发表于 2023-6-20 08:05:45
来自手机浏览器
显示全部楼层
Hard reset a tabletop model (Edge 500, 510, 5X0 [520 or 540], 6X0 [610, 620, 640, or 680] )
If the Edge is not connected to the Orchestrator, and the Local UI is not accessible, there is a final option to reset an Edge. For this method the user manually hard resets the Edge as described below using the reset button on the back of the Edge:
With the Edge powered on, insert a paperclip into the hole labeled Reset on the back of the edge,
Press and hold in the reset button with the paperclip until the front LED status light begins to flash blue. This may require holding the reset button for up to 30 seconds. The only way to know for certain the reset action was successful is if the front LED status light is flashing blue.
Once the front LED status light flashes blue, remove the paperclip and the Edge will reboot twice into full factory settings.
Note: this method can only hard reset the Edge, there is no method to manually soft reset/deactivate an Edge |
