查看: 646|回复: 0
[软件] GitHub Desktop v3.3.14 中文汉化安装版
发表于 2024-5-2 08:25:15 | 显示全部楼层 |阅读模式
GitHubDesktop,开源及私有项目托管平台的桌面版客户端,用于GIT项目代码托管,管理仓库版本,控制存储分支,本地同步推送等操作。GitHub.com是主流的公共代码仓库网站,托管了全球开源项目源代码。
软件截图
软件特点
1、经验电子
无论您使用的是Mac或Windows桌面,GitHubDesktop汉化版上给你一个简化的经验,为您的代码提供了更多空间。
2、简化你的工作流程
创建分支,与其他开发人员协作,并在不触及命令行的情况下提交更改。
3、让它成为你自己的
每个元素都是完全开源的,构建您所需要的功能,并成为未来GitHub桌面版的一部分。
更新日志3.3.14April 16, 2024
  • Fixed
    The tab panel semantics in the "Publish Repository" and "Clone a Repository" are announced by screen reader
  • Fixed
    The check all button in the diff always only represents one selectable group
  • Fixed
    Images diffs of less than 200px in width do not render with a zero width for diff views other than `2-up`
  • Fixed
    Fix list accessibility semantics of the Pull Request list
  • Fixed
    Fix screen reader support of warning dialogs
  • Fixed
    Selecting the "Configure manually" radio option does not cause unexpected focus shift to the name input in the Git Configuration page of the welcome flow
  • Fixed
    All dialogs can be closed by pressing Esc
  • Improved
    The force push warning in the push dropdown now has a contrast of 4.5:1
  • Improved
    Hyphen replacement and invalid sanitized name warnings and errors in the create branch and create repository dialogs are associated to the input by the aria-describedby attribute
  • Improved
    Add VapourSynth script files (.vpy) to test/x-python - #18364. Thanks @couleurm!
  • Improved
    The text contrast of tutorial steps when closed is 4.5:1
  • Improved
    Upgrade to Electron v28.2.3
  • Removed
    Remove support for macOS 10.13 and 10.14
此版特点
by robotze
汉化补丁制作
使用方法
1.安装主程序
2.运行GithubDesktopZhTool.exe,并点击汉化
3.运行githubdesktop,即为汉化版
下载地址
本地下载        飞机盘        飞书云
[url=][/url]
发表于 2024-5-2 12:44:59 来自手机浏览器 | 显示全部楼层
很多时候访问不了github
GMT+8, 2025-6-25 18:01 , Processed in 0.187200 second(s), 10 queries , Redis On.
