查看: 58|回复: 2
[SMI] 金泰克P650(SM2263XT G AD 长江存储)量产不成功卡40% ,请指教
发表于 6 小时前 | 显示全部楼层 |阅读模式
产品如图
用的SM2263XT G AD 存储芯片用的长江存储的。
用了几个SM2263 长江存储的量产工具量产卡40%
smi_nvme_flash_id 如下:
OS: 10.0 build 19043
Drive     : 0(NVME)
Scsi      : 1
Driver    : W10
Model     : tigo SSD 256GB
Fw        : T0828A0
HMB       : 32768 - 65536 KB (Enabled, 64 M)
Size      : 244198 MB [256.1 GB]
LBA Size  : 512
AdminCmd  : 0x00 0x01 0x02 0x04 0x05 0x06 0x08 0x09 0x0A 0x0C 0x10 0x11 0x80 0x81 0x82 0xC0 0xC1 0xC2
I/O Cmd   : 0x00 0x01 0x02 0x05 0x09
Controller:  [SM2263XT] bufferless
Bank00: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank01: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank02: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank03: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank08: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank09: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank10: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank11: 0x9b,0xc3,0x48,0x25,0x10,0x0,0x0,0x0 - YMTC 3dv2-64L(x1-9050) TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Channel: 4
CE     : 2
Plane  : 2
Die/Ce : 1
Ch map : 0x0F
CE map : 0x05
Bit Per Cell  : (TLC)
Inter.        : 2
Pages/Block   : 1152(384)
First Fblock  :    1
Total Fblock  : 1006
Total Hblock  : 3816
Fblock Per Ce : 1006
Fblock Per Die: 1006
Original Spare Block Count :    68
Vendor Marked Bad Block    :     0
Bad Block From Pretest     :    29
SM2263XT Telemetry data:
VERSION                                                  :                1
Power-on Hours Count                                     :             2848
Temperature                                              :               24
RE-allocated Sector Events                               :           110658
Total LBAs Written                                       :       7001754008 [3339GB]
Total LBAs Read                                          :     125121497492 [59663GB]
SLC Available Spare Blocks (SLC)                         :               68
SLC NAND Writes (SLC)                                    :       6884229120
TLC NAND writes (TLC/MLC)                                :      12919777040
Current SLC spare super block (SLC)                      :               56
TLC Erase cycle average                                  :               80
TLC Erase cycle Max                                      :              585
TLC Erase cycle Min                                      :                4
Throttling light count(transit to PS1 from PS0 and PS2)  :                1
Retry count (retry trig)                                 :           110658
total manufacture bad count(unit : plane)                :                1
Worst manufacture bad count(unit : plane)                :              182
SLC Valid 4K count                                       :                2
SLC system block writes(sector)                          :               68
以上红框中频率调266 或100 试过了也不行,转接卡用的SSK的,芯片JMS583。
请大老指教应该用哪款工具量产合适,先谢了
发表于 4 小时前 | 显示全部楼层
放下开卡时的错误截图吧,还有转接卡主控型号
发表于 3 小时前 | 显示全部楼层
还要看设置图才知道啊
GMT+8, 2025-10-24 15:30 , Processed in 0.093600 second(s), 9 queries , Gzip On, Redis On.
