发表于 2022-11-13 22:31:49
显示全部楼层
应该是激光笔,控制播放ppt的。这个U盘应该是接收器和驱动程序,插电脑上这遥控才起作用.网上搜到的资料
Keyspan PR-PRO3 Overview
[size=1.125]The Presentation Remote Pro from Keyspan is designed to provide full control over your PowerPoint or Keynote presentations. The built-in laser pointer and mouse control make this device a perfect choice for any presenter. This RF controller transmits signals up to 100 feet away from the USB receiver, and its plug-and-play functionality means that there is no software to install. The remote connects to your computer via the standard USB interface and is compatible with both Macintosh and Windows computers.
[size=1.5]Easy to Use
Plug-and-play functionality means that there is no software to install; just plug the receiver into an available USB port in your PC or Mac, and you will be ready to give a presentation with the remote.
[size=1.5]RF functionality
The sleek RF remote transmits signals up to 100 feet away from the computer. You won't have to worry about line of sight due to the RF interface, so you can have a large degree of freedom when giving your presentations.
[size=1.5]Cross Platform Compatibility
The remote works on both Macintosh and Windows computers. This allows you to more easily control your presentations regardless of the operating platform you use.
[size=1.5]Mouse Control and Laser Pointer
The built-in 2-button mouse control makes navigating through your presentation a breeze. This remote also features a laser pointer for convenient and accurate pointing.
