查看: 3690|回复: 12
[影音] 出售无法启动的小爱音响一个,只有一个哦!
发表于 2021-7-3 11:48:49 | 显示全部楼层 |阅读模式 IP属地:山东青岛
收了一台小爱音响,通电没有任何反应,按照网上的教程接TTL查看,TTL记录如下,好像是系统坏了,会修的拿去吧,售出不退不换,只是拆开接了TTL查看而已,没任何修理!只有裸机一台,无配件无电源,自己配12V1a电源就可以。
淘宝地址:https://item.taobao.com/item.htm?spm=a1z10.1-c.w4004-12683114723.3.c063197co2DyrM&id=650324827033
TTL信息如下:
AXG:BL1:d95c53:a4926f;FEAT:E0DC318C:2000;POC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 23347
BL2 Built : 18:30:39, Aug 28 2018. axg g56303a2-dirty - liang.yang@droid11-sz
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 6
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 2c 06 52 35 10 5a 26 00 4d 3b 16 60 00 00 00 00 00 00 00 00 00 00 00 00 625   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
page0 page0->bbt:
0000000000000000000000000000000000000000000000000000000000000000
page0 bbt:
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x42
3c a9 31 97 da 66 81 34 97 64 39 4c bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014619 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Nov 12 2018 - 08:00:45), Build: jenkins-Mico_s12a_ota_publish-275
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89590
NAND:  nand id: 0x98 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: 98 f1 80 15 f2 16
NAND device: Manufacturer ID: 0x98, Chip ID: 0x98 (Toshiba A revision NAND 1Gib TC58BVG0S3HTA00 )
oob avail size 6
Creating 1 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000000000-0x000000200000 : "bootloader"
A revision NAND 1Gib TC58BVG0S3HTA00  initialized ok
nand id: 0x98 0xf1
PLANE change!
aml_nand_init :oobmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=1
aml_nand_scan_rsv_info 1254
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=25, ec=10, phy_page_addr=0, timestamp=22
nenv free list:
blockN=24, ec=10, dirty_flag=1
blockN=26, ec=-1, dirty_flag=0
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 330000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=33, ec=0, phy_page_addr=0, timestamp=2
nkey free list:
blockN=32, ec=0, dirty_flag=1
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
nkey valid addr: 420000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=40, ec=0, phy_page_addr=0, timestamp=1
ndtb free list:
blockN=41, ec=-1, dirty_flag=0
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
ndtb valid addr: 500000
tpl: off 8388608, size 8388608
NAND bbt detect factory Bad block at 6000000
Creating 6 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001800000 : "boot0"
0x000001800000-0x000002000000 : "boot1"
0x000002000000-0x000004000000 : "system0"
0x000004000000-0x000006000000 : "system1"
0x000006000000-0x000008000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 330000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 500000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      GZIP format, decompress...
就到这里就不进行了!
发表于 2021-7-3 11:50:30 | 显示全部楼层 IP属地:湖北黄冈
TTL搞不定就要吹芯片了,这个难度太大了呀,一失败40大元就没有了
 楼主| 发表于 2021-7-3 11:50:36 | 显示全部楼层 IP属地:山东青岛
淘宝地址:https://item.taobao.com/item.htm ... amp;id=650324827033
需要直接拍,今天发货!
 楼主| 发表于 2021-7-3 11:56:16 | 显示全部楼层 IP属地:山东青岛
啥意思,好像可以接usb重装系统,我不太懂,没玩过这个!
 楼主| 发表于 2021-7-3 11:57:07 | 显示全部楼层 IP属地:山东青岛
外壳挺新的,感觉应该是原用户升级失败造成的!
发表于 2021-7-3 13:12:01 | 显示全部楼层 IP属地:
之前收个好的小度才50,这个坏的还要40?
发表于 2021-7-3 13:58:22 | 显示全部楼层 IP属地:湖南
系统区有坏块了
 楼主| 发表于 2021-7-3 14:40:51 | 显示全部楼层 IP属地:山东青岛
贵了?那就30元吧!
发表于 2021-7-3 15:06:09 | 显示全部楼层 IP属地:甘肃兰州
漫步者音箱,R201TII,30元,运费10元。保证音质!无任何故障!带音频线!千牛或者旺旺:guoxinping1949
闲鱼交易。
还有一套X101V,R201T。都是30元
发表于 2021-7-4 06:41:04 来自手机浏览器 | 显示全部楼层 IP属地:河南南阳
闲 ...
你好打包能优惠些吗?非偏远,或者发物流也可以
发表于 2021-7-4 08:12:54 | 显示全部楼层 IP属地:甘肃兰州
可以的。请直接和我联系。
音箱我还多着呢,欢迎其他网页也联系我!
发表于 2021-7-4 08:26:44 来自手机浏览器 | 显示全部楼层 IP属地:重庆
运气好,重引导系统、运气差,字库坏
发表于 2021-7-4 08:29:31 来自手机浏览器 | 显示全部楼层 IP属地:
不知道什么字库,配件贵不值得
GMT+8, 2025-7-20 16:14 , Processed in 0.686402 second(s), 11 queries , Redis On.
