楼主 |
发表于 2019-9-20 12:57:07
显示全部楼层
这是我拆下来用设备读出来的信息,有空帮我分析有什么型号的字库可以代换,谢谢。
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 MHz
EMMC Device Information :
EMMC CID: 15010041475344325312BBAB52272495
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: AGSD2S , HEX: 414753443253 , S/N: BBAB5227 , rev. 0x12
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2017
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 16384 KB (000001000000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x50 , Boot from: ROM3 (Boot partition 2)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: AGSD2S_BBAB5227_20190703_185715.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is not found
MBR header is found. Analyzing data ...
Partition: mmcblk0p0 [000000800000 - 000001000000], size: 000000800000 (8.00 MB)
Partition: mmcblk0p1 [000001000000 - 000001800000], size: 000000800000 (8.00 MB)
EBR detected at address: 000001800000
Partition: mmcblk0p2 [000086C00000 - 00039FE00000], size: 000319200000 (12.3 GB)
Partition: mmcblk0p3 [000001800200 - 000041800000], size: 00003FFFFE00
Partition: mmcblk0p4 [000041800200 - 000081800000], size: 00003FFFFE00
Partition: mmcblk0p5 [000081800200 - 000082000000], size: 0000007FFE00
Partition: mmcblk0p6 [000082000200 - 000082400000], size: 0000003FFE00
Partition: mmcblk0p7 [000082400200 - 000084400000], size: 000001FFFE00
MBR header successfully parsed
Get firmware version
Brand = Neusoft
Manufacturer = Neusoft
Device = s301_17
Model = CHANGAN
Phone platform = imx6
CPU Abi = armeabi-v7a
Android release = 4.3
Firmware version = 01.04.13132.09333
Firmware date = Mon Nov 26 14:41:10 CST 2018
