原文
https://www.mydigit.cn/forum.php ... d=139060&extra=
焊接了引脚与用ttl成功连接
但好像进去跟网上有点不一样
请大家帮忙
不按任何按键
Bootrom start
Boot Media: eMMC
Decrypt auxiliary code ...OK
Enter boot auxiliary code
Auxiliary code - v1.00
DDR code - V1.1.2 20160205
Build: Sep 7 2017 - 01:06:39
Reg Version: v1.5.2`
Reg Time: 2018/02/25 12:35:26
Reg Name: hi3798mv3dmm_hi3798mv300_DDR3-1866_1GB_16bitx2_4layers_cm_01.reg
Boot auxiliary code success
Bootrom success
System startup
Relocate Boot
Jump to C code
Fastboot 3.3.0 (yangyumei@wangYS) (Mar 27 2018 - 16:25:16)
Fastboot: Version 3.3.0
Build Date: Mar 27 2018, 16:27:48
CPU: Hi3798Mv300
Boot Media: eMMC
DDR Size: 1GB
Found flash memory controller hifmc100.
no found nand device.
MMC/SD controller initialization.
scan edges:2 p2f:6 f2p:8
mix set temp-phase 3
scan elemnts: startp:104 endp:93
Tuning SampleClock. mix set phase:[03/07] ele:[07/13]
MMC/SD Card:
MID: 0x15
Read Block: 512 Bytes
Write Block: 512 Bytes
Chip Size: 7456M Bytes (High Capacity)
Chip Type: MMC
Version: 5.1
Speed: 100000000Hz
Mode: HS400
Voltage: 1.8V
Bus Width: 8bit
Boot Addr: 0 Bytes
Net: upWarning: failed to set MAC address
, gmac0Warning: failed to set MAC address
Boot Env on eMMC
Env Offset: 0x00400000
Env Size: 0x00010000
Env Range: 0x00010000
SDK Version: cmcc_v6r3c01spc012cp0001_patch5
check remote recovery button begin
count=2
mac:00:E4:00:DA:73:BD
Reserve Memory
Start Addr: 0x3FFFE000
Bound Addr: 0x8D80000
Free Addr: 0x3F1FC000
Alloc Block: Addr Size
0x3FBFD000 0x400000
0x3F8FC000 0x300000
0x3F8F9000 0x2000
0x3F878000 0x80000
0x3F725000 0x152000
0x3F3A0000 0x384000
0x3F39C000 0x3000
0x3F206000 0x195000
0x3F1FC000 0x9000
Press Ctrl+C to stop autoboot
MMC read: dev # 0, block # 327680, count 20480 ... 20480 blocks read: OK
158197618 Bytes/s
Found Initrd at 0x04000000 (Size 344421 Bytes), align at 16384 Bytes
## Booting kernel from Legacy Image at 01ffffc0 ...
Image Name: Linux-3.18.24_hi3798mv2x
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 9026176 Bytes = 8.6 MiB
Load Address: 02000000
Entry Point: 02000000
XIP Kernel Image ... OK
OK
ATAGS [0x00000100 - 0x00000480], 896Bytes
Starting kernel ...
Uncompressing Linux... done, booting the kernel. |
