查看: 2510|回复: 5
[慧荣] 慧荣(SiliconMotion) SM3267产品参数存档
发表于 2021-12-5 00:58:53 | 显示全部楼层 |阅读模式
2013年的主控了,看官方的态度貌似是不打算继续做了,找了很久才在一个专门提供PDF的地方找到,存档备用,版本区间差异应该不大。
SM3267
The SM3267 is a USB 3.0 single-channel flash drive
controller offering high performance and high
compatibility for SLC, MLC, TLC, and high-speed
Toggle and ONFI DDR NAND. For USB 3.0 Flash
Disk applications, this controller supports high
capacity of up to 4 NAND flash devices.
The SM3267 delivers high data transfer rate, and
ensures data accuracy and reliability with the
powerful ECC engine which can overcome the
read/write disturbances on new generation NAND. By
integrating an embedded crystal and other
components, the controller can reduce customer
overall cost at a system level. The SM3267 is
available in 48-pin QFN green package with
manufacturing-ready turnkey solution.
Applications
 USB Flash Drive
 USB Solid State Disk
 Embedded Application
 High-Speed NAND Storage
Package
 48-pin QFN
 Lead-free and RoHS compliant
Key Features
 USB 3.0 SuperSpeed (5 Gbps) and USB High-
Speed Interface
- Compliant with USB 3.0 Specification Rev. 1.0
- Compliant with USB 2.0 Specification Rev. 2.0
- USB Mass Storage Class Specification Rev. 1.0
- USB Mass Storage Class Bulk-Only Transport
Protocol
- Supports USB 3.0 multi-level link power
management
 NAND Flash Support
- Single-channel flash interface
- Supports 2-way and 4-way interleave operation
- Configurable ECC engine
- Supports SLC/MLC/TLC with 4KB/8KB/16KB
page
- Supports Toggle/ONFI DDR NAND flash
- Supports 3.3V/1.8V NAND flash
- Supports Bad Column Management
 The crystal-less design offers lower BOM cost
 Integrates 5V to 3.3V/1.2V voltage regulators
 Supports Write Protect security function to
protect the data in USB Flash Disk
 Supports LED indicator to indicate the access
status
 Supports VID, PID, serial number, and vendor
information update
 Supports firmware In System Programming (ISP)
function for firmware upgrade
 Low power 1.2V core operation
 Supports the operating systems: Windows 8/7/
Vista/XP, Mac OS 10.x and above, and Linux
kernel 2.4 and above
 Supports Windows 8/7/Vista ReadyBoost function
发表于 2021-12-5 07:33:26 | 显示全部楼层
这个支持hcnd1那款slc,用了两年很稳定,不掉盘
发表于 2021-12-5 08:30:16 | 显示全部楼层
专门提供PDF的地方可以分享一下吗
 楼主| 发表于 2021-12-5 18:40:54 | 显示全部楼层
参与人数 1家元 +20 收起 理由
k1503 + 20 謝謝分享
发表于 2021-12-9 10:40:16 | 显示全部楼层
靠,点一下55m币没了
 楼主| 发表于 2021-12-9 19:16:24 | 显示全部楼层
kyui 发表于 2021-12-9 10:40
靠,点一下55m币没了
我在四楼有提供原先的地址啊= =
GMT+8, 2025-7-23 10:53 , Processed in 0.951601 second(s), 14 queries , Redis On.
