我的这个硬盘现在无法格式化操作,所以想进行开卡,但是开卡过程中我短接尾部两个圆点不读取rom,设备管理器的磁盘管理还是显示128G未格式化
通过phison_flash_id获取到以下信息
v0.772a
Drive: 1(USB)
OS: 10.0 build 22621
Model: SATAFIRM S11
Fw : SBFM21W1
P/N : 511-171101297 , SBSM21.0
S11fw: SBFM21.1, 2017Oct13
Bank00: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron MLC 256Gb/CE 256Gb/die
Bank04: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron MLC 256Gb/CE 256Gb/die
Bank08: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron MLC 256Gb/CE 256Gb/die
Bank12: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron MLC 256Gb/CE 256Gb/die
Controller : Possible PS3109 or PS3111
Flash CE : 4
PS3105/3108/3109/3111 only:
Flash Channel: 2
Dram Size,MB : 32
PS3110 only :
Flash Channel: 4
Interleave : 2
Flash Mode/Clk: 0/0 (S9) or 5/7 (S11)
Defects All Early Later
Bank00: 56 56 0
Bank04: 81 81 0
Bank08: 18 18 0
Bank12: 38 38 0
Total : 193 193 0
Early defect list
Bank00: 96 97 98 99 102 328 608 896 902 904 908 909 910 1050 1120 1124 1125 1126 1128 1129 1130 1132 1133 1134 1376 1377 1378 1379 1380 1381 1382 1383 1632 1633 1634 1635 1636 1637 1638 1639 1920 1921 1922 1923 1924 1925 1926 1927 1928 1929 1930 1931 1932 1933 1934 1935
Bank04: 16 96 97 98 99 103 104 106 111 112 352 354 359 608 610 615 810 818 826 834 842 858 866 874 882 890 896 898 903 904 905 906 911 914 920 921 922 923 930 938 946 1120 1121 1122 1127 1128 1129 1130 1135 1376 1377 1378 1379 1380 1381 1383 1624 1632 1633 1634 1635 1636 1637 1638 1639 1920 1921 1922 1923 1924 1925 1926 1927 1928 1929 1930 1931 1932 1933 1934 1935
Bank08: 96 97 98 99 1128 1376 1632 1757 1920 1921 1924 1928 1929 1930 1931 1932 1933 1935
Bank12: 96 97 98 99 100 358 359 609 1120 1128 1138 1376 1377 1379 1380 1382 1632 1633 1635 1636 1637 1638 1920 1921 1922 1923 1924 1925 1926 1927 1928 1929 1930 1931 1932 1933 1934 1935
Later defect list
PS3111 smart configuration:
Attr Tresh Flags ValId WrstId RawId Description
0x01: 0x32 0x0B 0x0000 0x0000 0x0100 - Number of ECC Error
0x09: 0x00 0x12 0x0000 0x0000 0x0600 - Power on hours
0x0C: 0x00 0x12 0x0000 0x0000 0x0607 - Power on/off cycles
0xA8: 0x00 0x12 0x0000 0x0000 0x0103 - SATA PHY error count
0xAA: 0x0A 0x03 0x0102 0x0102 0x030C - Total Early Bad Block Count/Total Later Bad Block Count
0xAD: 0x00 0x12 0x0000 0x0000 0x0204 - Max Erase Cnt/Avg Erase Cnt
0xC0: 0x00 0x12 0x0000 0x0000 0x0608 - Unexpected Power Loss Count
0xC2: 0x00 0x23 0x0300 0x0300 0x0800 - Current Temp/Min Temp/Max Temp
0xDA: 0x32 0x0B 0x0000 0x0000 0x0104 - CRC Error Count
0xE7: 0x00 0x13 0x0000 0x0000 0x020A - SSD life left
0xF1: 0x00 0x12 0x0000 0x0000 0x0402 - Host Write (GB)
