查看: 1800|回复: 13
[SMI] 主控2258XT 颗粒是海力士3DV4 这个RDT表示有240个坏块?
发表于 2023-5-22 18:52:38 | 显示全部楼层 |阅读模式
是按照这个设置的 开卡后 接电跑的rdt
颗粒id
第二条红线标的是读取失败计数 这个是坏块数量?后边CH0 239 第一个颗粒里有239个坏块?是这么看吧 这个真心看不懂
哪一项设置错了容量居然少了一半 后面坏块数量不是90个么?
这个也显示的坏块数量90
<< Super Block count detail information >>
1 Super block = 4 * physical block
Total block Count = 1272
Pretest calculated minimum required block Count = 661
Initial bad block Count = 90
Good as bad block Count of initial bad block = 1
Available good block Count = 1183
Remaining spare block Count = 522
<< Total Bad Block numbers for each Channel and CE >>
     CH0   CH1   CH2   CH3   (All-Plane)
CE0  261   ---   002   ---
CE1  ---   ---   ---   ---
CE2  ---   ---   ---   ---
CE3  ---   ---   ---   ---
     CH0   CH1   CH2   CH3   (Plane-0)
CE0  088   ---   001   ---
CE1  ---   ---   ---   ---
CE2  ---   ---   ---   ---
CE3  ---   ---   ---   ---
     CH0   CH1   CH2   CH3   (Plane-1)
CE0  043   ---   001   ---
CE1  ---   ---   ---   ---
CE2  ---   ---   ---   ---
CE3  ---   ---   ---   ---
     CH0   CH1   CH2   CH3   (Plane-2)
CE0  089   ---   000   ---
CE1  ---   ---   ---   ---
CE2  ---   ---   ---   ---
CE3  ---   ---   ---   ---
     CH0   CH1   CH2   CH3   (Plane-3)
CE0  041   ---   000   ---
CE1  ---   ---   ---   ---
CE2  ---   ---   ---   ---
CE3  ---   ---   ---   ---
--- System block index ---
1st-Info [00] : CH0, Intlv0 (CE0-Die0), P0, Blk0
2nd-Info [01] : CH2, Intlv0 (CE0-Die0), P0, Blk0
3rd-Info [02] : CH0, Intlv0 (CE0-Die0), P1, Blk0
4th-Info [03] : CH2, Intlv0 (CE0-Die0), P1, Blk0
1st-ISP  [04] : CH0, Intlv0 (CE0-Die0), P2, Blk0
2nd-ISP  [05] : CH2, Intlv0 (CE0-Die0), P2, Blk0
3rd-ISP  [06] : CH0, Intlv0 (CE0-Die0), P3, Blk0
4th-ISP  [07] : CH2, Intlv0 (CE0-Die0), P3, Blk0
Index    [08] : CH0, Intlv0 (CE0-Die0), P0, Blk1
BadInfo  [0A] : CH0, Intlv0 (CE0-Die0), P1, Blk1
MPInfo   [0B] : CH2, Intlv0 (CE0-Die0), P1, Blk1
Log      [0C] : CH0, Intlv0 (CE0-Die0), P2, Blk1
发表于 2023-5-22 19:03:02 | 显示全部楼层
是240个,第一个通道的第一个CE就239个,不知道为啥这么多。
另外为什么开出来容量就一半,我猜,是不是因为CE不连续?
 楼主| 发表于 2023-5-22 19:07:41 | 显示全部楼层
另外为什么开出来容量就一半,我猜,是不是因 ...
ce不连续?还有这一说法? 要不在试一次?pretest还是选2 在试一次?
发表于 2023-5-22 19:12:04 | 显示全部楼层
不对,好像不是,别管我刚刚说的,今天没睡好觉脑子不太清醒坏块是对的,为啥只有一半容量等大神来解决吧
 楼主| 发表于 2023-5-22 19:12:38 | 显示全部楼层
又试了一次结果跟上边一样 为啥?
发表于 2023-5-22 19:51:29 | 显示全部楼层
读失败次数,不是坏块
 楼主| 发表于 2023-5-23 09:09:46 | 显示全部楼层
换了一个软件就没问题了
发表于 2023-5-23 09:15:04 | 显示全部楼层
可以手动容量的
发表于 2023-5-23 09:20:22 | 显示全部楼层
读取错误 ECC错误各是什么含义啊
 楼主| 发表于 2023-5-23 09:44:38 | 显示全部楼层
klrm 发表于 2023-5-23 09:15
可以手动容量的
手动设置容量的时候很少好像ps3111需要吧 别的都是自动模式
 楼主| 发表于 2023-5-23 09:45:04 | 显示全部楼层
testzhou 发表于 2023-5-23 09:20
读取错误 ECC错误各是什么含义啊
不知道啊  接触的这个还是少
发表于 2023-5-23 09:48:12 | 显示全部楼层
2258Xt肯定可以手动设置容量的
 楼主| 发表于 2023-5-23 09:50:36 | 显示全部楼层
klrm 发表于 2023-5-23 09:48
2258Xt肯定可以手动设置容量的
可以手动设置
发表于 2023-5-23 09:52:54 | 显示全部楼层
路过学习一下
GMT+8, 2025-7-25 15:45 , Processed in 0.202800 second(s), 10 queries , Redis On.
