根据https://appliancerepairshymon.ca ... achine-error-codes/ 所述:
ERROR CODE E82 – DRUM BLOCKED
The error code may be displayed if the drum or motor freezes for a few seconds and then resumes. Try spinning the drum by hand:
If it does not rotate freely, check that no clothing or other object is blocking the rotation of this part.
If it turns, check the motor system (coals, motor, belt).
说是滚筒受阻, 但是滚筒旋转并无异常。正常洗和甩干都能用。
皮带被死兔子给咬掉4x1厘米, 不知道皮带有没有相应的光电传感器做监测。 |
