是一款用了几年的金士顿企业级盘,结果前两天一次意外断电就掉盘了,系统只能识别为“sanforce 200026 0.0GB",没有盘符,金士顿的ssd管理工具也无法识别。
网上能找到的固件支持列表里都没有这款最后两位是“-AE”的,所以只能尝试用6.0.A的固件找了一个接近的芯片来尝试。
用的是本站大神做好的centos虚拟机,用usb硬盘盒连上去,但最后都会在校验flash的时候失败,命令行反馈如下(很长,麻烦帮忙看看):
[root@localhost SF_Genesis-v1.7]# ./SF_Genesis -PROCESS_SSD 60:0:0:0 /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/27331.12345.test.driveconfig 12345 www_123 log=/log/
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 04/16/2019 12:04:07] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 60:0:0:0
argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/27331.12345.test.driveconfig
argv[5]: 12345
argv[6]: www_123
argv[7]: log=/log/
[Tue 04/16/2019 12:04:07] - Instructing the operating system to purge any existing cached data for device: '60:0:0:0'
[Tue 04/16/2019 12:04:12] - Issuing a discovery command for device: '60:0:0:0'
[Tue 04/16/2019 12:04:18] - Discovery command completed...
[Tue 04/16/2019 12:04:18] - Waiting 5 seconds for the system to settle...
[Tue 04/16/2019 12:04:23] - Device designation string '60:0:0:0' is mapped to node '/dev/sg2'
[Tue 04/16/2019 12:04:23] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/27331.12345.test.driveconfig
Serial No. = 12345
World Wide Name = www_123
[Tue 04/16/2019 12:04:23] - Successfully received the IDENTIFY data from the drive...
[Tue 04/16/2019 12:04:23] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Tue 04/16/2019 12:04:23] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Tue 04/16/2019 12:04:23] - file /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/27331.12345.test.driveconfig Loaded successfully
[Tue 04/16/2019 12:04:32] - B01 Power Management configuration request detected
[Tue 04/16/2019 12:04:32] - B01 Power Management conforms to hardware version 0x0
[Tue 04/16/2019 12:04:32] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/27331.12345.test.driveconfig
[Tue 04/16/2019 12:04:32] - Extracted Config_ID: 1 (27331) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/27331.12345.test.driveconfig
[Tue 04/16/2019 12:04:32] - Extracted SerialOutputControl: 0
[Tue 04/16/2019 12:04:32] - Searching for flashware image for configuration 27331
[Tue 04/16/2019 12:04:32] - Manifest found for configuration 27331
[Tue 04/16/2019 12:04:32] - Flashware image extracted: 27331_fw_cl_mlc_Toshiba_64Gb_FT64G08UCT11D_2Q_2C_1D_S_PP_R01401_s512.vic
[Tue 04/16/2019 12:04:32] - Searching for manufacturing image for configuration 27331
[Tue 04/16/2019 12:04:32] - Manufacturing image extracted: 27331_mf_mlc_Toshiba_64Gb_FT64G08UCT11D_2Q_2C_1D_S_PP_R01401_s512.vic
[Tue 04/16/2019 12:04:32] - Proceeding in ROM mode, download feature 3...
[Tue 04/16/2019 12:04:33] - Successfully downloaded MFB to the drive...
[Tue 04/16/2019 12:04:33] - Waiting (5 sec) for the drive to settle...
[Tue 04/16/2019 12:04:38] - Successfully received the IDENTIFY data from the drive...
[Tue 04/16/2019 12:04:38] - Firmware revision reported to be: '60AABBM0'. This indicates MFB download was successful.
[Tue 04/16/2019 12:04:38] - Successfully enabled SMART capabilities...
[Tue 04/16/2019 12:04:40] - Successfully issued a diagnostic unlock...
[Tue 04/16/2019 12:04:41] - Performing the flash test of block 0 (0x0000)...
[Tue 04/16/2019 12:04:43] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 2
Chip Enabled Count: 2
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
Total Number of test results: 16
Number of failures: 16
Number of Passed with warnings: 0
No. Passed without warnings: 0
[Tue 04/16/2019 12:04:43] - End of Genesis manufacturing log.
[Tue 04/16/2019 12:04:43] - Exiting...
[Tue 04/16/2019 12:04:43] - Overall Result for Device: /dev/sg2 ****** FAIL ******
现在不知道咋弄了,有几个疑问:
1、是否一定要6.03的固件? 或者更高版本的固件,请告知哪里能下载,我真没找到,感谢
2、我这个硬盘盒是纽曼的usb3.0,每次接这个盘要几十秒才能识别新设备,是不是要换个20329主控的转接卡?(是否一定要20329D芯片呢,呵呵)
