查看: 867|回复: 1
[SandForce] sf2281用1153e开卡报错
发表于 2023-2-28 10:05:32 | 显示全部楼层 |阅读模式
搞了个ocz的固态主控sf2281,颗粒id是2c88044ba900,开卡报错
Starting command:[/root/Desktop/sf2281/SF_Genesis-v1.7/SF_Genesis -PROCESS_SSD 3:0:0:0 "/root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp" "/root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/toshiba/22785.12345.MLC-SF-WHL-PT.driveconfig" 000000000000 000000000000  LOG="/root/Desktop/logs/000000000000_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log"   19:0:0:0]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 02/28/2023 08:52:38] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 3:0:0:0
                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/toshiba/22785.12345.MLC-SF-WHL-PT.driveconfig
                      argv[5]: 000000000000
                      argv[6]: 000000000000
                      argv[7]: LOG=/root/Desktop/logs/000000000000_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log
                      argv[8]: 19:0:0:0
[Tue 02/28/2023 08:52:38] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Tue 02/28/2023 08:52:43] - Issuing a discovery command for device: '3:0:0:0'
[Tue 02/28/2023 08:52:49] - Discovery command completed...
[Tue 02/28/2023 08:52:49] - Waiting 5 seconds for the system to settle...
[Tue 02/28/2023 08:52:54] - Device designation string '3:0:0:0' is mapped to node '/dev/sg2'
[Tue 02/28/2023 08:52:54] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/toshiba/22785.12345.MLC-SF-WHL-PT.driveconfig
              Serial No. = 000000000000
         World Wide Name = 000000000000
[Tue 02/28/2023 08:52:54] - Successfully received the IDENTIFY data from the drive...
[Tue 02/28/2023 08:52:54] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Tue 02/28/2023 08:52:54] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Tue 02/28/2023 08:52:54] - file  /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/toshiba/22785.12345.MLC-SF-WHL-PT.driveconfig Loaded successfully
[Tue 02/28/2023 08:52:54] - Warning:  Unable to query diagnostics information to perform power management settings check
[Tue 02/28/2023 08:52:54] - B01 Power Management configuration request detected
[Tue 02/28/2023 08:52:54] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/toshiba/22785.12345.MLC-SF-WHL-PT.driveconfig
[Tue 02/28/2023 08:52:54] - Extracted Config_ID: 1 (22785) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/toshiba/22785.12345.MLC-SF-WHL-PT.driveconfig
[Tue 02/28/2023 08:52:54] - Extracted SerialOutputControl: 0
[Tue 02/28/2023 08:52:54] - Searching for flashware image for configuration 22785
[Tue 02/28/2023 08:52:54] - Manifest found for configuration 22785
[Tue 02/28/2023 08:52:54] - Flashware image extracted: 22785_fw_cl_mlc_Micron_64Gb_MT29F64G08CBAABWP_2Q_1C_1D_PP_R00712_s512.vic
[Tue 02/28/2023 08:52:54] - Searching for manufacturing image for configuration 22785
[Tue 02/28/2023 08:52:54] - Manufacturing image extracted: 22785_mf_mlc_Micron_64Gb_MT29F64G08CBAABWP_2Q_1C_1D_PP_R00712_s512.vic
[Tue 02/28/2023 08:52:54] - Proceeding in ROM mode, download feature 3...
[Tue 02/28/2023 08:53:04] - FATAL_ERROR: Could not download MFB to the drive...(0x12000005:SF_SG_HOST_ABORT_ERROR)
[Tue 02/28/2023 08:53:04] - End of Genesis manufacturing log.
[Tue 02/28/2023 08:53:04] - Exiting...
[Tue 02/28/2023 08:53:04] - Overall Result for Device: /dev/sg2 ****** FAIL ******
Process exited with code 20
发表于 2023-2-28 20:40:25 | 显示全部楼层
信息太少了,上板子图吧,几贴,多大容量这些信息
GMT+8, 2025-5-13 22:55 , Processed in 0.156000 second(s), 8 queries , Redis On.
