楼主 |
发表于 2022-4-7 08:22:10
显示全部楼层
不行呀还是出错,
Day: ( 7 \ 4 \ 2022) Time: ( 8:21:47) TesterNumber:1
[ConfigID]
ID=98 3A 94 93 76 51-7DDL
[SN Set]
SN_Set=1
SN_Type=0
SN_Len=12
SN_Start=000000000065
SN_End=999999999999
SN_Mask=############
[Other]
SATA_SSC_Enable=1
[General Info]
TestStationSel=3
TestStation=F1
WorkingNo=SAILFISH SDD
ModelName=SAILFISH SDD
SerialNum=000000000065
MaxCurrent=400
[Flash Info]
Flh_Type=MLC_16K
Flh_MakeCode=Toshiba
Flh_ID=98 3a 94 93 76 51
Flh_Capacity=131072
Flh_CapacitySel=13
Flh_Number=8
Flh_NumberSel=0
Flash Clock=200
Flash Interface=3
[Device Info]
SATASpeed=3
ControllerType=SSD-3111SB
ICFWVersion=SBFC01.2
3111SBISP_CodeVersion=C01.2
3111SBISP_MPBINCode=.\Bin\SBFC01.2.BIN
3111SBISP_RDTBINCode=.\Bin\SBSC01.1.BIN
SSD Size=2.5"
[Options]
DDRSize=32
SetSSDSize=120
Enable_Set_Custom_SMART_Temperature=1
Set_Custom_SMART_Temperature=42
Smart_Table=0
EnableSmartC3=1
SLCPoolSizeSel=1
SLCPoolSize=0
Disable_DIPM_Support=1
DEVSLP_Enable=1
Put_Thermal_Sensor=0
Skip_Check_RDDebugPage=1
PretestType=1
PMASetting=42035
[EraseAll]
Do_Erase_First=1
Type=09
[Log]
[ Success ] Modify InfoBlock OK.
[ Success ] AES VUC Process OK.
[ Info ] MP AP: V2.06_x01(China), MAC Address: , ISP FW: SBFC01.2.BIN, Station:F1T
[ Success ] Check Device State OK.
[ Success ] Check IO State OK- Total take 0.004 sec.
[ Success ] Check ICVer. OK.
ErrorID=0x04, ErrorInfo=0x3333
FailMapCh0=0x20, FailMapCh1=0x00
Fail CE: 0,1,4,5,8,9,12,13,CE0,CE1,CE4,CE5,CE8,CE9,CE12,CE13,
[ Fail ] Error Message : HW_SET_FLASH_OVERDRIVE_FAIL.
Error Code : I_D08
AP Command : [a1]-[8]-[e]-[13]-[1]-[0]-[0]-[0]-[a0]-[21]-[0]-[0]
OS LastError : [ 0 ]
ATA Reg:[0][1][0][0][0][50]
[ Error End ] Time: ( 8:21:47)
Fail Mapping : 0000000000000020 Fail CE: 5, |
