20年买的TR200挂了,在论坛查了一些资料,用flash ID查到主控是PS3111,颗粒是东芝。但是容量识别为0M,固件是SBRM02.0(硬盘上标注的是SBFA12.7),下载了几个固件都刷不上,求大佬指点一下,感激不尽~~~
v0.844a
Drive: 1(ATA)
OS: 10.0 build 19043
Model: PS3111
Fw : SBRM02.0
ATA: ReadSysinfo13 failed! Error: 0x51
ATA: ReadInfoBlock28 failed! Error: 0x51
Bank00: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank01: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank04: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank05: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank08: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank09: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank12: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank13: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Controller : PS3111 in Rom Mode
问题1:容量为0M还能开卡吗?
问题2:没有转接卡,用的是以前那种刷“build-s10-flasher”固件的方法来刷的,固件选择“SAFM16.0_03072018.bin”没错吧?
问题3:生成的刷固件程序提示找不到device是什么原因?(一直卡在这一步)
各位大佬,指点一下新人么,谢谢!!
