马路上走,看到一个黑黑的家伙,带有一块超小的锂电池,感觉是蓝牙耳机。
捡起来看看,外壳烂了,电池已经被轧扁了,怕不安全扯下来电池扔了。
剩下的主板研究一下,
面贴也消失了,看到一个锅仔片按钮,大概是接电话的
外围很精简,就一片芯片,六根导线分别连接充电,电池,耳机,不过都已经压断遗失了
钳子剪开外壳取出主板,确实很小巧
仔细看好像丢失了一些芝麻粒,焊盘还有痕迹
蓝牙天线也撬起来了,暴力,汽车碾过力道不小!
有2个led指示灯,看得出来是多色闪烁的,旁边的芯片可能是充电或者电源管理之类吧
硅胶套保护的应该是mic,撬开看看
果然是mic,为了防水嘛?
天线自己掉下来了,三个焊盘焊了两头
这种多层板印刷天线,有点意思
螃蟹的主控, Realtek瑞昱RTL8763BFR低功耗蓝牙5.0双模芯片。这是瑞昱首款支持AI唤醒的TWS蓝牙耳机芯片。
1. QFN40 5mm X 5mm
RTL8763BF – Stereo headset, dual mic headset
RTL8763BFR – RWS headset
RTL8763BM – Mono headset
(RTL8763BF/BFR supports 8M-bits on chip FLASH memory、RTL8763BM/BMR support 1-bit and 2-bit mode)
BT5.0,8mA低功耗,双边通话,出仓开机 ,自动配对,智能入耳检测,语言唤醒,敲击/触摸操作,HIFI级音质。
Bluetooth 5 specification compatible
Supports HFP 1.7, HSP 1.2, A2DP 1.3, AVRCP 1.6, SPP 1.2 and PBAP 1.0
Single-end RF radio output with high performance 10dBm of transmitter power and -94dBm 2M EDR receiver sensitivity
Supports Bluetooth classic (BDR/EDR)
Supports Bluetooth Low Energy (BLE)
Generic access service
Device information service
Proprietary services for data communication
Apple Notification Center Service (ANCS)
Real Wireless Stereo (RWS)
Supports USB type-C audio
Supports iAP2
Realtek’s latest RCV (Real Clear Voice) technology for narrowband and wideband voice connection, including wind noise reduction
Supports high resolution audio codec up to 24bits, 192kHz audio data format
Supports dual analog and digital MIC, AUX-IN, I2S digital audio, analog output
Supports high speed UART, I2C, SPI and USB2.0 compatible interface
Supports high resolution 12-bits multi-channel ADC
Supports PWM I/O and smart LED controller
Supports USB BC1.2 battery charging
Smart I/O distribution scheme with MUX
Built-in 8Mbits FLASH memory (RTL8763BF/RTL8763BFR)
Integrated dual switch mode power regulator, linear regulators, and battery charger; charging current up to 400mA
Built-in battery voltage monitoring and thermal protection scheme with external thermal resistor
SBC, AAC decoder support
Package: 5x5mm2 QFN40 (RTL8763BM, RTL8763BF, RTL8763BFR), 6x6mm2 QFN48 (RTL8763BS) and 8x8mm2 QFN68 (RTL8763BA) with 0.4mm pitch
Supports OTA and USB firmware upgrade
GSM 217Hz interference block out design
Low BOM cost
Green (RoHS compliant and no antimony or halogenated flame retardants)
Supports PTA (Packet Traffic Arbiter) when co-existing with Wi-Fi
Realtek RWS蓝牙无线耳机工作原理:和传统无线蓝牙耳机相比,RWS无线蓝牙耳机技术将单个蓝牙装置由一个增添为两个单体耳机,并区分出主耳机和从耳机,从技术上来说是指手机通过连接主耳机,再由主耳机通过蓝牙无线方式连接从耳机,实现真正的蓝牙左右声道无线分离使用。不连接从耳机时,主耳机回到单声道音质。简单来说就是左右声道的耳机组成主从关系,将收到的音源传递给另外一个耳机实现真立体声的效果。 采用Realtek RWS技术能够实现左右耳之间的延迟约在<<3ms,蓝牙无线耳机到手机之间的延时约在<<100ms左右。这将意味着RWS技术能够应用到大部分极端恶劣的干扰环境中。
要说TWS蓝牙耳机,我们先从TWS技术说起。TWS:为True Wireless Stereo的缩写,是真正无线立体声的意思,这种技术的实现是基于芯片技术的发展。其从技术上来说是指手机通过连接主音箱,再由主音箱通过蓝牙无线方式连接从音箱,实现真正的蓝牙左右声道无线分离使用。不连接从音箱时,主音箱回到单声道音质。TWS技术运用到了蓝牙耳机领域,因此也催生了一个新的产品-TWS蓝牙耳机。
相比普通蓝牙耳机,TWS真无线蓝牙耳机具有如下优点:
1.真无线结构, 完全摒弃有线烦恼,运动更自由。
2.使用方式多样,既可独享,又可分享,还可一机当做两机用。
由于TWS蓝牙耳机两耳挂不需要有线连接,左右2个耳机通过蓝牙组成立体声系统,听歌、通话、佩戴都得到了提升。大概是长这样的
芯片原理图,我是懒得去补齐芝麻粒了
