| 1 | 3 | 0 | 2 | 0x0001 | N1 | PASS |
| 1 | 3 | 0 | 3 | 0x0001 | N1 | PASS |
Total Number of test results: 32
Number of failures: 0
Number of Passed with warnings: 0
No. Passed without warnings: 32
[Wed 03/17/2021 16:04:43] - Performing the FORMAT Command with the following parameters:
MemoryWearCycleCapability = 0
CurrentPE_CycleCount = 0
LifeInSeconds = 0
LogicalCapacity = 468862128
SectorSize = 512
SectorAlignmentOffset = 0
ExpectedMemoryID = 56984 (0xDE98)
ExpectedNumDies = 0
SerialOutputControl = 0
Time[8] = 0x0000000000000000
MiscFlag_Erase_R_Block = 0
MiscFlag_PanicHandlingEnabled = 0
MiscFlag_PanicOnSATA_Error = 0
MiscFlag_WriteThrottlingTestMode = 0
MiscFlag_DisableUserBandECCX = 0
L_PageSize = 0
E_PageSize = 0
ErrorCorrectionPower = 0
ConfigDeviceReadDisturbCount = 0
ConfigDeviceReadDisturbCountLow = 0
ExtraOptions_0_1 = 0
[Wed 03/17/2021 16:05:14] - FORMAT command completed...
[Wed 03/17/2021 16:05:14] - Waiting (2 sec) for the drive to settle...
[Wed 03/17/2021 16:05:16] - Setting up the stamp information through CDU command...
[Wed 03/17/2021 16:05:20] - Waiting (2 sec) for the drive to settle...
[Wed 03/17/2021 16:05:22] - Downloading the flashware to the drive... feature 3
[Wed 03/17/2021 16:05:26] - Successfully downloaded flashware to the drive...
[Wed 03/17/2021 16:05:26] - Waiting (15 sec) for the drive to settle...
[Wed 03/17/2021 16:05:57] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Wed 03/17/2021 16:05:57] - End of Genesis manufacturing log.
[Wed 03/17/2021 16:05:57] - Exiting...
有没有遇到过这个问题大佬能给个解决思路?
选写保护选项到format 就报错 ,选BO1电源直接提示不支持
早上把昨晚家里翻出来的带辅助供电口的usb线拿来尝试了,一次过。
看来sf2281自己主控+贴满16片的板子的确挺耗电的。
还有这个板子1 不需要选写保护 2 电源选BO1 昨天我记错了,不能选BO2
附开卡部分信息:
Number of Passed with warnings: 2
No. Passed without warnings: 30
[Thu 03/18/2021 08:42:10] - Performing the FORMAT Command with the following parameters:
LifeInSeconds = 0
SectorSize = 512
ExpectedNumDies = 0
L_PageSize = 0
E_PageSize = 0
[Thu 03/18/2021 08:42:40] - FORMAT command completed...
[Thu 03/18/2021 08:42:40] - Waiting (2 sec) for the drive to settle...
[Thu 03/18/2021 08:42:42] - Setting up the stamp information through CDU command...
[Thu 03/18/2021 08:42:46] - Waiting (2 sec) for the drive to settle...
[Thu 03/18/2021 08:42:48] - Downloading the flashware to the drive... feature 3
[Thu 03/18/2021 08:42:51] - Successfully downloaded flashware to the drive...
[Thu 03/18/2021 08:42:51] - Waiting (15 sec) for the drive to settle...
[Thu 03/18/2021 08:43:07] - Successfully received the IDENTIFY data from the drive...
[Thu 03/18/2021 08:43:07] - Firmware revision reported to be: 'GT5 '
[Thu 03/18/2021 08:43:07] - Enabling SMART support...
[Thu 03/18/2021 08:43:07] - Issuing a diagnostic unlock to the drive...
[Thu 03/18/2021 08:43:09] - Setting up Max LBA settings...
[Thu 03/18/2021 08:43:13] - Change of sector size is not required, sector size is already set to 512
[Thu 03/18/2021 08:43:14] - Setting the serial number of the drive to: 12345
[Thu 03/18/2021 08:43:16] - Setting the World Wide Name (WWN) of the drive to: www_123
[Thu 03/18/2021 08:43:20] - Processing completed for device: 12345
[Thu 03/18/2021 08:43:20] - Begin collecting the device post-process log/information
中间部分信息略
Thu 03/18/2021 08:43:27] - Plain text panic directory listing log created
[Thu 03/18/2021 08:43:27] - Completed collecting all plain text log files.
[Thu 03/18/2021 08:43:27] - End of logs and information collection
[Thu 03/18/2021 08:43:28] - Applying the remaining ConfigUniqueDrive settings...
[Thu 03/18/2021 08:43:29] - Setting Customer ID with value : 12345
[Thu 03/18/2021 08:43:29] - Setting Diagnostic Unlock Key with value supplied
[Thu 03/18/2021 08:43:29] - Setting Max LBA Count for 4096 Plus DIFF Sectors with value : 0
[Thu 03/18/2021 08:43:29] - Setting Max LBA Count for 4096 Sectors with value : 0
[Thu 03/18/2021 08:43:29] - Setting Max LBA Count for 512B Plus DIFF Sectors with value : 0
[Thu 03/18/2021 08:43:29] - Setting Max LBA Count for 512B Sectors with value : 0
[Thu 03/18/2021 08:43:29] - Setting Max LBA Count for 520B Sectors with value : 0
[Thu 03/18/2021 08:43:29] - Setting Max LBA Count for 524B Sectors with value : 0
[Thu 03/18/2021 08:43:29] - Setting Max LBA Count for 528B Sectors with value : 0
[Thu 03/18/2021 08:43:29] - Setting Power Management Version with value : 2
[Thu 03/18/2021 08:43:29] - Total of 1 valid MaxLBA settings were setup to be written to the drive.
[Thu 03/18/2021 08:43:31] - Successfully applied the remaining ConfigUniqueDrive settings...
[Thu 03/18/2021 08:43:31] - Issuing an IdleImmediate command to the drive...
[Thu 03/18/2021 08:43:31] - Not an Enterprise drive,so, continuing without setting master password..
[Thu 03/18/2021 08:43:31] - End of Genesis manufacturing log.
[Thu 03/18/2021 08:43:31] - Exiting...
