查看: 2213|回复: 5
腾达AC8路由器成砖求编程器固件
发表于 2024-3-18 14:40:06 | 显示全部楼层 |阅读模式
腾达AC8路由器成砖求编程器固件
腾达tenda AC8 v4
硬件版本: V4.0
故障:没有无线信号;不能进入WEB界面;TTL不停重启无法进入。
发表于 2024-3-18 16:53:55 | 显示全部楼层
果照呢?
TTL信息呢?
发表于 2024-3-18 16:59:43 | 显示全部楼层
没有,就帮顶一下吧祝楼主好运
发表于 2024-3-18 19:57:02 | 显示全部楼层
没有,看看坛里高手问问有没有?
 楼主| 发表于 2024-3-24 20:05:52 | 显示全部楼层
Booting...
init_ram
DDR init OK
init ddr ok
DRAM Type: DDR2
        DRAM frequency: 533MHz
        DRAM Size: 64MB
JEDEC id 684015, EXT id 0x6840
found BH25D16
>>>>>No Flash Vendor support (0x00684015)<<<<<
use MXIC as flash vendor instead
BH25D16, size=2MB, erasesize=4KB, max_speed_hz=55000000Hz
auto_mode=0 addr_width=3 erase_opcode=0x00000020
Write PLL1=80c00042
=>CPU Wake-up interrupt happen! GISR=89000080
RTL8197F-VG boot release version:588 (Jan 13 2020-14:27:08) (999MHz)
Mac addr:b4-0f-3b-87-ca-d0
LAN WAN isolate config...
Lan pbmp:0x000000ef
Wan pbmp:0x000000f0
use Switch new descriptor
wait for upgrage
port[0] link:down
port[1] link:down
port[2] link:down
port[3] link:down
port[4] link:down
irq:0x00008080
Jump to image start:0x80700000...
decompressing kernel:
Uncompressing... done, booting the kernel.
done decompressing kernel.
start address: 0xa0000600
[cyg_net_init] Init: mbinit(0x00000000)
[cyg_net_init] Init: cyg_net_init_devs(0x00000000)
Init device 'rltk819x_eth0'
Init device 'rltk819x_eth1'
Init device 'rltk819x_eth7'
Init device 'rltk819x_peth0'
[peth0] added, mapping to [eth1]...
Init device 'rltk819x_eth4'
Init device 'rltk819x_eth3'
Init device 'rltk819x_eth2'
Init device 'rltk819x_wlan1'
[MACFM_software_init 297]wifi hal support Mac function = 0x8008
RFE TYPE =0
[pwlan0] added...
Init device 'rltk819x_wlan1-vxd'
RFE TYPE =0
Init device 'rltk819x_wlan1-va3'
RFE TYPE =0
Init device 'rltk819x_wlan1-va2'
RFE TYPE =0
Init device 'rltk819x_wlan1-va1'
RFE TYPE =0
Init device 'rltk819x_wlan1-va0'
RFE TYPE =0
Init device 'rltk819x_wlan0'
[MACFM_software_init 297]wifi hal support Mac function = 0x10ff
[pwlan0] added...
Init device 'rltk819x_wlan0-vxd'
Init device 'rltk819x_wlan0-va3'
Init device 'rltk819x_wlan0-va2'
Init device 'rltk819x_wlan0-va1'
Init device 'rltk819x_wlan0-va0'
Init device 'rltk819x_pwlan0'
[cyg_net_init] Init: loopattach(0x00000000)
[cyg_net_init] Init: ifinit(0x00000000)
[cyg_net_init] Init: domaininit(0x00000000)
[cyg_net_init] Init: cyg_net_add_domain(0x80471c1c)
New domain internet6 at 0x00000000
[cyg_net_init] Init: cyg_net_add_domain(0x80471358)
New domain internet at 0x00000000
IP packet filtering initialized, divert enabled, rule-based forwarding enabled, default to deny, logging disabled
Realtek FastPath:v1.03
[cyg_net_init] Init: cyg_net_add_domain(0x80471208)
New domain route at 0x00000000
[cyg_net_init] Init: call_route_init(0x00000000)
[cyg_net_init] Init: ip6_init2(0x00000000)
[cyg_net_init] Init: sysctl_register_all(0x00000000)
[cyg_net_init] Done
Creating Init Thread...
cpuload_calibration_value=10163771
Envram is initing! base_addr=0x1c000 size=0x3000
md5:7511afe1d127a5cc org:e1af1175cca527d1
Nvram is initing! base_addr=0x1f8000 size=0x7fff
Snvram is initing! base_addr=0x1f0000 size=0x7fff
md5:804da9f0961ca646 org:f0a94d8046a61c96
NVRAM start form MAIN block data
System start
Realtek GPIO init
Init GPIO in GPIO_APIV2
init gpio_id:35
init gpio_id:35
init gpio_id:36
this thread can be checked ! if thread stack overflow or soiled
------------main
tenda_ifconfig error
: Invalid argument
CLI> [MAIN->tapf_vlan_config->262]:vlan config ok!
bridge0: ifid: 02:e0:4c:ff:fe:f0:00:01
in6_ifattach_linklocal: failed to configure a link-local address on bridge0 (errno=22)
kbMrAiIdNg-e>1b:r _iifniidt:- >0827:8e]0::b4rc(:bfrfi:dfgee:0f)0 :i0n0i:t0 1o
n!i
6_ifattach_linklocal: failed to configure a link-local address on bridge1 (errno=22)
tMeAtIhN:- >ibfri_di:n ibt6-:>08f7:83]b::bfrf(:bfrei:d8g7e:1c)a :idn0i
  ok!
[MAIN->init_before_module_init_services->76]:init_before_module_init_services ok!
[DEBUG] [MSG->msg_init->37]:rc_msg init ok!
[llm] br_interfaces(1065) eth0 up ...
eth0: promiscuous mode enabled
[rc->rc_msg_2_tlv->108]:key = op,value = 3
[MSG->msg_send_msg_2_mbox->120]:center:00000106
[MSG->msg_send_msg_2_mbox->136]:send msg [op=3] success!
[TPI->tpi_lan_start->151]:start success!
re865x_ioctl:5069, set port 4 0M FULL
wlan: ifid: b6:0f:3b:ff:fe:87:ca:d1
chip_version=0x100f,WlanSupportAbility = 0x0
test 0x81cd4c00,0x30,0x1cd4e80,0x0,
test 0x81cd4c80,0x30,0x1cd4ec0,0x0,
test 0x81cd4d00,0x30,0x1cd4f00,0x0,
test 0x81cd4d80,0x30,0x1cd4f40,0x0,
test 0x81cd4e00,0x30,0x1cd4f80,0x0,
[97G] RFE type 0 PHY paratemters: DEFAULT
clock 40MHz
InitMACTRX OK
InitMACProtocolHandler OK
InitMACSchedulerHandler OK
InitMACWMACHandler OK
InitMACSysyemCfgHandler OK
InitMACFunctionHandler OK
[Warning] is_fcs_mode_enable=NULL
--- STA STEERING INIT ---
LED2SV & LED1SV ctrl fem
steer_update_bss_info: isdown(0)
steer_update_bss_info: isdown(1)
clock 40MHz
InitMACTRX OK
wlan1: promiscuous mode enabled
sTPI->wtlpain_:w iiffii_do:p ebr6a:t0ofr:-3>b1:5f4f8:]f:es:t8o7p: csau:cdc5e
isc!h
p_version=0x2001,WlanSupportAbility = 0x3
clock 40MHz
InitPON OK!!!
>>SetBeaconDownload88XX
[GetHwReg88XX][PHY_REG_PG_8812Fmp_Type0]
[set_8812F_trx_regs] +++
sta steer cmd:count = 1, 0
sta steer cmd:count = 17, 2,rssi_lmt_2g,-55
sta steer cmd:count = 17, 2,rssi_lmt_5g,-76
sta steer cmd:count = 17, 2,pri_rssi_5g,-64
sta steer cmd:count = 17, 2,pri_rssi_2g,-74
sta steer cmd:count = 18, 2,sta_lmt_flow,100
sta steer cmd:count = 18, 2,sta_balance_en,1
sta steer cmd:count = 19, 2,sta_lmt_num_5g,16
wlan0: promiscuous mode enabled
pTPI-i>ntiptiW_ewbisf:i _loapneirpa=t[o1r9-2>.1156488.]0:.s1t]o
- s-u-c-c-e-s-s-!-
--w-lianni0t W e b s -c-l-e-a-r-_-a-c-l-_-t-a2b7l0e-:-0- - -
-w-l-a-n-1
     clear_acl_table:0
wlan0     fflush_acl_list:0
wlan1     fflush_acl_list:0
func:ipnat_init i = 0
[TPI->tpi_firewall_start->239]:start success!
[TPI->tpi_http_start->145]:http start success!
[TPI->tpi_upnp_start->107]:start success!
osl_open_udp_socket: bind failed: Can't assign requested address
[TPI->tpi_dnsmasq_start->75]:start success!
[TPI->tpi_sntp_start->82]:start success!
[TPI->tpi_dhcp_server_start->330]:start success!
[TPI->tpi_wan_surf_check_start->588]:start success!
[TPI->tpi_wan_mode_check_start->359]:start success!
[TPI->tpi_reboot_check_start->469]:start success!
[ERROR] [TPI->tpi_wifi_switch_sched_update_info->67]:schedule count[ 0 ] wrong
iw_init,1094,ifname2G:wlan1,ifn[atmpei5_Gi:gwmlpa_ni0n
rtb]r[u1t2e6_]f[olrucmei_naatitsa]c kn_omtihtiingga ttioo nd oT.h
e
Booting...
init_ram
DDR init OK
init ddr ok
DRAM Type: DDR2
        DRAM Size: 64MB
found BH25D16
Write PLL1=80c00042
Reboot Result from Watchdog Timeout!
Lan pbmp:0x000000ef
Wan pbmp:0x000000f0
wait for upgrage
port[0] link:down
port[1] link:down
port[2] link:down
port[3] link:down
port[4] link:down
irq:0x00008080
RFE TYPE =0
[pwlan0] added...
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
[pwlan0] added...
[cyg_net_init] Done
cpuload_calibration_value=10166648
System start
Realtek GPIO init
init gpio_id:35
init gpio_id:35
init gpio_id:36
------------main
: Invalid argument
n!i
  ok!
clock 40MHz
InitMACTRX OK
clock 40MHz
InitMACTRX OK
isc!h
clock 40MHz
InitPON OK!!!
- s-u-c-c-e-s-s-!-
-w-l-a-n-1
     clear_acl_table:0
lERROR] [TPI->tpi_wifi_switch_sched_update_info->67]:sched[utlpei _ciogumnpt_[i n0i t]] [w1r2o6n]g[
luimwi_nianiist], 1n0o9t4h,iinfgn atmoe 2dGo:.w
an1,ifname5G:wlan0
brute_force_attack_mitigation ThresHold[10]
WiFi Simple Config v2.14-wps2.0 (2020.08.21-00:05+0000).
[TPI->tpi_create_wps_thread->276]:start success!
[TPI->tpi_wps_iw_start->320]:start success!
[ERROR] [TPI->tpi_ddns_start->105]:the mib is off, connot start!
.....ucloud.............do......option....
[TPI->tpi_ucloud_star--------- [Idle Thread] get exception !! ---------
ptr:0x806356d0 base 0x80635198 size:2048
limit:0x80635998
--------- map symbol only ---------
updated stack ptr from R29 :0x806358f8
[<802361cc>] [<8023640c>] [<80470000>] [<11110011>] [<11110012>] [<11110013>] [<11110014>] [<80630000>]
[<11110016>] [<80225904>] [<1111001a>] [<1111001b>] [<1111001c>] [<80635960>] [<80635960>] [<80226408>]
[<00000000>] [<00000000>] [<deadbeef>] [<00000001>] [<806350a0>] [<80226b64>] [<deadbeef>] [<deadbeef>]
[<deadbeef>] [<deadbeef>] [<11110010>] [<80226b38>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
[<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
Exception --------------------------------------------------------------
  Type: TLB miss (Load or IFetch)
  Data Regs:
    R0    00000000    R8    80637ED0    R16   80630000    R24   802263E8
    R1    80000000    R9    10000401    R17   11110011    R25   8012E3DC
    R2    00000000    R10   802C3AA4    R18   11110012    R26   00000000
    R3    00000000    R11   7FFFFFFF    R19   11110013    R27   00000000
    R4    040DD729    R12   00000030    R20   11110014    R28   8047D0A0
    R5    80635920    R13   00000000    R21   11110015    R29   806358F8
    R6    00000001    R14   DFC61CC0    R22   11110016    R30   80635960
    R7    00000000    R15   0036386F    R23   11110017    R31   8023640C
    HI    00000000    LO    00000001    SR    10000403    PC    802361CC
                      CAUSE 00000000    PRID  00019385    BADVR 040DD729
          zero      at       v0       v1
$00   : 00000000 80000000 00000000 00000000
           a0       a1       a2       a3
$04   : 040dd729 80635920 00000001 00000000
           t0       t1       t2       t3
$08   : 80637ed0 10000401 802c3aa4 7fffffff
           t4       t5       t6       t7
$12   : 00000030 00000000 dfc61cc0 0036386f
           s0       s1       s2       s3
$16   : 80630000 11110011 11110012 11110013
           s4       s5       s6       s7
$20   : 11110014 11110015 11110016 11110017
           t8       t9       k0       k1
$24   : 802263e8 8012e3dc
           gp       sp       fp       ra
$28   : 8047d0a0 806358f8 80635960 8023640c
Hi    : 00000000
Lo    : 00000001
epc   : 802361cc
ra    : 8023640c
Status: 10000403    KERNEL EXL IE
Cause : 40000008
BadVA : 040dd729
PrId  : 00019385
Stack : 80470000 11110011 11110012 11110013 11110014 80630000 11110016 80225904
        1111001a 1111001b 1111001c 80635960 80635960 80226408 00000000 00000000
        deadbeef 00000001 806350a0 80226b64 deadbeef deadbeef deadbeef deadbeef
        11110010 80226b38 deadbeef deadbeef deadbeef deadbeef deadbeef deadbeef
        deadbeef deadbeef deadbeef deadbeef deadbeef deadbeef deadbeef deadbeef
Call stack:
SP: 0x806358f8, RA Offset: **, Ret Address: 0x802361cc, Func Address: 0x802361c0
SP: 0x806358f8, RA Offset: 28, Ret Address: 0x8023640c, Func Address: 0x802363fc
SP: 0x80635918, RA Offset: 20, Ret Address: 0x80225904, Func Address: 0x802258f4
SP: 0x80635930, RA Offset: 20, Ret Address: 0x80226408, Func Address: 0x802263e8
SP: 0x80635948, RA Offset: 20, Ret Address: 0x80226b64, Func Address: 0x80226b38
Code: 27bdffe8  afb00014  240c0030 <80820000> 2409ffdf  240d0058  240b0061  240a0041  240e002e
limit:0x80635998
[<11110016>] [<00000020>] [<00000030>] [<00000000>] [<806357a8>] [<00000008>] [<806357c8>] [<802c5d94>]
[<00000008>] [<11110015>] [<11110016>] [<8000c36c>] [<deadbeef>] [<0000000a>] [<00000030>] [<00000000>]
[<802361cc>] [<00000017>] [<11110017>] [<0000001f>] [<8023640c>] [<80630000>] [<806357a8>] [<11110011>]
[<11110012>] [<11110013>] [<11110014>] [<80226e2c>] [<deadbeef>] [<80635778>] [<80635960>] [<80227bac>]
[<deadbeef>] [<80227018>] [<deadbeef>] [<10000400>] [<80227bac>] [<deadbeef>] [<deadbeef>] [<8021c418>]
[<deadbeef>] [<80227c50>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<80000940>] [<806357e0>] [<00000024>]
[<00000003>] [<11110013>] [<11110014>] [<11110015>] [<11110016>] [<802271e8>] [<00000000>] [<80000000>]
[<00000000>] [<00000000>] [<040dd729>] [<80635920>] [<00000001>] [<00000000>] [<80637ed0>] [<10000401>]
[<802c3aa4>] [<7fffffff>] [<00000030>] [<00000000>] [<dfc61cc0>] [<0036386f>] [<80630000>] [<11110011>]
[<11110012>] [<11110013>] [<11110014>] [<11110015>] [<11110016>] [<11110017>] [<802263e8>] [<8012e3dc>]
[<00000000>] [<00000000>] [<8047d0a0>] [<806358f8>] [<80635960>] [<8023640c>] [<00000000>] [<00000001>]
[<00000008>] [<10000403>] [<802361cc>] [<00000000>] [<40000008>] [<040dd729>] [<00019385>] [<0322838c>]
[<8047d0a0>] [<80635930>] [<80635960>] [<80226408>] [<00000000>] [<00000001>] [<00000000>] [<10000403>]
[<80226408>] [<00000000>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
[<11110000>] [<11110001>] [<11110002>] [<11110003>] [<806350a0>] [<11110005>] [<11110006>] [<11110007>]
[<11110008>] [<11110009>] [<1111000a>] [<1111000b>] [<1111000c>] [<1111000d>] [<1111000e>] [<1111000f>]
[<11110010>] [<11110011>] [<80470000>] [<11110011>] [<11110012>] [<11110013>] [<11110014>] [<80630000>]
Thread Idle Thread (tid: 1), CurPri: 31, SetPri: 31
Stack Base: 0x80635198, Size: 0x800, Used: 0x478
Resetting ...
intf ...
eth0 18 [18]
eth1 18 [18]
eth7 18 [18]
peth0 18 [18]
eth4 18 [18]
eth3 18 [18]
eth2 18 [18]
wlan1 18 [18]
wlan1-vxd0 18 [18]
wlan1-va3 18 [18]
wlan1-va2 18 [18]
wlan1-va1 18 [18]
wlan1-va0 18 [18]
wlan0 18 [18]
Error Flag: 0xffff0000
wlan0-vxd0 18 [18]
wlan0-va3 18 [18]
wlan0-va2 18 [18]
wlan0-va1 18 [18]
wlan0-va0 18 [18]
pwlan0 18 [18]
bridge1 18 [18]
test sta_steer_exit(849)
--- STA STEERING EXIT ---
Booting...
init_ram
DDR init OK
init ddr ok
DRAM Type: DDR2
        DRAM Size: 64MB
found BH25D16
Write PLL1=80c00042
Lan pbmp:0x000000ef
Wan pbmp:0x000000f0
wait for upgrage
port[0] link:down
port[1] link:down
port[2] link:down
port[3] link:down
port[4] link:down
irq:0x00008080
RFE TYPE =0
[pwlan0] added...
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
[pwlan0] added...
[cyg_net_init] Done
cpuload_calibration_value=10166652
System start
Realtek GPIO init
init gpio_id:35
init gpio_id:35
init gpio_id:36
------------main
: Invalid argument
n!i
  ok!
clock 40MHz
InitMACTRX OK
clock 40MHz
InitMACTRX OK
isc!h
clock 40MHz
InitPON OK!!!
- s-u-c-c-e-s-s-!-
-w-l-a-n-1
     clear_acl_table:0
d[wt_piin_iitg,m1p0_9i4n,iitf]n[a1m2e62]G[:lwulmainn1a,iisf]n anmoet5hGi:nwgl atno0
uob.r
[TPI->tpi_ucloud_start->101]:start success!
[TPI->tpi_led_start->453]:start success!
[TPI->tpi_single_led_start->111]:start success!
lan_pppoe_start::Start PPPOE server, please wait...
lan_pppoe_start::start lan-pppoe-server sucess!!!
[MAIN->init_after_module_init_services->87]:init_after_module_init_services ok!
[rc->rc_module_msg_handle->157]:start handle module[6,rc_firewall]'s msg,op=3.debug_id=0.wlan_ifname=.string_info=
[TPI->tpi_firewall_action->137]:op=3
ioctl(SIOCIPFFL): Invalid argument
[TPI->tpi_firewall_stop->263]:stop success!
wlan0     clear_acl_table:0
wlan1     clear_acl_table:0
limit:0x80635998
updated stack ptr from R29 :0x80635930
[<80226400>] [<80226408>] [<00000000>] [<00000000>] [<deadbeef>] [<00000001>] [<806350a0>] [<80226b64>]
[<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<11110010>] [<80226b38>] [<deadbeef>] [<deadbeef>]
  Type: TLB miss (Store)
  Data Regs:
    R2    00000000    R10   802C3AA4    R18   11110012    R26   DEADBEEF
    R3    00000000    R11   7FFFFFFF    R19   11110013    R27   DEADBEEF
    R4    0683D966    R12   00000000    R20   11110014    R28   8047D0A0
    R5    806350A0    R13   00000000    R21   11110015    R29   80635930
    R6    00000001    R14   F440FE00    R22   11110016    R30   80635960
    R7    00000000    R15   00363870    R23   11110017    R31   80226408
    HI    00000000    LO    00000001    SR    10000403    PC    80226400
                      CAUSE 00000000    PRID  00019385    BADVR 111159AC
          zero      at       v0       v1
           a0       a1       a2       a3
$04   : 0683d966 806350a0 00000001 00000000
           t0       t1       t2       t3
           t4       t5       t6       t7
$12   : 00000000 00000000 f440fe00 00363870
           s0       s1       s2       s3
           s4       s5       s6       s7
           t8       t9       k0       k1
           gp       sp       fp       ra
$28   : 8047d0a0 80635930 80635960 80226408
Hi    : 00000000
Lo    : 00000001
epc   : 80226400
ra    : 80226408
Cause : c000000c
BadVA : 111159ac
PrId  : 00019385
Stack : 00000000 00000000 deadbeef 00000001 806350a0 80226b64 deadbeef deadbeef
        deadbeef deadbeef 11110010 80226b38 deadbeef deadbeef deadbeef deadbeef
        deadbeef deadbeef 0683d965 80486b70 8000c21c 00000000 00000000 00000000
        00000001 00000000 00000000 00000001 00000525 80000000 00000000 00000000
Call stack:
SP: 0x80635930, RA Offset: 20, Ret Address: 0x80226400, Func Address: 0x802263e8
Code: 3c108063  8e045998  24840001 <0c087142> ae045998  080898ff  8e045998  27bdffe0  afbf001c
limit:0x80635998
[<806356e4>] [<802c5b14>] [<802c5b08>] [<8000b810>] [<80635960>] [<80635960>] [<00000030>] [<00000000>]
[<00000006>] [<00000000>] [<00000020>] [<80320000>] [<80226400>] [<8000bc04>] [<11110016>] [<00000020>]
[<00000030>] [<00000000>] [<806357e0>] [<00000008>] [<80635800>] [<802c5d94>] [<00000008>] [<11110015>]
[<11110016>] [<8000c36c>] [<deadbeef>] [<0000000a>] [<00000030>] [<00000000>] [<80226400>] [<00000017>]
[<11110017>] [<0000001f>] [<80226408>] [<10000400>] [<806357e0>] [<11110011>] [<11110012>] [<11110013>]
[<11110014>] [<80226e2c>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<806357e0>] [<80227018>]
[<00000003>] [<11110013>] [<11110014>] [<11110015>] [<11110016>] [<8021c418>] [<deadbeef>] [<deadbeef>]
[<deadbeef>] [<deadbeef>] [<806357e0>] [<80000940>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
[<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<00000000>] [<80000000>] [<00000000>] [<00000000>]
[<0683d966>] [<806350a0>] [<00000001>] [<00000000>] [<80637ed0>] [<10000401>] [<802c3aa4>] [<7fffffff>]
[<00000000>] [<00000000>] [<f440fe00>] [<00363870>] [<80630000>] [<11110011>] [<11110012>] [<11110013>]
[<11110014>] [<11110015>] [<11110016>] [<11110017>] [<802263e8>] [<8012e3dc>] [<deadbeef>] [<deadbeef>]
[<8047d0a0>] [<80635930>] [<80635960>] [<80226408>] [<00000000>] [<00000001>] [<0000000c>] [<10000403>]
[<80226400>] [<00000000>] [<c000000c>] [<111159ac>] [<00019385>] [<0322838c>] [<deadbeef>] [<deadbeef>]
[<11110010>] [<11110011>] [<80470000>] [<11110011>] [<11110012>] [<11110013>] [<11110014>] [<11110015>]
[<11110016>] [<80225904>] [<1111001a>] [<1111001b>] [<1111001c>] [<80635960>] [<80635960>] [<80227ccc>]
Stack Base: 0x80635198, Size: 0x800, Used: 0x440
Resetting ...
intf ...
eth0 18 [18]
eth1 18 [18]
eth7 18 [18]
peth0 18 [18]
eth4 18 [18]
eth3 18 [18]
eth2 18 [18]
wlan1 18 [18]
wlan1-vxd0 18 [18]
wlan1-va3 18 [18]
wlan1-va2 18 [18]
wlan1-va1 18 [18]
wlan1-va0 18 [18]
wlan0 18 [18]
wlan0-vxd0 18 [18]
wlan0-va3 18 [18]
wlan0-va2 18 [18]
wlan0-va1 18 [18]
wlan0-va0 18 [18]
pwlan0 18 [18]
bridge1 18 [18]
Booting...
init_ram
DDR init OK
init ddr ok
DRAM Type: DDR2
        DRAM Size: 64MB
found BH25D16
Write PLL1=80c00042
Lan pbmp:0x000000ef
Wan pbmp:0x000000f0
wait for upgrage
port[0] link:down
port[1] link:down
port[2] link:down
port[3] link:down
port[4] link:down
irq:0x00008080
RFE TYPE =0
[pwlan0] added...
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
RFE TYPE =0
[pwlan0] added...
[cyg_net_init] Done
cpuload_calibration_value=10166661
System start
Realtek GPIO init
init gpio_id:35
init gpio_id:35
init gpio_id:36
------------main
: Invalid argument
n!i
  ok!
clock 40MHz
InitMACTRX OK
clock 40MHz
InitMACTRX OK
isc!h
clock 40MHz
InitPON OK!!!
- s-u-c-c-e-s-s-!-
-w-l-a-n-1
     clear_acl_table:0
w_init,1094,[itfpnia_mieg2mGp:_wilnaint1],[i1f2n6a]m[el5uGm:iwnlaains0]
tnbortuhtien_gf otroc ed_oa.t
limit:0x80635998
[<00000507>] [<8025c778>] [<00000000>] [<00000000>] [<deadbeef>] [<00000001>] [<00000000>] [<80226b64>]
  Data Regs:
    R0    00000000    R8    80637ED0    R16   80630000    R24   802266C0
    R2    00000507    R10   802C3AA4    R18   11110012    R26   DEADBEEF
    R4    00000002    R12   00000000    R20   11110014    R28   8047D0A0
    R5    80000000    R13   00000000    R21   11110015    R29   80635930
    R6    00000002    R14   31B1A1C0    R22   11110016    R30   80635960
    R7    00000000    R15   00363874    R23   11110017    R31   8025C778
    HI    00000000    LO    00000001    SR    10000403    PC    00000507
                      CAUSE 00000000    PRID  00019385    BADVR 00000506
          zero      at       v0       v1
$00   : 00000000 80000000 00000507 00000000
           a0       a1       a2       a3
$04   : 00000002 80000000 00000002 00000000
           t0       t1       t2       t3
           t4       t5       t6       t7
$12   : 00000000 00000000 31b1a1c0 00363874
           s0       s1       s2       s3
           s4       s5       s6       s7
           t8       t9       k0       k1
$24   : 802266c0 8012e3dc
           gp       sp       fp       ra
$28   : 8047d0a0 80635930 80635960 8025c778
Hi    : 00000000
Lo    : 00000001
epc   : 00000507
ra    : 8025c778
Cause : 50000008
BadVA : 00000506
PrId  : 00019385
Stack : 00000000 00000000 deadbeef 00000001 00000000 80226b64 deadbeef deadbeef
        deadbeef deadbeef 05815ed4 80486b70 8000c21c 00000000 00000000 00000000
        00000001 00000000 00000000 00000002 00000507 80000000 00000000 00000000
Call stack:
SP: 0x80635930, RA Offset: 92, Ret Address: 0x8025c778, Func Address: 0x8025c12c
limit:0x80635998
updated stack ptr from R29 :0x806356c0
[<8000b478>] [<00001001>] [<806357e0>] [<80635930>] [<0000005c>] [<8025c778>] [<8025c12c>] [<8000b6c8>]
[<80226b38>] [<00000030>] [<806357e0>] [<00000000>] [<00000001>] [<80320000>] [<802c79cc>] [<802c0000>]
[<11110016>] [<11110017>] [<80635960>] [<8000bb60>] [<11110016>] [<00019385>] [<00000030>] [<00000000>]
[<806357e0>] [<00000008>] [<80635800>] [<802c5d94>] [<00000008>] [<11110015>] [<11110016>] [<8000c36c>]
[<deadbeef>] [<0000000a>] [<00000030>] [<00000000>] [<00000507>] [<00000017>] [<11110017>] [<0000001f>]
[<8025c778>] [<10000400>] [<806357e0>] [<11110011>] [<11110012>] [<11110013>] [<11110014>] [<80226e2c>]
[<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<806357e0>] [<80227018>] [<00000003>] [<11110013>]
[<11110014>] [<11110015>] [<11110016>] [<8021c418>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
[<806357e0>] [<80000940>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
[<deadbeef>] [<deadbeef>] [<00000000>] [<80000000>] [<00000507>] [<00000000>] [<00000002>] [<80000000>]
[<00000002>] [<00000000>] [<80637ed0>] [<10000401>] [<802c3aa4>] [<7fffffff>] [<00000000>] [<00000000>]
[<31b1a1c0>] [<00363874>] [<80630000>] [<11110011>] [<11110012>] [<11110013>] [<11110014>] [<11110015>]
[<11110016>] [<11110017>] [<802266c0>] [<8012e3dc>] [<deadbeef>] [<deadbeef>] [<8047d0a0>] [<80635930>]
[<80635960>] [<8025c778>] [<00000000>] [<00000001>] [<00000008>] [<10000403>] [<00000507>] [<00000000>]
[<50000008>] [<00000506>] [<00019385>] [<0322838c>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
[<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<11110000>] [<11110001>]
[<11110002>] [<11110003>] [<806350a0>] [<11110005>] [<11110006>] [<11110007>] [<11110008>] [<11110009>]
[<1111000a>] [<1111000b>] [<1111000c>] [<1111000d>] [<1111000e>] [<1111000f>] [<11110010>] [<11110011>]
[<80470000>] [<11110011>] [<11110012>] [<11110013>] [<11110014>] [<11110015>] [<11110016>] [<80225904>]
[<1111001a>] [<1111001b>] [<1111001c>] [<80635960>] [<80635960>] [<80227ccc>] [<00000000>] [<00000000>]
[<deadbeef>] [<00000001>] [<00000000>] [<80226b64>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
[<11110010>] [<80226b38>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>]
  Data Regs:
    R0    00000000    R8    80000000    R16   8025C12C    R24   00000001
    R1    80000000    R9    00006300    R17   DEADBEEF    R25   000023BD
    R2    00000000    R10   0000F000    R18   00000000    R26   80000500
    R3    00000000    R11   00000004    R19   00000000    R27   00000001
    R4    00000001    R12   00000002    R20   80000948    R28   8047D0A0
    R5    FFFFF800    R13   00006200    R21   00000000    R29   806356C0
    R6    00000030    R14   00001800    R22   00000001    R30   DEADBEEF
    R7    FFFFFF00    R15   000027BD    R23   80635990    R31   00001001
    HI    00004000    LO    00000000    SR    10000402    PC    8000B478
                      CAUSE 00000000    PRID  00019385    BADVR DEADBEEE
          zero      at       v0       v1
           a0       a1       a2       a3
$04   : 00000001 fffff800 00000030 ffffff00
           t0       t1       t2       t3
$08   : 80000000 00006300 0000f000 00000004
           t4       t5       t6       t7
$12   : 00000002 00006200 00001800 000027bd
           s0       s1       s2       s3
$16   : 8025c12c deadbeef 00000000 00000000
           s4       s5       s6       s7
$20   : 80000948 00000000 00000001 80635990
           t8       t9       k0       k1
$24   : 00000001 000023bd
           gp       sp       fp       ra
$28   : 8047d0a0 806356c0 deadbeef 00001001
Hi    : 00004000
Lo    : 00000000
epc   : 8000b478
ra    : 00001001
Status: 10000402    KERNEL EXL
Cause : c0000408
BadVA : deadbeee
PrId  : 00019385
Stack : 806357e0 80635930 0000005c 8025c778 8025c12c 8000b6c8 80226b38 00000030
        806357e0 00000000 00000001 80320000 802c79cc 802c0000 11110016 11110017
        80635960 8000bb60 11110016 00019385 00000030 00000000 806357e0 00000008
        80635800 802c5d94 00000008 11110015 11110016 8000c36c deadbeef 0000000a
        00000030 00000000 00000507 00000017 11110017 0000001f 8025c778 10000400
Call stack:
SP: 0x806356c0, RA Offset: 68, Ret Address: 0x8000b478, Func Address: 0x8000b344
SP: 0x80635708, RA Offset: 44, Ret Address: 0x8000bb60, Func Address: 0x8000b85c
SP: 0x80635738, RA Offset: 60, Ret Address: 0x8000c36c, Func Address: 0x8000c21c
SP: 0x80635778, RA Offset: 20, Ret Address: 0x80226e2c, Func Address: 0x80226e18
SP: 0x80635790, RA Offset: 20, Ret Address: 0x80227018, Func Address: 0x80226ff8
SP: 0x806357a8, RA Offset: 20, Ret Address: 0x8021c418, Func Address: 0x8021c400
Code: 2631fffc  08002d13  00109023 <57000019> 9638ffff  3c04802c  03c02821  0c0894bd  24845748
limit:0x80635998
[<8025c12c>] [<8000b6c8>] [<80226b38>] [<00000030>] [<806357e0>] [<00000000>] [<00000001>] [<80320000>]
[<802c79cc>] [<802c0000>] [<11110016>] [<11110017>] [<80635960>] [<8000bb60>] [<11110016>] [<00019385>]
[<11110016>] [<8000c36c>] [<deadbeef>] [<0000000a>] [<00000030>] [<00000000>] [<00000507>] [<00000017>]
[<11110017>] [<0000001f>] [<8025c778>] [<10000400>] [<806357e0>] [<11110011>] [<11110012>] [<11110013>]
[<deadbeef>] [<deadbeef>] [<deadbeef>] [<deadbeef>] [<00000000>] [<80000000>] [<00000507>] [<00000000>]
[<00000002>] [<80000000>] [<00000002>] [<00000000>] [<80637ed0>] [<10000401>] [<802c3aa4>] [<7fffffff>]
[<00000000>] [<00000000>] [<31b1a1c0>] [<00363874>] [<80630000>] [<11110011>] [<11110012>] [<11110013>]
[<11110014>] [<11110015>] [<11110016>] [<11110017>] [<802266c0>] [<8012e3dc>] [<deadbeef>] [<deadbeef>]
[<8047d0a0>] [<80635930>] [<80635960>] [<8025c778>] [<00000000>] [<00000001>] [<00000008>] [<10000403>]
[<00000507>] [<00000000>] [<50000008>] [<00000506>] [<00019385>] [<0322838c>] [<deadbeef>] [<deadbeef>]
[<00000000>] [<00000000>] [<deadbeef>] [<00000001>] [<00000000>] [<80226b64>] [<deadbeef>] [<deadbeef>]
Stack Base: 0x80635198, Size: 0x800, Used: 0x6b0
Resetting ...
intf ...
eth0 18 [18]
          zero      at       v0       v1
$00   : 00000000 80000000 0bb81773 0000d0c9
           a0       a1       a2       a3
$04   : 00000015 00000000 00000005 0006b6c1
           t0       t1       t2       t3
$08   : b800351c 00000000 00000000 a0000000
           t4       t5       t6       t7
$12   : 0000001c 00006200 00001800 000027bd
           s0       s1       s2       s3
$16   : 00000015 00000000 81e56de0 802ca5c4
           s4       s5       s6       s7
$20   : 802c510c 80320000 00000001 80635990
           t8       t9       k0       k1
$24   : 00000000 7fffffff
           gp       sp       fp       ra
$28   : 8047d0a0 806353c8 deadbeef 80231914
Hi    : 00000000
Lo    : 00000100
epc   : 8023191c
ra    : 80231914
Cause : 40000410
BadVA : 0bb81773
PrId  : 00019385
Stack : 8063d10c 80235604 00000001 80639e00 00000000 802320c4 80639e00 00000000
        81e56de0 00000014 80635418 80234420 00000015 80320000 00000015 00000000
        00000015 8020aa30 00000002 00000002 80635420 00000000 30687465 802ca500
        802c510c 80320000 88438842 80635990 deadbeef 80225324 80635468 802c5d94
        00000014 00002000 81e56de0 00000014 00000048 8020ac00 00000002 81e56de0
Call stack:
SP: 0x8
发表于 4 天前 | 显示全部楼层
楼主有没有找到问题,我有一人ac11v2也是这样的问题,先是固件丢,然后刷机刷机后就报这个错
GMT+8, 2025-11-14 23:35 , Processed in 0.109200 second(s), 9 queries , Gzip On, Redis On.
