查看: 1699|回复: 1
[其他] 请教两个技术术语
发表于 2020-12-25 10:03:11 | 显示全部楼层 |阅读模式
在MP2625开关型可变途径锂电池充电IC的引脚定义描述中,以下红字各代表什么意思?
请大神指点。
①
Open drain charge status output to indicate various charger operation.
Connect to the pull up rail via 10-kΩ resistor. LOW indicates charge in progress. HIGH indicates charge complete or charge disabled. When any fault condition occurs, STAT pin blinks in 1 Hz.
The STAT pin function can be disabled when STAT_DIS bit is set.
② BATFET enable/reset control input.
When BATFET is in ship mode, a logic low of tSHIPMODE (typical 1sec) duration turns on BATFET to exit shipping mode. .
When VBUS is not plugged-in, a logic low of tQON_RST (typical 10sec) duration resets SYS (system power) by turning BATFET off for tBATFET_RST (typical 0.3sec) and then re-enable BATFET to provide full system power reset.
The pin contains an internal pull-up to maintain default high logic
发表于 2020-12-25 10:14:15 | 显示全部楼层
Open drain charge status:开漏引脚
Connect to the pull up rail via 10-kΩ resistor.:需要一个10K电阻上拉到VCC
When BATFET is in ship mode:当BATFET处于运输模式时
参与人数 2家元 +15 收起 理由
温力口 + 5 熱心會員
邓穿石 + 10 熱心會員
GMT+8, 2025-5-12 11:50 , Processed in 0.343200 second(s), 13 queries , Redis On.
