查看: 9193|回复: 6
[Other] 请问这个固态硬盘还有救吗?
发表于 2019-3-19 20:51:17 | 显示全部楼层 |阅读模式
金胜维固态硬盘,请问这个盘还有救吗?phison_flash_id:
v0.777a
Drive: 1(ATA)
OS: 6.1 build 7601 Service Pack 1
Model: INIC6081SSDWP
Fw   : INICWP00
P/N  :
S11fw: SBFM71T0, 2017Mar 9
Original Model: P3-128
Original Fw   : 1.00
Bank00: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank02: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank08: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Controller   : Possible PS3109 or PS3111
Flash CE     : 3
PS3105/3108/3109/3111 only:
Flash Channel: 2
Dram Size,MB : 32
PS3110 only  :
Flash Channel: 3
Interleave   : 2
Flash Mode/Clk: 0/0 (S9) or 5/7 (S11)
Defects All Early Later
Bank00:  26  26   0
Bank02:  42  41   1
Bank08:  38  38   0
Total : 106 105   1
Early defect list
Bank00: 40 96 97 98 99 1122 1130 1133 1378 1381 1634 1637 1639 1920 1922 1923 1924 1925 1927 1928 1929 1930 1931 1932 1933 1935
Bank02: 96 97 98 99 906 1122 1130 1134 1286 1376 1378 1379 1380 1382 1592 1632 1633 1634 1635 1636 1637 1638 1660 1768 1806 1860 1920 1921 1922 1923 1924 1925 1926 1928 1929 1930 1931 1932 1933 1934 1935
Bank08: 96 97 98 99 908 909 1124 1128 1132 1376 1377 1378 1380 1381 1492 1632 1633 1634 1636 1637 1805 1813 1853 1920 1921 1922 1923 1924 1925 1927 1928 1929 1930 1931 1932 1933 1934 1935
Later defect list
Bank02: 766
PS3111 smart configuration:
Attr Tresh Flags ValId WrstId  RawId   Description
0x01: 0x32 0x0B 0x0100 0x0100 0x0100 - Number of ECC Error
0x05: 0x00 0x00 0x0000 0x0000 0x0302 - Total Later Bad Block Count
0x09: 0x00 0x32 0x0000 0x0000 0x0600 - Power on hours
0x0C: 0x00 0x00 0x0000 0x0000 0x0607 - Power on/off cycles
0xA0: 0x00 0x00 0x0000 0x0000 0x0500 - Read Fail Count
0xA1: 0x00 0x00 0x0000 0x0000 0x0306 - Spare Block Count (Plane)
0xA3: 0x00 0x00 0x0000 0x0000 0x0301 - Total Early Bad Block Count
0xA4: 0x00 0x00 0x0000 0x0000 0x0200 - Total Erase Count
0xA5: 0x00 0x00 0x0000 0x0000 0x0201 - Max Erase Count
0xA6: 0x00 0x00 0x0000 0x0000 0x020B - Min Erase Cnt
0xA7: 0x00 0x00 0x0000 0x0000 0x0202 - Avg Erase Count
0xC0: 0x00 0x00 0x0000 0x0000 0x0608 - Unexpected Power Loss Count
0xC2: 0x00 0x00 0x0000 0x0000 0x0801 - Current Temp
0xC3: 0x00 0x00 0x0000 0x0000 0xF010 - HB retry count
0xC4: 0x00 0x00 0x0000 0x0000 0x0706 - ReadMoveTableCnt
0xF1: 0x00 0x00 0x0000 0x0000 0x0403 - Host Write (65536 Sectors)
0xF2: 0x00 0x00 0x0000 0x0000 0x0423 - Host Read (65536 Sectors)
发表于 2019-3-20 11:07:02 | 显示全部楼层
TLC的 无所谓了
发表于 2020-3-3 21:58:18 | 显示全部楼层
我的也是这个盘,无法分区
发表于 2020-3-4 12:14:07 | 显示全部楼层
S11fw: SBFM71T0, 2017Mar 9 这个不是告诉你可以用PS3111的SBFM71固件升级试试么
发表于 2020-6-9 12:37:03 | 显示全部楼层
我的和这个一模一样,我试了几个sbfm71的固件,显示成功,但是还是不认盘,这个芯片是打字的,估计是修改的固件,通用的没戏
发表于 2020-9-2 01:02:43 | 显示全部楼层
算是同颗粒搜索过来的,也是没什么头绪,不过打算多试几个固件..没准就活了
3: NT-128
4: ST250DM000-1BD141
5: NVMe    Colorful CN600 1
6: NVMe    HFM128GDJTNG-831
Please select drive number:3
Drive: 3(ATA)
Model: NT-128
Fw   : 1.83.00
ReadFID - 2762 ms.
P/N  :
S11fw: SBFG71T2, 2018Apr 3
Bank00: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron TLC 384Gb/CE 384Gb/die
Bank02: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron TLC 384Gb/CE 384Gb/die
Bank08: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron TLC 384Gb/CE 384Gb/die
Flash CE     : 3
Flash Channel: 2
DRAM Size,MB : 32
Bank00:  20  20   0
Bank02:  14  14   0
Bank08:  15  15   0
Total :  49  49   0
Saved to: phison_flash_id.txt
发表于 2022-5-17 09:48:21 | 显示全部楼层
修改的固件,通用的没戏
GMT+8, 2025-7-20 20:36 , Processed in 0.156000 second(s), 9 queries , Redis On.
