查看: 30|回复: 1
[慧荣] 求助,SM2259XT2固态U盘无法写入,只能读取
发表于 2 小时前 | 显示全部楼层 |阅读模式
几年前咸鱼买的固态U盘,SM2259XT2主控,ASM235桥接芯片,镁光B17A颗粒。
之前一直用的好好的,前天突然无法写入数据。
症状是原来的数据读取都正常,但是写入或者删除新数据时,文件管理器中都显示写入或者删除掉了。可是一旦把盘拔下来,再插入电脑,所有文件全部恢复原状。
另外用各种格式化软件格式化都失败。
附件是linux下的SMART的报告。
  1. smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.11.11-valve24-2-neptune-611-gfd0dd251480d] (local build)
  2. Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
  3. === START OF INFORMATION SECTION ===
  4. Device Model:     PSSD 256GB
  5. Serial Number:    RS202302000000000712
  6. Firmware Version: V1114A0
  7. User Capacity:    256,060,514,304 bytes [256 GB]
  8. Sector Size:      512 bytes logical/physical
  9. Rotation Rate:    Solid State Device
  10. Form Factor:      2.5 inches
  11. TRIM Command:     Available
  12. Device is:        Not in smartctl database 7.3/5528
  13. ATA Version is:   ACS-4 (minor revision not indicated)
  14. SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
  15. Local Time is:    Sun Nov 30 00:46:22 2025 CST
  16. SMART support is: Available - device has SMART capability.
  17. SMART support is: Enabled
  18. === START OF READ SMART DATA SECTION ===
  19. SMART overall-health self-assessment test result: FAILED!
  20. Drive failure expected in less than 24 hours. SAVE ALL DATA.
  21. No failed Attributes found.
  22. General SMART Values:
  23. Offline data collection status:  (0x00)        Offline data collection activity
  24.                                         was never started.
  25.                                         Auto Offline Data Collection: Disabled.
  26. Self-test execution status:      (   0)        The previous self-test routine completed
  27.                                         without error or no self-test has ever
  28.                                         been run.
  29. Total time to complete Offline
  30. data collection:                 (  120) seconds.
  31. Offline data collection
  32. capabilities:                          (0x11) SMART execute Offline immediate.
  33.                                         No Auto Offline data collection support.
  34.                                         Suspend Offline collection upon new
  35.                                         command.
  36.                                         No Offline surface scan supported.
  37.                                         Self-test supported.
  38.                                         No Conveyance Self-test supported.
  39.                                         No Selective Self-test supported.
  40. SMART capabilities:            (0x0002)        Does not save SMART data before
  41.                                         entering power-saving mode.
  42.                                         Supports SMART auto save timer.
  43. Error logging capability:        (0x01)        Error logging supported.
  44.                                         General Purpose Logging supported.
  45. Short self-test routine
  46. recommended polling time:          (   2) minutes.
  47. Extended self-test routine
  48. recommended polling time:          (  10) minutes.
  49. SCT capabilities:                (0x0001)        SCT Status supported.
  50. SMART Attributes Data Structure revision number: 1
  51. Vendor Specific SMART Attributes with Thresholds:
  52. ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  53.   1 Raw_Read_Error_Rate     0x0032   100   100   050    Old_age   Always       -       2
  54.   5 Reallocated_Sector_Ct   0x0032   100   100   050    Old_age   Always       -       49
  55.   9 Power_On_Hours          0x0032   100   100   050    Old_age   Always       -       1754
  56. 12 Power_Cycle_Count       0x0032   100   100   050    Old_age   Always       -       1030
  57. 160 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       0
  58. 161 Unknown_Attribute       0x0033   100   100   050    Pre-fail  Always       -       102261109
  59. 163 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       9
  60. 164 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       6839
  61. 165 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       118
  62. 166 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       4
  63. 167 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       15
  64. 168 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       5050
  65. 169 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       100
  66. 175 Program_Fail_Count_Chip 0x0032   100   100   050    Old_age   Always       -       0
  67. 176 Erase_Fail_Count_Chip   0x0032   100   100   050    Old_age   Always       -       0
  68. 177 Wear_Leveling_Count     0x0032   100   100   050    Old_age   Always       -       0
  69. 178 Used_Rsvd_Blk_Cnt_Chip  0x0032   100   100   050    Old_age   Always       -       49
  70. 181 Program_Fail_Cnt_Total  0x0032   100   100   050    Old_age   Always       -       0
  71. 182 Erase_Fail_Count_Total  0x0032   100   100   050    Old_age   Always       -       0
  72. 192 Power-Off_Retract_Count 0x0032   100   100   050    Old_age   Always       -       1030
  73. 194 Temperature_Celsius     0x0022   100   100   050    Old_age   Always       -       40
  74. 195 Hardware_ECC_Recovered  0x0032   100   100   050    Old_age   Always       -       0
  75. 196 Reallocated_Event_Count 0x0032   100   100   050    Old_age   Always       -       0
  76. 197 Current_Pending_Sector  0x0032   100   100   050    Old_age   Always       -       49
  77. 198 Offline_Uncorrectable   0x0032   100   100   050    Old_age   Always       -       0
  78. 199 UDMA_CRC_Error_Count    0x0032   100   100   050    Old_age   Always       -       0
  79. 232 Available_Reservd_Space 0x0032   100   100   050    Old_age   Always       -       102261109
  80. 241 Total_LBAs_Written      0x0030   100   100   050    Old_age   Offline      -       36201
  81. 242 Total_LBAs_Read         0x0030   100   100   050    Old_age   Offline      -       39654
  82. 245 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       76239
  83. SMART Error Log Version: 1
  84. No Errors Logged
  85. SMART Self-test log structure revision number 1
  86. No self-tests have been logged.  [To run self-tests, use: smartctl -t]
  87. Selective Self-tests/Logging not supported
  88. The above only provides legacy SMART information - try 'smartctl -x' for more
复制代码
发表于 15 分钟前 | 显示全部楼层
GMT+8, 2025-11-30 15:20 , Processed in 0.124800 second(s), 7 queries , Gzip On, Redis On.
