't get aclk
[ 1.556846] rk_iommu ff360480.iommu: can't get hclk
[ 1.557290] rk_iommu ff360480.iommu: can't get sclk
[ 1.557989] rk_iommu ff330200.iommu: can't get sclk
[ 1.558711] rk_iommu ff340800.iommu: can't get sclk
[ 1.559332] rk_iommu ff373f00.iommu: can't get sclk
[ 1.560439] SCSI subsystem initialized
[ 1.561021] libata version 3.00 loaded.
[ 1.561677] usbcore: registered new interface driver usbfs
[ 1.562242] usbcore: registered new interface driver hub
[ 1.562875] usbcore: registered new device driver usb
[ 1.563493] media: Linux media interface: v0.10
[ 1.563953] Linux video capture interface: v2.00
[ 1.564441] pps_core: LinuxPPS API ver. 1 registered
[ 1.564891] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
<giometti@linux.it>
[ 1.565721] PTP clock support registered
[ 1.567729] Advanced Linux Sound Architecture Driver Initialized.
[ 1.569754] NetLabel: Initializing
[ 1.570075] NetLabel: domain hash size = 128
[ 1.570465] NetLabel: protocols = UNLABELED CIPSOv4
[ 1.570976] NetLabel: unlabeled traffic allowed by default
[ 1.571931] rockchip-cpuinfo cpuinfo: Serial : a47710bd9505492d
[ 1.573632] clocksource: Switched to clocksource arch_sys_counter
[ 1.676385] NET: Registered protocol family 2
[ 1.677524] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.678453] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.679732] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.680412] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 1.681076] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 1.682106] NET: Registered protocol family 1
[ 1.682943] RPC: Registered named UNIX socket transport module.
[ 1.683475] RPC: Registered udp transport module.
[ 1.683901] RPC: Registered tcp transport module.
[ 1.684327] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.684916] PCI: CLS 0 bytes, default 64
[ 1.685536] Trying to unpack rootfs image as initramfs...
[ 1.762478] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ 1.765739] Unable to handle kernel paging request at virtual address fffffffffffffff1
[ 1.766456] pgd = ffffff8009325000
[ 1.766771] [fffffffffffffff1] *pgd=0000000000000000, *pud=0000000000000000
[ 1.767414] Internal error: Oops: 96000045 [#1] SMP
[ 1.767852] Modules linked in:
[ 1.768155] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.167 #1
[ 1.768694] Hardware name: Beikeyun (DT)
[ 1.769055] task: ffffff80090f6790 task.stack: ffffff80090e0000
[ 1.769595] PC is at default_idle_call+0x0/0x34
[ 1.770006] LR is at cpu_startup_entry+0x214/0x2ac
[ 1.770435] pc : [<ffffff800810075c>] lr : [<ffffff8008100a1c>] pstate: 000000c5
[ 1.771095] sp : ffffff80090e3f50
[ 1.771397] x29: ffffff80090e3f50 x28: 0000000002fb001c
[ 1.771888] x27: 0000000002ba722c x26: 0000000003325000
[ 1.772376] x25: 0000000003322000 x24: ffffff8008bbd000 [ 1.772691] Freeing initrd memory:
3672K
[ 1.773187]
[ 1.773353] x23: ffffff80090eb778 x22: ffffff80090eb000
[ 1.773840] x21: ffffff80090a7000 x20: 0000000000000000
[ 1.774327] x19: 0000000000000000 x18: 0000000000000002
[ 1.774815] x17: 000000004c0f6737 x16: 0000000000000050
[ 1.775302] x15: 0000000000000000 x14: 0000000300000001
[ 1.775790] x13: 0000000000000002 x12: 00000000000003f7
[ 1.776276] x11: 0000000000000400 x10: 0000000000000a30
[ 1.776763] x9 : ffffff80090e3ec0 x8 : ffffff80090f7220
[ 1.777251] x7 : 0000000000000429 x6 : 0000000000000352
[ 1.777738] x5 : ffffff8009261e80 x4 : 0100000000000000
[ 1.778225] x3 : ffffff8009109d40 x2 : 0000000000000000
[ 1.778713] x1 : ffffff80090f0e8c x0 : 0000000000000001
[ 1.779201]
[ 1.779201] PC: 0xffffff80081006dc:
[ 1.779651] 06dc aa1e03e0 d503201f a8c17bfd d65f03c0 a9bf7bfd 910003fd aa1e03e0 d503201f
[ 1.780501] 06fc a8c17bfd d65f03c0 a9bf7bfd 910003fd aa1e03e0 d503201f a8c17bfd d65f03c0
[ 1.781346] 071c a9bf7bfd 910003fd aa1e03e0 d503201f a8c17bfd d65f03c0 a9bf7bfd 910003fd
[ 1.782191] 073c aa1e03e0 d503201f f0007f40 52800021 b9077801 d50342ff a8c17bfd d65f03c0
[ 1.783017] 075c a9bf7bfd 910003fd aa1e03e0 d503201f d5384100 f9400000 721f001f 54000080
[ 1.783862] 077c d50342ff a8c17bfd d65f03c0 97fe123c 17fffffd a9bd7bfd 910003fd a90153f3
[ 1.784688] 079c f90013f5 aa0003f5 2a0203f3 aa0103f4 aa1e03e0 d503201f 36f800f3 97ffffe9
[ 1.785523] 07bc 2a1303e0 f94013f5 a94153f3 a8c37bfd d65f03c0 d5384100 f9400000 721f001f
[ 1.786363]
[ 1.786363] LR: 0xffffff800810099c:
[ 1.786810] 099c b5ffff60 94006e3f 94006478 97ffff57 17ffffa5 9400b8f0 35fff8c0 d538d081
[ 1.787625] 09bc 90007d80 910f6000 f8616813 aa1303e0 941fdafe aa0003f4 d5384100 f9400000
[ 1.788462] 09dc 36080120 d50342ff 17fffff1 b94002e0 35000060 9400b8e0 34fffa80 d503203f
[ 1.789307] 09fc 17ffffcf 94006435 aa1303e1 aa1403e0 941fd8ae 72001c1f 540001a0 97ffff51
[ 1.790154] 0a1c d53b4220 363ffc20 d0008a60 9109d400 39400401 35000081 d4210000 52800021
[ 1.790989] 0a3c 39000401 d50342ff 17ffffd8 f0007f40 b9478000 aa1303e1 7100041f aa1403e0
[ 1.791834] 0a5c 540001a1 941fd8de 37f80060 d50342ff 17ffffec aa1303e1 aa1403e0 941fd8c8
[ 1.792680] 0a7c 2a0003e2 aa1303e1 aa1403e0 97ffff42 17ffffe4 941fd98e 2a0003e2 aa1303e1
[ 1.793518]
[ 1.793518] SP: 0xffffff80090e3ed0:
[ 1.793965] 3ed0 090eb000 ffffff80 090eb778 ffffff80 08bbd000 ffffff80 03322000 00000000
[ 1.794811] 3ef0 03325000 00000000 02ba722c 00000000 02fb001c 00000000 090e3f50 ffffff80
[ 1.795656] 3f10 08100a1c ffffff80 090e3f50 ffffff80 0810075c ffffff80 000000c5 00000000
[ 1.796491] 3f30 090e3f50 ffffff80 08100a10 ffffff80 ffffffff ffffffff 00000000 00000000
[ 1.797336] 3f50 090e3fa0 ffffff80 08b9daa8 ffffff80 09261000 ffffff80 09261000 ffffff80
[ 1.798182] 3f70 090eb000 ffffff80 08ef9739 ffffff80 09014715 ffffff80 090145c8 ffffff80
[ 1.799019] 3f90 03322000 00000000 08b9daa0 ffffff80 090e3fb0 ffffff80 08fb0bb4 ffffff80
[ 1.799864] 3fb0 00000000 00000000 08fb01c4 ffffff80 00000400 00000000 00000e12 00000000
[ 1.800714]
[ 1.800714] X1: 0xffffff80090f0e0c:
[ 1.801162] 0e0c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.801998] 0e2c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.802833] 0e4c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.803648] 0e6c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.804472] 0e8c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.805318] 0eac 00000000 7d0e0aa0 ffffffc0 00000000 00000000 08d3bbc0 ffffff80 08d38d70
[ 1.806165] 0ecc ffffff80 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.807010] 0eec 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.807860]
[ 1.807860] X3: 0xffffff8009109cc0:
[ 1.808308] 9cc0 091095d8 ffffff80 0000006d 00000000 09109c68 ffffff80 09109c58 ffffff80
[ 1.809155] 9ce0 00000000 00000000 00000000 00000000 00000000 00000000 00000040 00000000
[ 1.810001] 9d00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.810847] 9d20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.811682] 9d40 0910a190 ffffff80 0910a5d0 ffffff80 00000000 00000000 00000000 00000000
[ 1.812517] 9d60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.813351] 9d80 026a026a dead4ead ffffffff 00000000 ffffffff ffffffff fffffee2 ffffffff
[ 1.814186] 9da0 fffffee1 ffffffff 00000007 00000000 0000000f 00000000 0000000f 00000000
[ 1.815035]
[ 1.815035] X5: 0xffffff8009261e00:
[ 1.815482] 1e00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.816318] 1e20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.817163] 1e40 0000000a 20746f4e 6e696174 00646574 00000000 00000000 00000000 00000000
[ 1.818008] 1e60 00000000 00000000 091056a8 ffffff80 00000000 00000000 00000000 00000000
[ 1.818833] 1e80 00000000 00000020 00000001 00000000 00000000 00000000 00000000 00000000
[ 1.819678] 1ea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.820513] 1ec0 00000000 00000022 00000002 00000000 00000000 00000000 00000000 00000000
[ 1.821357] 1ee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.822197]
[ 1.822197] X8: 0xffffff80090f71a0:
[ 1.822645] 71a0 00000000 00000000 00000000 00000000 00000000 00000001 00000000 00000000
[ 1.823490] 71c0 7d11d400 ffffffc0 090f6790 ffffff80 7d11d400 ffffffc0 090a7000 ffffff80
[ 1.824336] 71e0 0911ba30 ffffff80 08bbe588 ffffff80 7ff47340 ffffffc0 00000000 00000000
[ 1.825170] 7200 08bbe000 ffffff80 090f6e20 ffffff80 090e3ec0 ffffff80 090e3ec0 ffffff80
[ 1.826016] 7220 08085704 ffffff80 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.826861] 7240 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.827687] 7260 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.828532] 7280 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.829371]
[ 1.829371] X9: 0xffffff80090e3e40:
[ 1.829818] 3e40 00000000 01000000 09261e80 ffffff80 00000352 00000000 00000429 00000000
[ 1.830664] 3e60 090f7220 ffffff80 090e3ec0 ffffff80 00000a30 00000000 00000400 00000000
[ 1.831510] 3e80 000003f7 00000000 00000002 00000000 00000001 00000003 00000000 00000000
[ 1.832333] 3ea0 00000050 00000000 4c0f6737 00000000 00000002 00000000 00000000 00000000
[ 1.833178] 3ec0 00000000 00000000 090a7000 ffffff80 090eb000 ffffff80 090eb778 ffffff80
[ 1.834024] 3ee0 08bbd000 ffffff80 03322000 00000000 03325000 00000000 02ba722c 00000000
[ 1.834869] 3f00 02fb001c 00000000 090e3f50 ffffff80 08100a1c ffffff80 090e3f50 ffffff80
[ 1.835705] 3f20 0810075c ffffff80 000000c5 00000000 090e3f50 ffffff80 08100a10 ffffff80
[ 1.836562]
[ 1.836562] X21: 0xffffff80090a6f80:
[ 1.837010] 6f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.837846] 6fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.838692] 6fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.839527] 6fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.840373] 7000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.841220] 7020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.842064] 7040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.842911] 7060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.843748]
[ 1.843748] X22: 0xffffff80090eaf80:
[ 1.844197] af80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.845043] afa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.845888] afc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.846724] afe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.847569] b000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.848415] b020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.849250] b040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.850065] b060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.850902]
[ 1.850902] X23: 0xffffff80090eb6f8:
[ 1.851351] b6f8 0000000f 00000000 0000000f 00000000 00000000 00000000 7d004000 ffffffc0
[ 1.852196] b718 7d0e2000 ffffffc0 7d0e2200 ffffffc0 7d0e2400 ffffffc0 7d0e2600 ffffffc0
[ 1.853041] b738 7d0e2800 ffffffc0 7d0e2a00 ffffffc0 00000000 0001af3b 000003e8 00000001
[ 1.853886] b758 00000020 00000001 0007a120 00000000 00000064 00000000 00989680 00000000
[ 1.854722] b778 00000000 00004e20 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.855557] b798 00000000 00000000 0000003c 00000001 00000001 00000001 00000001 00000000
[ 1.856392] b7b8 5fed7e80 fa693b73 69499bdd d21eeb6a a9bd782a f67a951a ebf15685 ed78e9d0
[ 1.857228] b7d8 9fb21b25 9bfc8899 afc29aab f093cef5 142adde7 9df24e1f f328d1a3 9738b9ef
[ 1.858066]
[ 1.858066] X24: 0xffffff8008bbcf80:
[ 1.858513] cf80 00000380 00000000 00000080 00000000 00000001 00000000 080b347c ffffff80
[ 1.859350] cfa0 00000400 00000000 00000400 00000000 00000008 00000000 080b33a0 ffffff80
[ 1.860185] cfc0 00000800 00000000 00000400 00000000 00000008 00000000 080ae668 ffffff80
[ 1.861021] cfe0 00000c00 00000000 00000100 00000000 00000002 00000000 080b3324 ffffff80
[ 1.861856] d000 00000d00 00000000 00000080 00000000 00000001 00000000 080ae668 ffffff80
[ 1.862692] d020 00000e00 00000000 00000100 00000000 00000002 00000000 080ae668 ffffff80
[ 1.863517] d040 00000f00 00000000 00000004 00000000 00000000 00000000 080ae668 ffffff80
[ 1.864363] d060 00000f10 00000000 00000010 00000000 00000000 00000000 080ae668 ffffff80
[ 1.865204]
[ 1.865204] X29: 0xffffff80090e3ed0:
[ 1.865653] 3ed0 090eb000 ffffff80 090eb778 ffffff80 08bbd000 ffffff80 03322000 00000000
[ 1.866499] 3ef0 03325000 00000000 02ba722c 00000000 02fb001c 00000000 090e3f50 ffffff80
[ 1.867344] 3f10 08100a1c ffffff80 090e3f50 ffffff80 0810075c ffffff80 000000c5 00000000
[ 1.868190] 3f30 090e3f50 ffffff80 08100a10 ffffff80 ffffffff ffffffff 00000000 00000000
[ 1.869035] 3f50 090e3fa0 ffffff80 08b9daa8 ffffff80 09261000 ffffff80 09261000 ffffff80
[ 1.869870] 3f70 090eb000 ffffff80 08ef9739 ffffff80 09014715 ffffff80 090145c8 ffffff80
[ 1.870716] 3f90 03322000 00000000 08b9daa0 ffffff80 090e3fb0 ffffff80 08fb0bb4 ffffff80
[ 1.871560] 3fb0 00000000 00000000 08fb01c4 ffffff80 00000400 00000000 00000e12 00000000
[ 1.872407]
[ 1.872554] Process swapper/0 (pid: 0, stack limit = 0xffffff80090e0000)
[ 1.873150] Stack: (0xffffff80090e3f50 to 0xffffff80090e4000)
[ 1.873669] 3f40: ffffff80090e3fa0 ffffff8008b9daa8
[ 1.874366] 3f60: ffffff8009261000 ffffff8009261000 ffffff80090eb000 ffffff8008ef9739
[ 1.875064] 3f80: ffffff8009014715 ffffff80090145c8 0000000003322000 ffffff8008b9daa0
[ 1.875762] 3fa0: ffffff80090e3fb0 ffffff8008fb0bb4 0000000000000000 ffffff8008fb01c4
[ 1.876458] 3fc0: 0000000000000400 0000000000000e12 000000007daf1000 0000000000000003
[ 1.877155] 3fe0: 0000000000000000 0000000002000000 0000000000000000 ffffff80090145c8
[ 1.877847] Call trace:
[ 1.878075] Exception stack(0xffffff80090e3d80 to 0xffffff80090e3eb0)
[ 1.878649] 3d80: 0000000000000000 0000008000000000 ffffff80090e3f50 ffffff800810075c
[ 1.879346] 3da0: ffffff80090e3dc0 ffffff800808e020 0000000000000000 ffffff80080ee3b8
[ 1.880043] 3dc0: ffffff80090e3de0 ffffff80080ee528 ffffffc07ff473c8 ffffff80090a7000
[ 1.880740] 3de0: ffffff80090e3e60 ffffff80080f90ec ffffffc07ff47340 ffffffc07d11d480
[ 1.881439] 3e00: ffffff80090e3e30 ffffff8008ba1e90 ffffff80090e3e30 ffffff8008ba1fc0
[ 1.882134] 3e20: 0000000000000001 ffffff80090f0e8c 0000000000000000 ffffff8009109d40
[ 1.882832] 3e40: 0100000000000000 ffffff8009261e80 0000000000000352 0000000000000429
[ 1.883528] 3e60: ffffff80090f7220 ffffff80090e3ec0 0000000000000a30 0000000000000400
[ 1.884224] 3e80: 00000000000003f7 0000000000000002 0000000300000001 0000000000000000
[ 1.884918] 3ea0: 0000000000000050 000000004c0f6737
[ 1.885361] [<ffffff800810075c>] default_idle_call+0x0/0x34
[ 1.885861] [<ffffff8008b9daa8>] rest_init+0x74/0x7c
[ 1.886316] [<ffffff8008fb0bb4>] start_kernel+0x3d0/0x3f4
[ 1.886802] [<ffffff8008fb01c4>] __primary_switched+0x30/0x6c
[ 1.887323] Code: b9077801 d50342ff a8c17bfd d65f03c0 (a9bf7bfd)
[ 1.887903] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.887931] ---[ end trace b3e7bb483e2d8150 ]---
[ 1.887940] Kernel panic - not syncing: Attempted to kill the idle task!
[ 1.887948] CPU1: stopping
[ 1.887959] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.167 #1
[ 1.887962] Hardware name: Beikeyun (DT)
[ 1.887965] Call trace:
[ 1.887980] [<ffffff80080889b0>] dump_backtrace+0x0/0x1bc
[ 1.887989] [<ffffff8008088b90>] show_stack+0x24/0x30
[ 1.887999] [<ffffff8008585dac>] dump_stack+0x98/0xc0
[ 1.888009] [<ffffff800808db8c>] handle_IPI+0x1d0/0x248
[ 1.888017] [<ffffff8008080d90>] gic_handle_irq+0xa8/0xc0
[ 1.888023] Exception stack(0xffffffc07d20fe10 to 0xffffffc07d20ff40)
[ 1.888030] fe00: 0000004076eab000 ffffff80090a7000
[ 1.888040] fe20: 0000000000000000 ffffff8009109d40 0100000000000000 0000000008b8898c
[ 1.888048] fe40: 0000000000000328 0000000000000000 ffffffc07d201890 ffffffc07d20fef0
[ 1.888059] fe60: 0000000000000a30 0000000000000400 0000000000000400 0000000000000002
[ 1.888067] fe80: 0000000300000001 0000000000000000 0000000000000008 0000000010265ff3
[ 1.888076] fea0: 0000000000000000 ffffff80090a7000 ffffff800924fb18 ffffff800924f000
[ 1.888084] fec0: ffffff80090eb000 ffffff80090eb778 ffffff8008bbd000 0000000003322000
[ 1.888093] fee0: 0000000003325000 0000000002ba7234 0000000000000000 ffffffc07d20ff40
[ 1.888103] ff00: ffffff8008085100 ffffffc07d20ff40 ffffff8008085104 0000000060000045
[ 1.888112] ff20: ffffff80090a7000 ffffff80090eb000 ffffffffffffffff ffffff8008bbd000
[ 1.888120] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[ 1.888129] [<ffffff8008085104>] arch_cpu_idle+0x8c/0x100
[ 1.888137] [<ffffff800810078c>] default_idle_call+0x30/0x34
[ 1.888144] [<ffffff8008100a1c>] cpu_startup_entry+0x214/0x2ac
[ 1.888153] [<ffffff800808d568>] secondary_start_kernel+0x190/0x1bc
[ 1.888159] [<0000000002ba7178>] 0x2ba7178
[ 1.888165] CPU2: stopping
[ 1.888175] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.167 #1
[ 1.888178] Hardware name: Beikeyun (DT)
[ 1.888181] Call trace:
[ 1.888193] [<ffffff80080889b0>] dump_backtrace+0x0/0x1bc
[ 1.888202] [<ffffff8008088b90>] show_stack+0x24/0x30
[ 1.888211] [<ffffff8008585dac>] dump_stack+0x98/0xc0
[ 1.888219] [<ffffff800808db8c>] handle_IPI+0x1d0/0x248
[ 1.888226] [<ffffff8008080d90>] gic_handle_irq+0xa8/0xc0
[ 1.888233] Exception stack(0xffffffc07d213e10 to 0xffffffc07d213f40)
[ 1.888240] 3e00: 0000004076ec0000 ffffff80090a7000
[ 1.888249] 3e20: 0000000000000000 ffffff8009109d40 0100000000000000 0000000008b8898c
[ 1.888258] 3e40: 0000000000000328 00000000000003ea ffffffc07d202690 ffffffc07d213ef0
[ 1.888268] 3e60: 0000000000000a30 0000000000000400 0000000000000114 0000000000000001
[ 1.888276] 3e80: 0000000000000001 0000000000000000 0000000000000000 0000000000000000
[ 1.888287] 3ea0: 0000000000000007 ffffff80090a7000 ffffff800924fb18 ffffff800924f000
[ 1.888296] 3ec0: ffffff80090eb000 ffffff80090eb778 ffffff8008bbd000 0000000003322000
[ 1.888304] 3ee0: 0000000003325000 0000000002ba7234 0000000000000000 ffffffc07d213f40
[ 1.888313] 3f00: ffffff8008085100 ffffffc07d213f40 ffffff8008085104 0000000060000045
[ 1.888322] 3f20: ffffff80090a7000 ffffff80090eb000 ffffffffffffffff ffffff8008bbd000
[ 1.888331] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[ 1.888340] [<ffffff8008085104>] arch_cpu_idle+0x8c/0x100
[ 1.888348] [<ffffff800810078c>] default_idle_call+0x30/0x34
[ 1.888355] [<ffffff8008100a1c>] cpu_startup_entry+0x214/0x2ac
[ 1.888364] [<ffffff800808d568>] secondary_start_kernel+0x190/0x1bc
[ 1.888369] [<0000000002ba7178>] 0x2ba7178
[ 1.888633] CPU3: stopping
[ 1.888642] CPU: 3 PID: 1 Comm: swapper/0 Tainted: G D 4.4.167 #1
[ 1.888646] Hardware name: Beikeyun (DT)
[ 1.888648] Call trace:
[ 1.888660] [<ffffff80080889b0>] dump_backtrace+0x0/0x1bc
[ 1.888669] [<ffffff8008088b90>] show_stack+0x24/0x30
[ 1.888678] [<ffffff8008585dac>] dump_stack+0x98/0xc0
[ 1.888686] [<ffffff800808db8c>] handle_IPI+0x1d0/0x248
[ 1.888693] [<ffffff8008080d90>] gic_handle_irq+0xa8/0xc0
[ 1.888700] Exception stack(0xffffffc07d143810 to 0xffffffc07d143940)
[ 1.888707] 3800: 0000000000000000 0000000000000000
[ 1.888715] 3820: 0000004076ed5000 0000004076ed5000 ffffff80090eb6e8 00000000fffffffe
[ 1.888725] 3840: ffffff8009264ae8 6c62616e65203a73 2068746977206465 6f635f38766d7261
[ 1.888735] 3860: 3335615f78657472 69726420554d5020 632037202c726576 20737265746e756f
[ 1.888744] 3880: 6c62616c69617661 0000000000000000 ffffff8008c3467a ffffff8008c34e7a
[ 1.888755] 38a0: 0000000000000005 ffffff8009109450 0000000000000006 ffffff800926e484
[ 1.888763] 38c0: 000000000000005d ffffff8009109458 ffffff8008e5878c ffffff8009264948
[ 1.888772] 38e0: ffffff8009264a8c 0000000000000040 ffffff8009265000 ffffffc07d143940
[ 1.888781] 3900: ffffff800810d174 ffffffc07d143940 ffffff800810d178 0000000060000045
[ 1.888790] 3920: ffffff8009264948 ffffff8009264a8c ffffffffffffffff 0000000000000400
[ 1.888798] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[ 1.888810] [<ffffff800810d178>] console_unlock+0x364/0x3dc
[ 1.888821] [<ffffff800810d62c>] vprintk_emit+0x43c/0x440
[ 1.888831] [<ffffff800810d678>] vprintk+0x48/0x54
[ 1.888841] [<ffffff800810d6ac>] vprintk_default+0x28/0x34
[ 1.888851] [<ffffff800818f74c>] printk+0x70/0x7c
[ 1.888860] [<ffffff800895fbfc>] armpmu_register+0xcc/0xe8
[ 1.888868] [<ffffff800895ffd8>] arm_pmu_device_probe+0x3c0/0x4a4
[ 1.888878] [<ffffff8008090b74>] armv8_pmu_device_probe+0x30/0x3c
[ 1.888889] [<ffffff80086ed34c>] platform_drv_probe+0x5c/0xb0
[ 1.888898] [<ffffff80086eb4fc>] driver_probe_device+0x190/0x274
[ 1.888907] [<ffffff80086eb634>] __driver_attach+0x54/0xa0
[ 1.888914] [<ffffff80086e985c>] bus_for_each_dev+0x8c/0x9c
[ 1.888922] [<ffffff80086eaf9c>] driver_attach+0x30/0x3c
[ 1.888930] [<ffffff80086eabe0>] bus_add_driver+0x1a0/0x1e4
[ 1.888939] [<ffffff80086ec1d0>] driver_register+0xa0/0xd8
[ 1.888948] [<ffffff80086ed290>] __platform_driver_register+0x58/0x64
[ 1.888957] [<ffffff8008fb55b0>] register_armv8_pmu_driver+0x18/0x20
[ 1.888966] [<ffffff80080831b8>] do_one_initcall+0x178/0x180
[ 1.888976] [<ffffff8008fb0e00>] kernel_init_freeable+0x228/0x22c
[ 1.888986] [<ffffff8008b9dac8>] kernel_init+0x18/0x100
[ 1.888993] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[ 1.888998] CRU:
[ 1.889018] 00000000: 000070d7 00000486 000a3d70 00000000 00000000 00000000 00000000 00000000
[ 1.889036] 00000020: 00002083 00001441 00000001 00000000 00000000 00000000 00000000 00000000
[ 1.889053] 00000040: 00001032 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889069] 00000060: 000023d7 00000458 000a3d70 00000000 00000000 00000000 00000000 00000000
[ 1.889087] 00000080: 00001113 0000a000 00005a5a 00000000 3a98c064 00000000 00000000 00000000
[ 1.889103] 000000a0: 0000304b 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889118] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889133] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889150] 00000100: 000007c0 00001113 00000003 00000000 00002c80 00008004 0000000f 00040050
[ 1.889167] 00000120: 0000000f 00040050 0000000f 00040050 0000000f 00040050 00000207 00040050
[ 1.889184] 00000140: 00000207 00040050 00000207 00040050 00008087 0000170c 000001e0 00000017
[ 1.889203] 00000160: 00008107 00000207 0000000f 00000705 00004107 00000011 0000021d 00000017
[ 1.889219] 00000180: 00000105 00008800 00000707 00000707 00000305 00000203 00007a97 00000002
[ 1.889234] 000001a0: 00003111 0bb8ea60 00003113 00000003 00000042 0000001f 00000000 00000000
[ 1.889250] 000001c0: 00000340 00000041 00000003 00000505 00000b31 00000000 00000000 00000000
[ 1.889267] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889283] 00000200: 00000000 0000f336 0000200f 00000000 00000001 00000000 00000000 00000000
[ 1.889300] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 1.889317] 00000240: 00000780 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889333] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889348] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889363] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889380] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889396] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889413] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889429] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889445] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889463] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889478] 00000380: 00000004 00000000 00000004 00000000 00000004 00000000 00000004 00000000
[ 1.889493] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889509] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889526] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889529] PMU:
[ 1.889546] 00000000: 00008000 00000101 00005005 00000001 00001555 0000aaaa 0000a88a 00000008
[ 1.889561] 00000020: 00000a05 00000255 00000000 00000000 00000000 0000aa00 00000000 00000000
[ 1.889577] 00000040: 00000000 00000000 00002aaa 00000000 00000085 00000000 00000000 00000000
[ 1.889593] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889608] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889625] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889640] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889654] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.889659] Kernel Offset: disabled
[ 1.970814] Rebooting in 10 seconds..
