查看: 4267|回复: 7
星际蜗牛安装黑裙7.0.1,发现不能休眠了
发表于 2021-11-6 20:37:18 | 显示全部楼层 |阅读模式
之前整的黑裙6.2.1,前两天没忍住升级6.2.3出问题,被迫升级到7.0.1
好不容易保住数据,发现不能休眠了
休眠日志:
[ 1092.742589] ppid:7293(synoscgi), pid:19605(synoscgi), dirtied inode 87960 (oom_score_adj) on proc
[ 1102.776208] ppid:7293(synoscgi), pid:19605(SYNO.Entry.Sock), dirtied inode 91281 (current) on proc
[ 1107.804939] ppid:1(systemd), pid:19699(scemd), dirtied inode 19485 (syno_standby_syncing) on sysfs
[ 1107.806091] <redpill/smart_shim.c:684> Expected to copy HDIO_DRIVE_CMD header of 4 bytes from           (null) - it failed
[ 1107.806754] ppid:1(systemd), pid:19699(scemd), dirtied inode 19788 (syno_standby_syncing) on sysfs
[ 1107.807784] <redpill/smart_shim.c:684> Expected to copy HDIO_DRIVE_CMD header of 4 bytes from           (null) - it failed
[ 1107.808422] ppid:1(systemd), pid:19699(scemd), dirtied inode 20091 (syno_standby_syncing) on sysfs
[ 1107.809466] <redpill/smart_shim.c:684> Expected to copy HDIO_DRIVE_CMD header of 4 bytes from           (null) - it failed
[ 1107.810089] ppid:1(systemd), pid:19699(scemd), dirtied inode 20394 (syno_standby_syncing) on sysfs
[ 1107.810796] <redpill/smart_shim.c:684> Expected to copy HDIO_DRIVE_CMD header of 4 bytes from           (null) - it failed
[ 1108.192815] ppid:1(systemd), pid:19700(syslog-ng), dirtied inode 28362 (messages) on md0
[ 1108.193224] ppid:1(systemd), pid:19700(syslog-ng), dirtied inode 28362 (messages) on md0
[ 1108.193632] ppid:1(systemd), pid:19700(syslog-ng), dirtied inode 28362 (messages) on md0
[ 1108.194088] ppid:1(systemd), pid:19700(syslog-ng), dirtied inode 24317 (kern.log) on md0
[ 1108.194485] ppid:1(systemd), pid:19700(syslog-ng), dirtied inode 24317 (kern.log) on md0
[ 1108.194890] ppid:1(systemd), pid:19700(syslog-ng), dirtied inode 24317 (kern.log) on md0
[ 1109.775770] <redpill/override_symbol.c:250> Obtaining lock for <GetHwCapability+0x0/0x110 [apollolake_synobios]/ffffffffa065b490>
[ 1109.776342] <redpill/override_symbol.c:250> Writing original code to <ffffffffa065b490>
[ 1109.776730] <redpill/override_symbol.c:250> Released lock for <ffffffffa065b490>
[ 1109.777099] <redpill/override_symbol.c:221> Obtaining lock for <GetHwCapability+0x0/0x110 [apollolake_synobios]/ffffffffa065b490>
[ 1109.777659] <redpill/override_symbol.c:221> Writing trampoline code to <ffffffffa065b490>
[ 1109.778061] <redpill/override_symbol.c:221> Released lock for <ffffffffa065b490>
[ 1109.778421] <redpill/bios_hwcap_shim.c:65> proxying GetHwCapability(id=5)->support => real=0 [org_fout=0, ovs_fout=0]
[ 1109.929031] <redpill/pmu_shim.c:310> Got 1 bytes from PMU: reason=1 hex={2d} ascii="-"
[ 1110.079045] <redpill/pmu_shim.c:310> Got 1 bytes from PMU: reason=1 hex={37} ascii="7"
[ 1110.079437] <redpill/pmu_shim.c:239> Executing cmd OUT_STATUS_LED_OFF handler cmd_shim_noop+0x0/0x2d [redpill]
[ 1110.079919] <redpill/pmu_shim.c:45> vPMU received OUT_STATUS_LED_OFF using 1 bytes - NOOP
[ 1110.809188] ppid:1(systemd), pid:19699(scemd), dirtied inode 23016 (cpufreq) on sysfs
[ 1110.809974] ppid:1(systemd), pid:19699(scemd), dirtied inode 23017 (cpufreq) on sysfs
[ 1110.810429] ppid:1(systemd), pid:19699(scemd), dirtied inode 23018 (cpufreq) on sysfs
[ 1110.810888] ppid:1(systemd), pid:19699(scemd), dirtied inode 23019 (cpufreq) on sysfs
每次唤醒都出现这个
有没有大佬了解这个啊
附上 引导镜像
论坛限制8M
发表于 2021-11-25 16:11:13 | 显示全部楼层
我的升级后根本找不到ip
 楼主| 发表于 2021-12-1 19:42:32 | 显示全部楼层
cat_li 发表于 2021-11-25 16:11
我的升级后根本找不到ip
换引导了没?
发表于 2021-12-13 17:00:58 | 显示全部楼层
好贵,买不起啊。有没有免费的链接可以下载:、
发表于 2023-12-14 11:04:35 | 显示全部楼层
我从来没有休眠过,不在意了
发表于 2023-12-23 15:25:24 | 显示全部楼层
小白鼠逐渐多了起来。。帖子那么多怎么不看看呢?有升级了不休眠的,有找不到IP的,有引导出错的。还有直接丢盘的。。
发表于 2023-12-29 12:16:24 | 显示全部楼层
休眠对硬盘寿命应该是有负面影响的
发表于 2024-1-1 14:55:19 | 显示全部楼层
使用ARP引导,没有任何问题
GMT+8, 2025-5-1 23:01 , Processed in 0.124800 second(s), 11 queries , Redis On.
