查看: 3126|回复: 15
[硬件] Rock Pi 4B plus开箱和装系统
发表于 2021-10-12 22:11:45 | 显示全部楼层 |阅读模式
参与人数 2家元 +25 收起 理由
听雨亭 + 5
家睦 + 20
 楼主| 发表于 2021-10-12 22:15:16 | 显示全部楼层
OP1 是RK3399的高速版,据厂方说可以提高11%,Rock Pi 4B+是基于这格国产6核64位SOC处理器发布的SBC,下一个流行的树莓派?
试装了一个变种Linux ,颜值很高的开源系统,可以换皮。
发表于 2021-10-13 09:34:24 | 显示全部楼层
这个比树莓派4B还贵些,要是便宜还可能搞一个玩玩。
发表于 2021-10-13 09:58:30 | 显示全部楼层
瑞芯微rk3399
 楼主| 发表于 2021-10-14 09:51:43 | 显示全部楼层
对的,OP1,高速版RK3399。
发表于 2021-10-14 10:16:14 | 显示全部楼层
这个 热设计 和 NanoPi  系列 基本一致,至少比树莓派热设计 人性化一些 ……3399 性能也够快了……
https://wiki.radxa.com/Home
https://shop.allnetchina.cn/
发表于 2021-10-14 10:22:54 | 显示全部楼层
Model
ROCK PI 4 Model A
ROCK PI 4 Model B
ROCK PI 4 Model C
Processor
64bits hexa core processor
Rockchip RK3399
Dual Cortex-72, frequency 1.8GHz with qual Cortex-A53, frequency 1.4GHz
Mali T860MP4 gpu, support OpenGL ES 1.1/2.0/3.0/3.1/3.2, Vulkan 1.0, Open CL 1.1 1.2, DX11.
Memory
LPDDR4
64bit dual channel LPDDR4@3200Mb/s, 1GB/2GB/4GB optioal
Storage
eMMC module (Optional industrial compatible high performance eMMC module, 8GB/16GB/32GB/64GB/128GB available)
μSD card (μSD slot supports up to 128 GB μSD card)
M.2 SSD (M.2 connector supports up to 2T M2 NVME SSD)
Display
HDMI 2.0 up to 4k@60
MIPI DSI 2 lanes via FPC connector
HDMI and MIPI DSI can work at the same time, support mirror mode or extend mode.
DP up to 1440P@60
HDMI and DP can work at the same time.
Audio
3.5mm jack with mic
HD codec that supports up to 24-bit/96KHz audio.
Camera
MIPI CSI 2 lanes via FPC connector, support up to 800 MP camera.
Wireless
None802.11 ac wifi
Bluetooth 5.0
with on board antenna
USB
USB 3.0 OTG X1, hardware switch for host/device switch, upper one
USB 3.0 HOST X1, dedicated USB 3.0 channel, lower one
USB 2.0 HOST X2
Ethernet
GbE LANGbE LAN with Power over Ethernet (PoE) support
additional HAT is required for powering from PoE
IO
40-pin expansion header
2 x UART
2 x SPI bus
3 x I2C bus
1 x PCM/I2S
1 x SPDIF
2 x PWM
1 x ADC
6 x GPIO
2 x 5V DC power in
2 x 3.3V DC power in
Others
RTC
RTC battery connector for time backup(optional)
Power
USB PD, support USB Type C PD 2.0, 9V/2A, 12V/2A, 15V/2A, 20V/2A.
Qualcomm® Quick ChargeTM: Supports QC 3.0/2.0 adapter, 9V/2A, 12V/1.5A
Size
85mm x 54mm
 楼主| 发表于 2021-10-14 18:30:03 | 显示全部楼层
这格板相对性能指标配置,性价比还是很高的
三大亮点:
OP1,限量版,CPU 速度提升11%(比标准RK3399)
板载高速eMMC (128G)
预装Twister OS 系统(颜值高)
 楼主| 发表于 2021-10-14 18:31:19 | 显示全部楼层
 楼主| 发表于 2021-10-15 08:34:22 | 显示全部楼层
嗯,RK3399是Rockchip目前产品线中性能最高的芯片,在应用中具有高性能和可扩展性。芯片的硬件规格在行业中处于领先地位。
RK3399的CPU采用big.LITTLE核心架构,采用双核Cortex-A72大核+四核Cortex-A53小核结构。在整数,浮点数,内存,整体性能,功耗和核心面积方面都进行了重大改进。RK3399的GPU采用四核ARM的新一代高端图像处理器Mali-T860,集成了更多的带宽压缩技术(如智能叠加,ASTC和本地像素存储),并支持更多的图形和计算接口。总体性能比上一代提高了45%。
以下显示了RK3399的七大性能优势:
集成USB3.0 Type-C双端口,并支持Type-C显示端口的音频和视频输出。
双ISP具有800MPix / s的像素处理能力,支持双摄像头的同时数据输入和高级处理(例如3D和深度信息提取)。
MIPI / eDP接口支持2560×1600屏幕和双屏显示。
HDMI2.0接口和H.265 / H.264 / VP9 4K @ 60fps支持解码和显示高清视频。
PCI-e内置接口支持基于PCI-e的高速Wi-Fi和存储扩展。
支持8路数字麦克风阵列的输入。
为与Android,Linux和其他操作系统兼容的系统提供全面支持。
它具有强大的兼容性和扩展能力,可应用于VR,游戏机,平板电脑和其他多功能终端。
发表于 2021-10-15 13:22:08 | 显示全部楼层
使用工业版的RK3399K的比普通的快1丢丢原因是频率比普通的RK3399快1点,而且RK3399PRO才带NPU
RK3399的A53+A72已经是旧架构了,现在有点过气了
新出的rk3588使用 A76+A55 而且带有NPU对比RK3399强太多了
 楼主| 发表于 2021-10-17 09:44:35 | 显示全部楼层
RK3399的A53+ ...
RK3588是比前一款处理器强多了,不过出来不久,采用的板商不多,资源也不多,目前还不适合入手。
RK3588是瑞芯微推出的新一代旗舰级高端处理器,采用8nm工艺设计,搭载四核A76+四核A55的八核CPU和Arm高性能GPU,内置6T算力的NPU。具备强大的视觉处理能力,可支持结构光、TOF等多种快速人脸解锁方案;支持丰富的显示接口,高达8K显示处理能力;有强大的扩展性,支持PCIE3.0、SATA3.0、双TypeC/USB3.1等高速接口,可做AI算力、图像数据处理等扩展。应用于ARMPC、高端平板电脑、边缘计算服务器、虚拟现实、NVR、8K电视等方向。最重要是pci-e 和sata  usb3.1 这些io都完整齐备了,可以diy 高性能“派”,软路由都很ok。这款芯片值得期待。
RK3588 规格:
  • CPU-4个Cortex-A76和4个Cortex-A55内核,采用动态配置
  • GPU–ARM Mali “Odin” MP4 GPU
  • AI加速器 – 一个6 TOPS的3.0加速器(Neural Processing Unit)
  • VPU-支持8K@30视频编码以及8K@60视频解码
  • 内存 I/F – 采用LPDDR4x/LPDDR5控制器,最高可达 32GB内存
  • 存储-eMMC 5.1、SDIO、SATA 3.0(多路PCIe 2.0复用)
  • 视频输出
    • 双HDMI 2.1/eDP高达8Kp60或4Kp120
    • 高达 4Kp60的双显示端口
    • 双米皮 DSI 输出
    • 最多四个独立显示器
  • 相机-48M(2x 24M)ISP,支持HDR和3D NR;多摄像头输入
  • 音频–支持多MIC阵列
  • 网络–双千兆以太网接口
  • USB-2个USB 3.1TypeC接口,2个USB0接口
  • PCIe-4条PCIe 3.0和3路PCIe 2.0(与多路SATA复用)
  • 制造工艺–8nm LP
发表于 2021-10-17 10:26:00 | 显示全部楼层
RK3588是 ...
Rock 3A        採用RK3568定位中高端的板linux已將支持,且armbian也已經支持
https://github.com/armbian/build/blob/master/config/boards/rock-3a.csc
 楼主| 发表于 2021-10-17 20:54:54 | 显示全部楼层
https://github.com/armb ...
价格居然还比ROCK 4B+便宜,可惜目前只有4G版本的,期待8G的上架。
发表于 2021-10-19 19:06:09 | 显示全部楼层
RK3588板子要是能原厂支持安卓就好了,用来diy手机才好
发表于 2021-10-20 15:03:19 | 显示全部楼层
RK35xx 瑞芯微提供android 11的开发源代码 ,但基于22nm工艺满载功耗有10多w了
GMT+8, 2025-5-5 21:00 , Processed in 0.249600 second(s), 12 queries , Redis On.
