请教大家,我用了20329,1153短接了都不认盘,直连可以认盘,但在虚拟机下识别不到直连的盘,2281真不好玩
1153刷了个固件可以开了,但是有个盘怎么都开不了,报错如下,大家帮忙分析;
<?xml version = "1.0"?> <Genesis_Log> <Log_Body> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Overall Summary: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Start Time: Thu, 06/09/2022 @ 23:55:44 End Time: Thu, 06/09/2022 @ 23:56:11 OverallResult: FAIL ExitCode: (0x10090021:SF_GENESIS_EXPECTED_MEMORY_ID_ERROR) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Environment Settings: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Input Parameters: argv[1]: -PROCESS_SSD argv[2]: 22:0:0:0 argv[3]: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp argv[4]: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig argv[5]: 50026B7228012921 argv[6]: 5896872 argv[7]: LOG=/root/Desktop/ssd/log/50026B7228012921_localhost.localdomain_DATETIMESTAMP_22.0.0.0_PROCESS_SSD_RESULT.log Log File: /root/Desktop/ssd/log/50026B7228012921_localhost.localdomain_DATETIMESTAMP_22.0.0.0_PROCESS_SSD_RESULT.log Hostname: localhost.localdomain Host IP Address: 127.0.0.1 Port Number: 1 DeviceName: /dev/sg1 SF_Genesis Version: v1.7.0.01020130612-fc14-32bit SF_Core Library Version: v1.7.1.20130612-fc14-32bit SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Post Processing Device Information: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ WWN OUI: UNKNOWN WWN UniqueID: UNKNOWN Serial No.: UNKNOWN Model No.: UNKNOWN Firmware Revision: UNKNOWN ROM Revision: UNKNOWN NAND Page Size: UNKNOWN Number Of Chip Enable: UNKNOWN Logical Sectors: UNKNOWN NAND ID: UNKNOWN Flash Manufacturer: UNKNOWN Flash Device: UNKNOWN ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit SF_Core Library: v1.7.1.20130612-fc14-32bit Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [Thu 06/09/2022 23:55:44] - SF_Genesis has been invoked with the following parameters: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ argv[1]: -PROCESS_SSD argv[2]: 22:0:0:0 argv[3]: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp argv[4]: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig argv[5]: 50026B7228012921 argv[6]: 5896872 argv[7]: LOG=/root/Desktop/ssd/log/50026B7228012921_localhost.localdomain_DATETIMESTAMP_22.0.0.0_PROCESS_SSD_RESULT.log ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [Thu 06/09/2022 23:55:44] - Instructing the operating system to purge any existing cached data for device: '22:0:0:0' [Thu 06/09/2022 23:55:49] - Issuing a discovery command for device: '22:0:0:0' [Thu 06/09/2022 23:55:54] - Discovery command completed... [Thu 06/09/2022 23:55:54] - Waiting 5 seconds for the system to settle... [Thu 06/09/2022 23:55:59] - Device designation string '22:0:0:0' is mapped to node '/dev/sg1' [Thu 06/09/2022 23:55:59] - Proceeding to process SSD device with the following parameters: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ DeviceName = /dev/sg1 MFP Package Filename = /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp Configuration File = /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig Serial No. = 50026B7228012921 World Wide Name = 5896872 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [Thu 06/09/2022 23:56:00] - Successfully received the IDENTIFY data from the drive... [Thu 06/09/2022 23:56:00] - Validating Manufacturing Firmware Package: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp [Thu 06/09/2022 23:56:00] - Successfully opened the package: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp [Thu 06/09/2022 23:56:00] - File : /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig in processing ... [Thu 06/09/2022 23:56:00] - file /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig Loaded successfully [Thu 06/09/2022 23:56:00] - Warning: Unable to query diagnostics information to perform power management settings check [Thu 06/09/2022 23:56:00] - B01 Power Management configuration request detected [Thu 06/09/2022 23:56:00] - Successfully extracted *.DriveConfig file: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig [Thu 06/09/2022 23:56:00] - Extracted Config_ID: 1 (27098) in DriveConfig file: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig [Thu 06/09/2022 23:56:00] - Extracted SerialOutputControl: 0 [Thu 06/09/2022 23:56:00] - Searching for flashware image for configuration 27098 [Thu 06/09/2022 23:56:00] - Manifest found for configuration 27098 [Thu 06/09/2022 23:56:00] - Flashware image extracted: 27098_fw_cl_mlc_Toshiba_64Gb_TC58NVG6D2HTA00_2Q_1C_1D_PP_R01109_s512.vic [Thu 06/09/2022 23:56:00] - Searching for manufacturing image for configuration 27098 [Thu 06/09/2022 23:56:00] - Manifest found for configuration 27098 [Thu 06/09/2022 23:56:00] - Manufacturing image extracted: 27098_mf_mlc_Toshiba_64Gb_TC58NVG6D2HTA00_2Q_1C_1D_PP_R01109_s512.vic [Thu 06/09/2022 23:56:00] - Proceeding in ROM mode, download feature 3... [Thu 06/09/2022 23:56:00] - Successfully downloaded MFB to the drive... [Thu 06/09/2022 23:56:00] - Waiting (5 sec) for the drive to settle... [Thu 06/09/2022 23:56:06] - Successfully received the IDENTIFY data from the drive... [Thu 06/09/2022 23:56:06] - Firmware revision reported to be: '60AABBM0'. This indicates MFB download was successful. [Thu 06/09/2022 23:56:06] - Successfully enabled SMART capabilities... [Thu 06/09/2022 23:56:08] - Successfully issued a diagnostic unlock... [Thu 06/09/2022 23:56:09] - Performing the flash test of block 0 (0x0000)... [Thu 06/09/2022 23:56:11] - Flash Test Results: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ----------------------------------------------------------------------------- Flash Test Parameters: ----------------------------------------------------------------------------- Block Count: 0 Page Count: 1 Bus Count: 2 Chip Enabled Count: 1 Die Count: 1 Lane Count: 4 Plane Count: 2 ----------------------------------------------------------------------------- Results Notes: ----------------------- N1 - At least one page tested and passed with no bit errors. N2 - No test data available. Test may have aborted, or failed during the testing. N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power. N4 - At least one erased page tested had bit error rate greater than half the correction power. N5 - Walking zeros test failed. N6 - Walking ones test failed. N7 - Block contained factory bad block markings and testing was skipped. N8 - At least one page tested and had bit error rate greater than the correction power on plane 0. N9 - Block in plane 0 was marked as a factory bad block. N10 - At least one page tested and had bit error rate greater than the correction power on plane 1. N11 - Block in plane 1 was marked as a factory bad block. ----------------------------------------------------------------------------- +------+------+------+------+--------+--------------------------------------------+---------+ | Bus | CE | Die | Lane | Value | Result Notes | Overall | +------+------+------+------+--------+--------------------------------------------+---------+ | 0 | 0 | 0 | 0 | 0x0380 | N7,N9,N11 | WARNING | +------+------+------+------+--------+--------------------------------------------+---------+ | 0 | 0 | 0 | 1 | 0x0380 | N7,N9,N11 | WARNING | +------+------+------+------+--------+--------------------------------------------+---------+ | 0 | 0 | 0 | 2 | 0x0380 | N7,N9,N11 | WARNING | +------+------+------+------+--------+--------------------------------------------+---------+ | 0 | 0 | 0 | 3 | 0x0380 | N7,N9,N11 | WARNING | +------+------+------+------+--------+--------------------------------------------+---------+ | 1 | 0 | 0 | 0 | 0x0380 | N7,N9,N11 | WARNING | +------+------+------+------+--------+--------------------------------------------+---------+ | 1 | 0 | 0 | 1 | 0x0380 | N7,N9,N11 | WARNING | +------+------+------+------+--------+--------------------------------------------+---------+ | 1 | 0 | 0 | 2 | 0x0001 | N1 | PASS | +------+------+------+------+--------+--------------------------------------------+---------+ | 1 | 0 | 0 | 3 | 0x0001 | N1 | PASS | +------+------+------+------+--------+--------------------------------------------+---------+ ----------------------------------------------------------------------------- Total Number of test results: 8 Number of failures: 0 Number of Passed with warnings: 6 No. Passed without warnings: 2 ----------------------------------------------------------------------------- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [Thu 06/09/2022 23:56:11] - FATAL_ERROR: The ExpectedMemoryID return by the drive is invalid... (0x10090021:SF_GENESIS_EXPECTED_MEMORY_ID_ERROR) [Thu 06/09/2022 23:56:11] - End of Genesis manufacturing log. [Thu 06/09/2022 23:56:11] - Exiting... </Log_Body> <Overall_Summary> <Start_Time> Thu, 06/09/2022 @ 23:55:44 </Start_Time> <End_Time> Thu, 06/09/2022 @ 23:56:11 </End_Time> <Overall_Result> FAIL </Overall_Result> <Exit_Code> (0x10090021:SF_GENESIS_EXPECTED_MEMORY_ID_ERROR) </Exit_Code> </Overall_Summary> <Environment_Settings> <Input_Parameters> argv[1]: -PROCESS_SSD argv[2]: 22:0:0:0 argv[3]: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp argv[4]: /root/Desktop/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/27098.0.test.edriveconfig argv[5]: 50026B7228012921 argv[6]: 5896872 argv[7]: LOG=/root/Desktop/ssd/log/50026B7228012921_localhost.localdomain_DATETIMESTAMP_22.0.0.0_PROCESS_SSD_RESULT.log </Input_Parameters> <Log_File> /root/Desktop/ssd/log/50026B7228012921_localhost.localdomain_DATETIMESTAMP_22.0.0.0_PROCESS_SSD_RESULT.log </Log_File> <Hostname> localhost.localdomain </Hostname> <Host_IP_Address> 127.0.0.1 </Host_IP_Address> <Port_Number> 1 </Port_Number> <Device_Name> /dev/sg1 </Device_Name> <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version> <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version> <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information> </Environment_Settings> <Post_Processing_Device_Info> <WWN_OUI> UNKNOWN </WWN_OUI> <WWN_UniqueID> UNKNOWN </WWN_UniqueID> <Serial_Number> UNKNOWN </Serial_Number> <Model_Number> UNKNOWN </Model_Number> <Firmware_Revision> UNKNOWN </Firmware_Revision> <ROM_Revision> UNKNOWN </ROM_Revision> <NAND_Page_Size> UNKNOWN </NAND_Page_Size> <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable> <Logical_Sectors> UNKNOWN </Logical_Sectors> <NAND_ID> UNKNOWN </NAND_ID> <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer> <Flash_Device> UNKNOWN </Flash_Device> </Post_Processing_Device_Info> </Genesis_Log> [Thu 06/09/2022 23:56:11] - Overall Result for Device: /dev/sg1 ****** FAIL ******
