查看: 14622|回复: 9
[慧荣] ASM235和1351区别在哪里
发表于 2021-3-11 12:23:45 来自手机浏览器 | 显示全部楼层 |阅读模式
500家元
请问大佬235和1351区别在哪里,235是1351的升级版吗,还有这两个相比较哪个更好一些,为什么现在市面是普遍是1351,很少有235
最佳答案
查看完整内容
同是USB3.1 10Gbps带宽,ASM235M支持tyepc输出,ASM1351则不支持
发表于 2021-3-11 12:23:46 | 显示全部楼层
回复
发表于 2021-3-11 13:33:28 | 显示全部楼层
235可以直接type-c,1351要type-c的话要转接芯片,性能上没有区别,好像是这样
回复
 楼主| 发表于 2021-3-11 14:29:47 来自手机浏览器 | 显示全部楼层
两个速度一样。只不过235可以A口可以C口对面
回复
发表于 2021-3-11 14:55:01 | 显示全部楼层
ASM235:
Features
       • Compliant with USB3.1 Specification Revision 1.0
       • Compliant with Type-C Specification Revision 1.1
       • Compliant with USB Specification Revision 2.0
       • Support USB Super-Speed Plus, USB Super-Speed, High-Speed and Full-Speed Operation
       • Support USB Mass Storage Class, Bulk-Only Transport Specification Revision 1.3
       • Support USB Attached SCSI Protocol Specification Revision 1.0
       • Compliant with Serial ATA Specification Revision 3.2
       • Serial ATA bus up to 6Gbps Signal bandwidth
       • Support Spread Spectrum Control of USB3.0 and SATA interface to improve the EMI performance
       • Support ATA/ATAPI Packet Command Set
       • Support ATA/ATAPI LBA48 addressing mode(28-bit LBA SATA devices are not supported due to OS limitations)
       • Integrated 8-bit micro-processor with embedded program RAM and ROM
       • Support SPI NVRAM for Vender Specific Application of USB Device Controller
       • Support multi-GPIO pins
       • Support programmable PWMs
       • Support 25 MHz with external crystal mode
       • Integrated two internal voltage regulator for IO power and Core
Package Type
       • Green Package 6x6 QFN 48L (Pb-free)
ASM1153:
Features
       •Compliant with  USB3.1 Specification  Revision 1.0
       •Compliant with USB  specification Revision 2.0
       •Support USB  super-speed plus. USB super-speed,High-speed and full -speed operation
       •Support USB mass storage class. bulk -only transport specification revision 1.3
       •Support  USB attached  scsi protocol specification revision 1.0
       •Compliant  with serial ATA specification revision  3.2
       •Seria  ATA bus up to 6Gbps  signal bandwidth
       •Support  ATA /ATAPI packet command  set
       •Support   speread spectrum  control of USB 3.0 a;nd SATA interface to improve the  EMI p erfomance
       •Support  ATA /ATAPILBA48 addressing mode
       •Integrated 8-bit micro -processor with embedded  program BAM  and  ROM
       •Support SPINVRAM for vender specific application of USB device controller
       •Support multi -GPIO pins
       •SUPPORT  programmable  PWMs
       •Support 25/30 MHZ with extemal  crystal  mode
       •integrated  two  intemal  voltage  regulator for lo power and  core
Package Type
回复
 楼主| 发表于 2021-3-11 23:06:54 来自手机浏览器 | 显示全部楼层
那为什么chipfancier C口是1351不是235呢
回复
发表于 2021-3-12 13:42:23 | 显示全部楼层
因为他是单c口,用的只是3.0对应的数据线部分。
回复
发表于 2021-3-16 18:11:57 | 显示全部楼层
ASM235CM原生支持Type-C,并且是新制程,发热比1351好蛮多
ASM1351不能原生支持Type-C,老制程发热大,烧开一滴水轻轻松松
回复
发表于 2021-3-19 08:30:42 | 显示全部楼层
1351物理上没办法实现双面满速,应该是单面3.0的,另一面2.0
回复
发表于 2021-5-25 13:01:29 来自手机浏览器 | 显示全部楼层
ASM1351不能原生支持Type-C,老制程发热大,烧开 ...
我的1153e自己动手换成了1351,插上电一会就发热了正常吗?插上去啥也没干
回复
GMT+8, 2024-6-15 14:36 , Processed in 0.218400 second(s), 11 queries , Redis On.
© 2006-2023 smzj.net
