查看: 1316|回复: 23
[Arduino] 大佬看一下代码!为什么中断不执行?Arduino C++ 的PID恒温
发表于 2025-8-1 16:51:51 | 显示全部楼层 |阅读模式
Arduino C语言  PID恒温   通过18B20温度传感器,感应加热片的温度,控制MOS管 0~255的PWM
目前PID运行很好,我很满意,但是我想要用一个按钮调整温度,按下按钮没有反应,按钮接在11引脚和12引脚
代码如下:
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <PinChangeInterrupt.h>
LiquidCrystal_I2C mylcd(0x27,16,2);
volatile double kd;
volatile double ki;
volatile double kp;
volatile int setpint;
volatile long sumerror;
volatile long lasterror;
volatile int input;
volatile int output;
volatile long newerror;
volatile float t;
volatile int p;
OneWire oneWire_9(9);
DallasTemperature sensors_9(&oneWire_9);
DeviceAddress insideThermometer;
float ds18b20_9_getTemp(int w) {
  sensors_9.requestTemperatures();
  if(w==0) {
    return sensors_9.getTempC(insideThermometer);
  else {
    return sensors_9.getTempF(insideThermometer);
void attachPinInterrupt_fun_CHANGE_11() {
  setpint++;
//按下按钮,设置温度加1,就是这里的代码不生效
void attachPinInterrupt_fun_FALLING_12() {
  setpint = setpint - 1;
//按下按钮,设置温度减1,就是这里的代码不生效
void setup(){
  mylcd.init();
  mylcd.backlight();
  kd = 0.12;
  ki = 0.2;
  kp = 0.5;
  setpint = 40; //这个是当前设置的温度
  sumerror = 0;
  lasterror = 0;
  input = 10;
  output = 0;
  newerror = 0;
  t = 0;
  p = 0;
  mylcd.setCursor(1-1, 1-1);
  mylcd.print("T");
  mylcd.setCursor(2-1, 1-1);
  mylcd.print(":");
  mylcd.setCursor(8-1, 1-1);
  mylcd.print("C");
  mylcd.setCursor(1-1, 2-1);
  mylcd.print("SET");
  mylcd.setCursor(4-1, 2-1);
  mylcd.print(":");
  mylcd.setCursor(5-1, 2-1);
  mylcd.print(setpint);
  mylcd.setCursor(9-1, 2-1);
  mylcd.print("PWM");
  mylcd.setCursor(12-1, 2-1);
  mylcd.print(":");
  sensors_9.getAddress(insideThermometer, 0);
  sensors_9.setResolution(insideThermometer, 9);
  pinMode(6, OUTPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
void loop(){
  mylcd.setCursor(13-1, 2-1);
  mylcd.print(p);
  mylcd.setCursor(3-1, 1-1);
  mylcd.print(ds18b20_9_getTemp(0));
  t = ds18b20_9_getTemp(0);  //读取18B20温度传感器的值,并且赋值给 变量 t
  newerror = setpint - t;
  sumerror = sumerror + newerror;
  output = (kp * newerror + ki * sumerror) + kd * (lasterror - newerror);
  lasterror = newerror;
  p = output;
  if (p >= 255) {
    p = 255;
  if (p <= 0) {
    p = 0;
  analogWrite(6, p);  //接MOS管 接6号引脚
  attachPCINT(digitalPinToPCINT(11),attachPinInterrupt_fun_CHANGE_11,CHANGE);//按下按钮,设置温度加1,就是这里的代码不生效
  attachPCINT(digitalPinToPCINT(12),attachPinInterrupt_fun_FALLING_12,FALLING);//按下按钮,设置温度减1,就是这里的代码不生效
 楼主| 发表于 2025-8-1 16:55:52 | 显示全部楼层
 楼主| 发表于 2025-8-1 16:57:56 | 显示全部楼层
参与人数 1家元 +6 收起 理由
8139 + 6 我不懂Arduino啊,哈哈
发表于 2025-8-1 17:01:02 | 显示全部楼层
 楼主| 发表于 2025-8-1 17:09:22 | 显示全部楼层
 楼主| 发表于 2025-8-1 17:11:19 | 显示全部楼层
发表于 2025-8-1 17:14:05 | 显示全部楼层
 楼主| 发表于 2025-8-1 17:15:51 | 显示全部楼层
发表于 2025-8-1 17:17:08 | 显示全部楼层
 楼主| 发表于 2025-8-1 17:23:30 | 显示全部楼层
 楼主| 发表于 2025-8-1 17:24:08 | 显示全部楼层
发表于 2025-8-1 17:34:49 | 显示全部楼层
 楼主| 发表于 2025-8-1 17:37:55 | 显示全部楼层
发表于 2025-8-1 17:44:12 | 显示全部楼层
参与人数 1家元 +6 收起 理由
sadfun + 6 熱心助人
发表于 2025-8-1 17:47:24 | 显示全部楼层
 楼主| 发表于 2025-8-1 17:49:34 | 显示全部楼层
发表于 2025-8-1 18:11:48 | 显示全部楼层
发表于 2025-8-1 18:45:51 来自手机浏览器 | 显示全部楼层
发表于 2025-8-1 20:59:04 | 显示全部楼层
 楼主| 发表于 2025-8-2 14:12:18 | 显示全部楼层
GMT+8, 2026-10-1 03:42 , Processed in 0.140400 second(s), 10 queries , Gzip On, Redis On.
