查看: 5148|回复: 10
[Other] Realtek RTL9210(B)NVMe/USB 3.1固件最新版本免费下载
发表于 2024-12-25 10:17:47 | 显示全部楼层 |阅读模式
Description:
Firmware RTL9201-A Version: No
Firmware RTL9210-B Version: 1.33.44.011824
GDFW_9210A Version:
GDFW_9210B Version: 4.30.23.071922
GDFW_9210VA Version:
GDFW_9210VB Version:
GDFW_9220 Version:
GDFW_9220VA Version:
Utilities Version: 1.15.8.0119
Date du package: 011824
Release note NVMe:
Version V1.33.44.011824
Improved Compatibility
Version V1.33.7.101923
Version V1.32.87.082923
addresses USB link instability seen in some SSD models when used in conjunction with Linux-based PCs, including the Solidigm P41 Plus. This update includes compatibility fixes in certain scenarios, including use with the Samsung 980 Pro
Version V1.32.49.140423
Version V1.32.16.010923
Version V1.31.17.102022
Version V1.30.21.070622
Has improved random 4K read performance.
Version V1.30.17
Fix slow speed issue.
Version V1.29.12.011122
Fix Compatibility with Samsung M.2 SSDs und Samsung Data Migration Too
Version V1.29.8.122921
Fix problem If your HDD/SSD could not be detected or kept disconnected from your Mac
Version v1.27.25.072921 2021.07.29
This firmware update aims to improve stability with Samsung 980 Pro and Western Digital SN550 NVMe SSDs.
The power LED behavior is also improved on Windows, and Intel based Mac systems: now when safely ejected the power LED should turn off ( it may blink slowly ) indicating the drive may be safely unplugged from the computer.This update is recommended for uses who have experienced connectivity problems with Samsung 980 Pro or Western Digital SN550 NVMe SSDs.
Version v1.23.9.100520 2020.10.05
01.Add customized command.
02.Update Kinsea KS10 LED behavior.
03.Fix Fulllink macbook disk speed test issue
Submitted On:30 Aug 2024File Size:5,588.57 KbDownloads:4044File Version:1.33.44.011824File Author:Fdrsoft
官方防盗连https://station-drivers.com
1.33.44.011824蓝奏下载
https://wwux.lanzn.com/iox9o2j216ta
Description:
Firmware RTL9210-B Version: 1.33.7.101923
GDFW_9210A Version: 4.31.12.1020.22
GDFW_9210VA Version: 4.31.11.101722
GDFW_9210VB Version: 4.31.11.101722
GDFW_9220 Version: 4.30.23.071922
GDFW_9220VA Version: 4.31.11.101722
Utilities Version: 1.15.8.01193
Date du package: 191023
Release note NVMe:
Version V1.30.17
Submitted On:30 Aug 2024File Size:5,641.00 KbDownloads:7775File Version:1.33.7.191023File Author:Fdrsoft
1.33.7.191023蓝奏下载
https://wwux.lanzn.com/iHGYU2j217bi
补充内容 (2025-1-24 09:36):
1.33.98.090324前住七楼下载
补充内容 (2025-6-7 10:50):
1.34.29.011325十一楼下载
减免请自行官网下载https://station-drivers.com
发表于 2024-12-25 16:11:08 | 显示全部楼层
这两个版本到底哪个是新的呢
 楼主| 发表于 2024-12-26 08:49:13 | 显示全部楼层
fiony 发表于 2024-12-25 16:11
这两个版本到底哪个是新的呢
44版本最新
发表于 2024-12-27 09:58:12 | 显示全部楼层
44的9210刷不了缺cfg文件
 楼主| 发表于 2024-12-27 13:28:23 | 显示全部楼层
iamggx 发表于 2024-12-27 09:58
44的9210刷不了缺cfg文件
gdfw目录里RTL9210B_v1.33.44.011824_signed
补充内容 (2025-1-24 08:59):
RTL9210.cfg没什么用,缺少可以在1.33.7中提取试试
 楼主| 发表于 2025-1-24 09:33:51 | 显示全部楼层
Version 1.33.98.090324
感觉免费提供下载地址无人关注无人打赏,改成上传社区,减免请自行官网下载
此次更新内容
更新提高写入和读取速度,并在华硕TUF A1上完美运行,很少看到固件带来如此大的变化,成果归功于对某些SSD改进支持。
发表于 2025-1-24 11:22:13 | 显示全部楼层
就是,这样的下载链接大哥call
 楼主| 发表于 2025-2-10 16:59:37 | 显示全部楼层
kuangjungang 发表于 2025-1-24 11:22
就是,这样的下载链接大哥call
减免请自行官网下载
发表于 2025-2-10 21:59:25 | 显示全部楼层
感谢楼主的分享
 楼主| 发表于 2025-3-5 09:34:06 | 显示全部楼层
版主请把主题分类[Other]改成Realtek
 楼主| 发表于 2025-5-12 14:11:16 | 显示全部楼层
Version 1.34.29.011325
更新内容
修复随机SSD断开连接的问题
 楼主| 发表于 2025-5-12 14:12:34 | 显示全部楼层
GMT+8, 2025-10-26 04:24 , Processed in 0.140401 second(s), 8 queries , Gzip On, Redis On.
