<?xml version = "1.0"?>
<Genesis_Log>
<Log_Body>
Overall Summary:
Start Time: Fri, 05/10/2024 @ 16:06:14
End Time: Fri, 05/10/2024 @ 16:06:29
OverallResult: FAIL
ExitCode: (0x00100002:SF_SATA_INVALID_FILENAME_ERROR)
Environment Settings:
Input Parameters:
argv[1]: -PROCESS_SSD
argv[2]: 54:0:0:0
argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/21808.12345.120.driveconfig
argv[5]: 12345
argv[6]: www_123
argv[7]: log=/log/
Log File: SF_Genesis_Main_Log__Fri_05.10.2024_16.06.14.log
Hostname: localhost.localdomain
Host IP Address: 127.0.0.1
Port Number: 2
DeviceName: /dev/sg2
SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
SF_Core Library Version: v1.7.1.20130612-fc14-32bit
SF_OS_Information: Linux 2.6.32-573.el6.i686 #1 SMP Thu Jul 23 12:37:35 UTC 2015 i686
Post Processing Device Information:
WWN OUI: UNKNOWN
WWN UniqueID: UNKNOWN
Serial No.: UNKNOWN
Model No.: UNKNOWN
Firmware Revision: UNKNOWN
ROM Revision: UNKNOWN
NAND Page Size: UNKNOWN
Number Of Chip Enable: UNKNOWN
Logical Sectors: UNKNOWN
NAND ID: UNKNOWN
Flash Manufacturer: UNKNOWN
Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 05/10/2024 16:06:14] - SF_Genesis has been invoked with the following parameters:
argv[2]: 54:0:0:0
argv[5]: 12345
argv[6]: www_123
argv[7]: log=/log/
[Fri 05/10/2024 16:06:14] - Instructing the operating system to purge any existing cached data for device: '54:0:0:0'
[Fri 05/10/2024 16:06:19] - Issuing a discovery command for device: '54:0:0:0'
[Fri 05/10/2024 16:06:24] - Discovery command completed...
[Fri 05/10/2024 16:06:24] - Waiting 5 seconds for the system to settle...
[Fri 05/10/2024 16:06:29] - Device designation string '54:0:0:0' is mapped to node '/dev/sg2'
[Fri 05/10/2024 16:06:29] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/21808.12345.120.driveconfig
Serial No. = 12345
World Wide Name = www_123
[Fri 05/10/2024 16:06:29] - Successfully received the IDENTIFY data from the drive...
[Fri 05/10/2024 16:06:29] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Fri 05/10/2024 16:06:29] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Fri 05/10/2024 16:06:29] - file : /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/21808.12345.120.driveconfig does not exist or cannot open
[Fri 05/10/2024 16:06:29] - Error loading file : /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/21808.12345.120.driveconfig
[Fri 05/10/2024 16:06:29] - ERROR: Cannot read driveconfig file : /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/21808.12345.120.driveconfig
[Fri 05/10/2024 16:06:29] - End of Genesis manufacturing log.
[Fri 05/10/2024 16:06:29] - Exiting...
</Log_Body>
<Overall_Summary>
<Start_Time> Fri, 05/10/2024 @ 16:06:14 </Start_Time>
<End_Time> Fri, 05/10/2024 @ 16:06:29 </End_Time>
<Overall_Result> FAIL </Overall_Result>
<Exit_Code> (0x00100002:SF_SATA_INVALID_FILENAME_ERROR) </Exit_Code>
</Overall_Summary>
<Environment_Settings>
<Input_Parameters>
argv[2]: 54:0:0:0
argv[5]: 12345
argv[6]: www_123
argv[7]: log=/log/
</Input_Parameters>
<Log_File> SF_Genesis_Main_Log__Fri_05.10.2024_16.06.14.log </Log_File>
<Hostname> localhost.localdomain </Hostname>
<Host_IP_Address> 127.0.0.1 </Host_IP_Address>
<Port_Number> 2 </Port_Number>
<Device_Name> /dev/sg2 </Device_Name>
<SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
<SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
<SF_OS_Information> Linux 2.6.32-573.el6.i686 #1 SMP Thu Jul 23 12:37:35 UTC 2015 i686 </SF_OS_Information>
</Environment_Settings>
<Post_Processing_Device_Info>
<WWN_OUI> UNKNOWN </WWN_OUI>
<WWN_UniqueID> UNKNOWN </WWN_UniqueID>
<Serial_Number> UNKNOWN </Serial_Number>
<Model_Number> UNKNOWN </Model_Number>
<Firmware_Revision> UNKNOWN </Firmware_Revision>
<ROM_Revision> UNKNOWN </ROM_Revision>
<NAND_Page_Size> UNKNOWN </NAND_Page_Size>
<Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
<Logical_Sectors> UNKNOWN </Logical_Sectors>
<NAND_ID> UNKNOWN </NAND_ID>
<Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
<Flash_Device> UNKNOWN </Flash_Device>
</Post_Processing_Device_Info>
</Genesis_Log>
[Fri 05/10/2024 16:06:29] - Overall Result for Device: /dev/sg2 ****** FAIL ******
SSD 是金士顿 主控是2281 颗粒FT64G08UCM1-31 我用的是21808 不知道固件对不对 求大神指点
