查看: 3554|回复: 5
[C51] DIY WS2812时钟
发表于 2020-4-20 14:35:05 | 显示全部楼层 |阅读模式
没事研究WS2812驱动,千辛万苦的搞到能带到1024支WS2812了后发现51速度太慢了,WS2812超过200支即使用到30M时钟也满足不了要求,最后也懒得优化程序了,做个半成品时钟就全拆了。
单片机STC15W4K 的时钟24M 如果只做时钟6M即可  乱七八糟,见谅
#include "REG51.h"
#include "intrins.h"
#define  u8 unsigned char
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
#define ulint unsigned long int//宏定义
#define uchar unsigned char//宏定义
#define uint unsigned int//宏定义
long int TM;//LCD显示变量
uchar h1,h2,h3,h4,h5,h6,h7;//LCD显示变量
sbit WS2812 = P0^4;
sbit K1 = P2^3;
sbit K2 = P2^4;
sbit K3 = P2^5;
sbit K4 = P2^6;
#define numLEDs 60
unsigned char buf_R[numLEDs] = {0};//颜色缓存
unsigned char buf_G[numLEDs] = {0};
unsigned char buf_B[numLEDs] = {0};
void timer_init(void);//定时器初始化
void ws2812_write_byte(u8 dat);
void Delay2000ms()        //@24.000MHz
    unsigned char i, j, k;
    _nop_();
    _nop_();
    i = 183;
    j = 100;
    k = 225;
    do
        do
            while (--k);
        } while (--j);
    } while (--i);
void HAL_Delay(unsigned int t)
        unsigned int x,y;
      for(x=114;x>0;x--)
      for(y=t;y>0;y--);
//复位延时
void Delay50us()        //@24.000MHz
    unsigned char i, j;
    i = 2;
    j = 39;
    do
        while (--j);
    } while (--i);
//发送24位数据
void Send_2811_24bits(unsigned char G8,unsigned char R8,unsigned char B8)
ws2812_write_byte(G8);
ws2812_write_byte(R8);
//     ws2812_write_byte(G8);
//  ws2812_write_byte(R8);
     ws2812_write_byte(B8);
u8 i = 8;
    dat <<= 1;
    while(i)
        WS2812 = 1;
        _nop_();_nop_();_nop_();_nop_();_nop_();             _nop_();   //22.1184M   //30M
        WS2812 = CY;
        WS2812 = 0;
        dat <<= 1;
        i--;
//复位码
void RGB_Rst()
        WS2812 = 0;
        Delay50us();
//把24位数据GRB码转RGB
void Set_Colour(unsigned char r,unsigned char g,unsigned char b)
//      unsigned char i;
    unsigned int i;
        for(i=0;i<numLEDs;i++)
                buf_R = r; //缓冲
              buf_G = g;
              buf_B = b;
            Send_2811_24bits(buf_G,buf_R,buf_B);//发送显示
//某一个点显示的颜色
void SetPointColour(unsigned int num,unsigned char r,unsigned char g,unsigned char b)
//      unsigned char i;
          unsigned int i;
                buf_R[num] = r;//缓冲
              buf_G[num] = g;
              buf_B[num] = b;
//颜色交换24位不拆分发
//void SetPixelColor(unsigned char num,unsigned long c)
void SetPixelColor(unsigned int num,unsigned long c)
//      unsigned char i;
          unsigned int i;
                buf_R[num] = (unsigned char)(c>>16);
              buf_G[num] = (unsigned char)(c>>8);
              buf_B[num] = (unsigned char)(c);
//复位
void PixelUpdate()
    RGB_Rst();
//颜色
unsigned long Color(unsigned char r, unsigned char g, unsigned char b)
  return ((unsigned long)r << 16) | ((unsigned long)g <<  8) | b;
//颜色算法
unsigned long Wheel(unsigned char WheelPos)
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85)
    return Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
//彩虹
void rainbow(unsigned int wait)
  unsigned int i, j;
  for(j=0; j<256; j++)
    for(i=0; i<numLEDs; i++)
    //  SetPixelColor(i, Wheel((i+j) & 255));
            SetPixelColor(i, Wheel((i*4+j)   & 255));
        PixelUpdate();
    HAL_Delay(wait);
//稍微不同的是,这使得彩虹均匀分布
void rainbowCycle(unsigned int wait)
  unsigned int i, j;
// for(j=0;j<256*5;j++)
    for(j=0;j<256;j++)
    // SetPixelColor(i, Wheel(((i * 256 / numLEDs) + j) & 255));
           SetPixelColor(i, Wheel(((i * 2048 / numLEDs) + j) & 255));
      PixelUpdate();
    HAL_Delay (wait);
void theaterChase(unsigned long c, unsigned int wait)
    int j,q;
    unsigned int i;
  for (j=0; j<10; j++)
    {  //do 10 cycles of chasing  做10个循环
    for (q=0; q < 3; q++)
      for (i=0; i<numLEDs; i=i+3)
        SetPixelColor(i+q, c);    //turn every third pixel on  把每一个第三个像素
            PixelUpdate();
      HAL_Delay(wait);
       SetPixelColor(i+q, 0);        //turn every third pixel off   把每一个第三个像素关掉
            PixelUpdate();
void theaterChase2(unsigned long c, unsigned int wait)
    int j,q;
    unsigned int i;
    for (q=0; q < 2; q++)
      for (i=0; i<numLEDs; i=i+2)
            PixelUpdate();
      HAL_Delay(wait);
            PixelUpdate();
//Theatre-style crawling lights with rainbow effect
//带有彩虹效果的戏剧式爬行灯
void theaterChaseRainbow(unsigned int wait)
    int j,q;
    unsigned int i;
  for (j=0; j < 256; j++)
    {     // cycle all 256 colors in the wheel 在轮子上循环所有256色
      for (i=0; i < numLEDs; i=i+3)
        SetPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel off 把每一个第三个像素
      PixelUpdate();
      HAL_Delay(wait);
void theaterChaseRainbow2(unsigned int wait)
    int j,q;
    unsigned int i;
      for (i=0; i < numLEDs; i=i+2)
       // SetPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel off 把每一个第三个像素
                        SetPixelColor(i+q, Wheel( (i*8+j) % 255));    //turn every third pixel off 把每一个第三个像素
      PixelUpdate();
      HAL_Delay(wait);
// Fill the dots one after the other with a color
//用一种颜色填充这些圆点
void colorWipe(unsigned long c, unsigned int wait)
    unsigned int i=0;
  for( i=0; i<numLEDs; i++)
    SetPixelColor(i, c);
    PixelUpdate();
    HAL_Delay(wait);
//单灯流水
    void Watercolor(unsigned long c, unsigned int wait)
//      unsigned char i=0;
            unsigned int i=0;
      PixelUpdate();
        HAL_Delay(wait*5);
    SetPixelColor(i, 0);
       PixelUpdate();
        HAL_Delay(wait);
void timer_init(void)//定时器初始化                                     50MS
     TMOD=0x01;/////////设置工作方式1
      TH0=(65536-50000)/256;///////赋值
      TL0=(65536-50000)%256;
     EA=1;ET0=1;//开总中断;开定时器中断
     TR0=1;////////启动计数器
void timer0()interrupt 1  //定时中断
     TR0=0;
      TH0=(65536-50000)/256;///////赋初值
        if(h4>39)
         h4=0;
            TM++;
    h1=TM/720;
    h2=TM%3600/60;
h3=TM%3600%60;
Set_Colour(0,0,0);
            SetPointColour(h1,0,127,0); // grb
             SetPointColour(h2,127,0,0); // grb
            SetPointColour(h3,0,0,127); // grb
        if(TM>43199)
        TM=0;
                 h4++;
     TR0=1;
void main()
    P0M0 = 0xFF;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
   colorWipe(0xff0000,0);
            //Set_Colour(0,0,0); //一下全黑
                        colorWipe(0x000000,0);  //彩虹7色
                    colorWipe(0xff7f00,0);
                        colorWipe(0xffff00,0);
                        colorWipe(0x00ff00,0);
                        colorWipe(0x00ffff,0);
                        colorWipe(0x0000ff,0);
                     colorWipe(0x8b00ff,0);
//SetPointColour(9,255,0,0); // grb
//SetPointColour(19,255,0,0); // grb
//SetPointColour(20,255,0,0); // grb
//SetPointColour(23,255,0,0); // grb
//SetPointColour(24,255,0,0); // grb
//SetPointColour(31,255,0,0); // grb
//SetPointColour(32,255,0,0); // grb
//SetPointColour(39,255,0,0); // grb
//SetPointColour(41,255,0,0); // grb
//SetPointColour(46,255,0,0); // grb
//SetPointColour(50,255,0,0); // grb
//SetPointColour(53,255,0,0); // grb
//SetPointColour(59,255,0,0); // grb
//SetPointColour(60,255,0,0); // grb
Delay2000ms();
Set_Colour(0,0,0);
         timer_init();//定时器初始化
//Delay3000ms();
//rainbowCycle(0);
h5=01;
h6=10;
h7=0;
TM=h5*3600+h6*60+h7;
        while(1)
        //    Set_Colour(16,16,16);
    //    rainbow(0);
         //    rainbowCycle(0);
            if(K1==0){
                rainbow(45);//彩虹
            }//彩虹
            if(K2==0){
                rainbowCycle(0);////稍微不同的是,这使得彩虹均匀分布;
            }//彩虹
                        if(K3==0){
                   Watercolor(0xff0000, 255);//红色单灯流水
     Watercolor(0x00ff00, 255);//绿色单灯流水
      Watercolor(0x0000ff, 255);//蓝色单灯流水
                                    if(K4==0){
                        colorWipe(0x000000,255);  //彩虹7色
  //Set_Colour(221,156,1);// 全屏颜色
  //        Watercolor(0xff0000, 0);//红色单灯流水
//         HAL_Delay(1000);
  //     Watercolor(0x00ff00, 0);//绿色单灯流水
  //       HAL_Delay(1000);
   //     Watercolor(0x0000ff, 0);//蓝色单灯流水
  //        HAL_Delay(1000);  ///延时是22m的 是多久 22M 0.17MS
//h4=6;
//SetPointColour(h2,255,0,0); // grb
    //          theaterChase(Color(55,0,0),0); // 必须3的倍数
            //  theaterChase2(Color(0,0,255),80); // Blue
  //theaterChaseRainbow(0);  //带有彩虹效果的戏剧式爬行灯
    //                colorWipe(0xff0000,0);
    //                    colorWipe(0x000000,0);  //彩虹7色
//                    colorWipe(0xff7f00,0);
    //                    colorWipe(0xffff00,0);
    //                colorWipe(0x00ff00,0);
    //                colorWipe(0x00ffff,0);
    //                    colorWipe(0x0000ff,0);
    //                colorWipe(0x8b00ff,0);
//theaterChaseRainbow2(0);
参与人数 3家元 +48 收起 理由
人艰不拆了 + 10
家睦 + 30
zidian + 8
发表于 2020-4-20 16:31:15 | 显示全部楼层
这个好像速率要求大于1M吧,忘了,反正uno不特别处理是驱动不起来的,你的51能输出多快呢?:loveliness:
发表于 2020-4-20 19:13:46 | 显示全部楼层
换STM32吧,DMA+SPI或者DMA+PWM,刷新WS2812可以达到其极限速率:lol:
发表于 2020-4-21 00:57:55 | 显示全部楼层
请楼主讲讲 设计思路?
谢谢!
 楼主| 发表于 2020-4-23 08:07:19 | 显示全部楼层
不好意思 程序中有大BUG,中断里面干的活太多了,以至于一小时慢一分钟多,更改了一下,实验过了修正了错误,24小时走时正常。
        TR0=0;
                  h4++;
                if(h4==40)
            h4=0;
                        TM++;
      if(TM>43199)
                TM=0;
                h8=1;
        TR0=1;
if(h8==1)
        h1=TM/720;
  h2=TM%3600/60;
  h3=TM%3600%60;
      Set_Colour(0,0,0);
                h8=0;
发表于 2020-4-23 17:17:56 | 显示全部楼层
居然还是劳力士
壕!:time:
GMT+8, 2024-5-3 19:45 , Processed in 0.140400 second(s), 14 queries , Redis On.
© 2006-2023 smzj.net
