查看: 485|回复: 2
[群联] 解决高版本mpall量产老主控BackgroundMerge报错
发表于 2026-1-20 21:37:39 | 显示全部楼层 |阅读模式
解决高版本mpall量产老主控BackgroundMerge报错,主要是红色那个不行就把整个复制走,不知道加了啥可以开启smart,不用这里面的参数打开工具就掉盘,即便是做了F1+F2,加了低格参数不起效果,估计还差一个低格烧录器,Sorting Burner File=B2303D2-LED_Flash.BIN那个30k的不行,这125个备用块,看不到坏块,绷不住了
[ParamEdit]
version= V3.16.17.0
CheckModeOrPartition=2
[PenDriveMP]
IC Type=PS2251-03
[Parameter Mark]
Parameter Type=F1_MP_21
VersionDate=2020-08-25
[Customize Info]
USB VID=0x13FE
USB PID=0x5200
String Product Name=Silicon-Power
String Manufacturer Name=TOSHIBA
Inquiry Version=PMAP
Use30Fixture=1
[Configuration]
Reset Serial Number=0
File System 1=2
FAT2NTFS=0
Mapping=0
TestReadWrite_Cycle=1
TestReadWrite_Percentage=0
Flash Mode=1
Show RDT Time=0
Check IB=0
ODT On=0
TestReadWrite Mode=0
CheckDarkSize=1
ExPBA=0
[TestItemOption]
Do Preformat Test=1
[Extra]
Mode=3
[Misc]
Volume Label=TOSHIBA
Burner Erase All=1
First Burner Erase All=1
set1667=0x00
[Advance]
FC1=0xFF
FC2=0x01
forceWriteLBACount=20
DisableBackgroundMerge=1
[Firmware]
ISP=1
Burner File=D:\USBProducts\Phison\Phison_MPALL_V5.18.00-01\BN03V117M.BIN
Firmware Name=D:\USBProducts\Phison\Phison_MPALL_V5.18.00-01\FW03FF01V11010M_20140205.BIN
[Sorting]
U3S Force Test=1
TestPercentage=100
BicsType=0
ShowDetailLog=1
Vendor=Auto
PageSize=Auto
DesignNM=Auto
Size=Auto
DoQC=0
IQC=0
Disable Check BCO=0
CheckSSDA2=0
SSDRule=0
SortingB1Capacity=15360
SortingB2Capacity=14800
SortingB3Capacity=12000
SortingB4Capacity=7680
SortingB5Capacity=7000
SortingB6Capacity=3840
SortingB7Capacity=1920
SortingB8Capacity=960
SortingB9Capacity=480
SortingB10Capacity=240
SortingB11Capacity=120
DoSorting=1
DoMPALL=1
SortingMode=12
FlashSlot=2
CustomerId=0x90
BinMode=1
DoF2=0
DoFQC=0
TestPlaneMode=-1
ShowMaxAndBinSize=1
SLCUseECC=20
Timing105=2
Timing106=1
Timing10C=a2
Timing10D=a1
FlashPartnumber=Auto
TestRetryRead=1
[Advanced Configuration]
Timing105=2
Timing106=1
Timing10C=a2
Timing10D=a1
Disable copyback=0x0c
Cache Read=0x00
Cache=0xcd
Disable wear leveling=0x00
[AP_VER]
APMajorVer=0x03
APMinorVer=0x7E
APRelYear=2017
APRelMonth=6
APRelDay=18
参与人数 1家元 +60 收起 理由
家睦 + 60
 楼主| 发表于 2026-1-21 12:20:13 来自手机浏览器 | 显示全部楼层
GMT+8, 2026-10-5 07:15 , Processed in 0.124801 second(s), 12 queries , Gzip On, Redis On.
