[root@localhost SF_Genesis-v1.7]# ./SF_Genesis -PROCESS_SSD 66:0:0:0 /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33205.12345.king.driveconfig 12345 www_123 log=/log/
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 11/25/2021 17:26:22] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 66:0:0:0
argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33205.12345.king.driveconfig
argv[5]: 12345
argv[6]: www_123
argv[7]: log=/log/
[Thu 11/25/2021 17:26:22] - Instructing the operating system to purge any existing cached data for device: '66:0:0:0'
[Thu 11/25/2021 17:26:27] - Issuing a discovery command for device: '66:0:0:0'
[Thu 11/25/2021 17:26:32] - Discovery command completed...
[Thu 11/25/2021 17:26:32] - Waiting 5 seconds for the system to settle...
[Thu 11/25/2021 17:26:37] - Device designation string '66:0:0:0' is mapped to node '/dev/sg2'
[Thu 11/25/2021 17:26:37] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33205.12345.king.driveconfig
Serial No. = 12345
World Wide Name = www_123
[Thu 11/25/2021 17:26:37] - Successfully received the IDENTIFY data from the drive...
[Thu 11/25/2021 17:26:37] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Thu 11/25/2021 17:26:37] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Thu 11/25/2021 17:26:37] - file /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33205.12345.king.driveconfig Loaded successfully
[Thu 11/25/2021 17:26:37] - Warning: Unable to query diagnostics information to perform power management settings check
[Thu 11/25/2021 17:26:37] - B01 Power Management configuration request detected
[Thu 11/25/2021 17:26:37] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33205.12345.king.driveconfig
[Thu 11/25/2021 17:26:37] - Extracted Config_ID: 1 (33205) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33205.12345.king.driveconfig
[Thu 11/25/2021 17:26:37] - Extracted SerialOutputControl: 0
[Thu 11/25/2021 17:26:37] - Searching for flashware image for configuration 33205
[Thu 11/25/2021 17:26:37] - Manifest found for configuration 33205
[Thu 11/25/2021 17:26:37] - Flashware image extracted: 33205_fw_cl_mlc_Micron_128Gb_33bit_FT16B08UCM1-3B_2Q_1C_1D_PP_R02795_s512.vic
[Thu 11/25/2021 17:26:37] - Searching for manufacturing image for configuration 33205
[Thu 11/25/2021 17:26:37] - Manufacturing image extracted: 33205_mf_mlc_Micron_128Gb_33bit_FT16B08UCM1-3B_2Q_1C_1D_PP_R02795_s512.vic
[Thu 11/25/2021 17:26:37] - Proceeding in non-ROM mode, Download feature 3...
[Thu 11/25/2021 17:26:44] - FATAL_ERROR: Could not download MFB to the drive...(0x12000005:SF_SG_HOST_ABORT_ERROR)
[Thu 11/25/2021 17:26:44] - End of Genesis manufacturing log.
[Thu 11/25/2021 17:26:44] - Exiting...
[Thu 11/25/2021 17:26:44] - Overall Result for Device: /dev/sg2 ****** FAIL ******
不能下载改如何处理?是否还有其他的错误
