楼主 |
发表于 2025-2-28 11:34:02
显示全部楼层
是不是需要贴个log上来
<?xml version = "1.0"?>
<Genesis_Log>
<Log_Body>
Overall Summary:
Start Time: Thu, 02/27/2025 @ 20:26:47
End Time: Thu, 02/27/2025 @ 20:27:12
OverallResult: FAIL
ExitCode: (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR)
Environment Settings:
Input Parameters:
argv[1]: -PROCESS_SSD
argv[2]: 10:0:0:0
argv[3]: /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp
argv[4]: /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/28041.0.driveconfig
argv[5]: 1234567890ABCDEF
argv[6]: 0000000000000000
argv[7]: LOG=/root/TOOLS/SF/1234567890ABCDEF_bogon_DATETIMESTAMP_10.0.0.0_PROCESS_SSD_RESULT.log
Log File: /root/TOOLS/SF/1234567890ABCDEF_bogon_DATETIMESTAMP_10.0.0.0_PROCESS_SSD_RESULT.log
Hostname: Unknown
Host IP Address: Unknown
Port Number: 2
DeviceName: /dev/sg2
SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
SF_Core Library Version: v1.7.1.20130612-fc14-32bit
SF_OS_Information: Linux 3.10.0-1160.el7.x86_64 #1 SMP Mon Oct 19 16:18:59 UTC 2020 x86_64
Post Processing Device Information:
WWN OUI: UNKNOWN
WWN UniqueID: UNKNOWN
Serial No.: UNKNOWN
Model No.: UNKNOWN
Firmware Revision: UNKNOWN
ROM Revision: UNKNOWN
NAND Page Size: UNKNOWN
Number Of Chip Enable: UNKNOWN
Logical Sectors: UNKNOWN
NAND ID: UNKNOWN
Flash Manufacturer: UNKNOWN
Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 02/27/2025 20:26:47] - SF_Genesis has been invoked with the following parameters:
argv[2]: 10:0:0:0
[Thu 02/27/2025 20:26:47] - Instructing the operating system to purge any existing cached data for device: '10:0:0:0'
[Thu 02/27/2025 20:26:52] - Issuing a discovery command for device: '10:0:0:0'
[Thu 02/27/2025 20:26:57] - Discovery command completed...
[Thu 02/27/2025 20:26:57] - Waiting 5 seconds for the system to settle...
[Thu 02/27/2025 20:27:02] - Device designation string '10:0:0:0' is mapped to node '/dev/sg2'
[Thu 02/27/2025 20:27:02] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp
Configuration File = /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/28041.0.driveconfig
Serial No. = 1234567890ABCDEF
World Wide Name = 0000000000000000
[Thu 02/27/2025 20:27:03] - Successfully received the IDENTIFY data from the drive...
[Thu 02/27/2025 20:27:03] - Validating Manufacturing Firmware Package: /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp
[Thu 02/27/2025 20:27:03] - Successfully opened the package: /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/FW_PPRO_6_0_A_Release.1134440.release.0.mfp
[Thu 02/27/2025 20:27:03] - file /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/28041.0.driveconfig Loaded successfully
[Thu 02/27/2025 20:27:03] - Warning: Unable to query diagnostics information to perform power management settings check
[Thu 02/27/2025 20:27:03] - B01 Power Management configuration request detected
[Thu 02/27/2025 20:27:03] - Successfully extracted *.DriveConfig file: /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/28041.0.driveconfig
[Thu 02/27/2025 20:27:03] - Extracted Config_ID: 1 (28041) in DriveConfig file: /root/TOOLS/SF/output/FW_PPRO_6_0_A_Release.1134440.release--0/Configuration_Files/28041.0.driveconfig
[Thu 02/27/2025 20:27:03] - Extracted SerialOutputControl: 0
[Thu 02/27/2025 20:27:03] - Searching for flashware image for configuration 28041
[Thu 02/27/2025 20:27:03] - Manifest found for configuration 28041
[Thu 02/27/2025 20:27:03] - Flashware image extracted: 28041_fw_cl_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Thu 02/27/2025 20:27:03] - Searching for manufacturing image for configuration 28041
[Thu 02/27/2025 20:27:03] - Manufacturing image extracted: 28041_mf_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Thu 02/27/2025 20:27:03] - Proceeding in ROM mode, download feature 3...
[Thu 02/27/2025 20:27:03] - Successfully downloaded MFB to the drive...
[Thu 02/27/2025 20:27:03] - Waiting (5 sec) for the drive to settle...
[Thu 02/27/2025 20:27:08] - Successfully received the IDENTIFY data from the drive...
[Thu 02/27/2025 20:27:08] - Firmware revision reported to be: '60AABBM0'. This indicates MFB download was successful.
[Thu 02/27/2025 20:27:08] - Successfully enabled SMART capabilities...
[Thu 02/27/2025 20:27:10] - Successfully issued a diagnostic unlock...
[Thu 02/27/2025 20:27:11] - Performing the flash test of block 0 (0x0000)...
[Thu 02/27/2025 20:27:12] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 1
Chip Enabled Count: 2
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
Total Number of test results: 8
Number of failures: 8
Number of Passed with warnings: 0
No. Passed without warnings: 0
[Thu 02/27/2025 20:27:12] - End of Genesis manufacturing log.
[Thu 02/27/2025 20:27:12] - Exiting...
</Log_Body>
<Overall_Summary>
<Start_Time> Thu, 02/27/2025 @ 20:26:47 </Start_Time>
<End_Time> Thu, 02/27/2025 @ 20:27:12 </End_Time>
<Overall_Result> FAIL </Overall_Result>
<Exit_Code> (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR) </Exit_Code>
</Overall_Summary>
<Environment_Settings>
<Input_Parameters>
argv[2]: 10:0:0:0
</Input_Parameters>
<Log_File> /root/TOOLS/SF/1234567890ABCDEF_bogon_DATETIMESTAMP_10.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
<Hostname> Unknown </Hostname>
<Host_IP_Address> Unknown </Host_IP_Address>
<Port_Number> 2 </Port_Number>
<Device_Name> /dev/sg2 </Device_Name>
<SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
<SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
<SF_OS_Information> Linux 3.10.0-1160.el7.x86_64 #1 SMP Mon Oct 19 16:18:59 UTC 2020 x86_64 </SF_OS_Information>
</Environment_Settings>
<Post_Processing_Device_Info>
<WWN_OUI> UNKNOWN </WWN_OUI>
<WWN_UniqueID> UNKNOWN </WWN_UniqueID>
<Serial_Number> UNKNOWN </Serial_Number>
<Model_Number> UNKNOWN </Model_Number>
<Firmware_Revision> UNKNOWN </Firmware_Revision>
<ROM_Revision> UNKNOWN </ROM_Revision>
<NAND_Page_Size> UNKNOWN </NAND_Page_Size>
<Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
<Logical_Sectors> UNKNOWN </Logical_Sectors>
<NAND_ID> UNKNOWN </NAND_ID>
<Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
<Flash_Device> UNKNOWN </Flash_Device>
</Post_Processing_Device_Info>
</Genesis_Log>
[Thu 02/27/2025 20:27:12] - Overall Result for Device: /dev/sg2 ****** FAIL ******
