查看: 6373|回复: 8
[SandForce] 威刚ADATA ASP900S7 2241开卡全家桶完美解决
发表于 2021-7-17 19:29:30 | 显示全部楼层 |阅读模式
求开卡ID 28044 31050 都开不出来 下载固件fail
参与人数 3家元 +25 收起 理由
路先森 + 9
Reset的萌新 + 6 原創內容
dogegg + 10 卵妹哥哥好帅
 楼主| 发表于 2021-7-17 20:11:51 | 显示全部楼层
单面BGA的是60075183 5300847754是30005
  1. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  2. SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
  3. SF_Core Library: v1.7.1.20130612-fc14-32bit
  4. Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
  5. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  6. [Sat 07/17/2021 20:25:49] - SF_Genesis has been invoked with the following parameters:
  7.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  8.                       argv[1]: -PROCESS_SSD
  9.                       argv[2]: 2:0:0:0
  10.                       argv[3]: /home/root1/1/unzip/1/1.mfp
  11.                       argv[4]: /home/root1/1/30005.123456.SP900_SAN.driveconfig
  12.                       argv[5]: 2E5220008288
  13.                       argv[6]: WE5220008288
  14.                       argv[7]: log=/home/root1/mpt/1.log
  15.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  16. [Sat 07/17/2021 20:25:49] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
  17. sh: 1: cannot create /proc/scsi/scsi: Directory nonexistent
  18. [Sat 07/17/2021 20:25:54] - Issuing a discovery command for device: '2:0:0:0'
  19. sh: 1: cannot create /proc/scsi/scsi: Directory nonexistent
  20. [Sat 07/17/2021 20:25:59] - Discovery command completed...
  21. [Sat 07/17/2021 20:25:59] - Waiting 5 seconds for the system to settle...
  22. [Sat 07/17/2021 20:26:04] - Device designation string '2:0:0:0' is mapped to node '/dev/sg2'
  23. [Sat 07/17/2021 20:26:04] - Proceeding to process SSD device with the following parameters:
  24.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  25.               DeviceName = /dev/sg2
  26.     MFP Package Filename = /home/root1/1/unzip/1/1.mfp
  27.       Configuration File = /home/root1/1/30005.123456.SP900_SAN.driveconfig
  28.               Serial No. = 2E5220008288
  29.          World Wide Name = WE5220008288
  30.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  31. [Sat 07/17/2021 20:26:04] - Successfully received the IDENTIFY data from the drive...
  32. [Sat 07/17/2021 20:26:04] - Validating Manufacturing Firmware Package: /home/root1/1/unzip/1/1.mfp
  33. [Sat 07/17/2021 20:26:49] - Successfully opened the package: /home/root1/1/unzip/1/1.mfp
  34. [Sat 07/17/2021 20:26:50] - file  /home/root1/1/30005.123456.SP900_SAN.driveconfig Loaded successfully
  35. [Sat 07/17/2021 20:26:51] - Warning:  Unable to query diagnostics information to perform power management settings check
  36. [Sat 07/17/2021 20:26:51] - B01 Power Management configuration request detected
  37. [Sat 07/17/2021 20:26:51] - Successfully extracted *.DriveConfig file: /home/root1/1/30005.123456.SP900_SAN.driveconfig
  38. [Sat 07/17/2021 20:26:51] - Extracted Config_ID: 1 (30005) in DriveConfig file: /home/root1/1/30005.123456.SP900_SAN.driveconfig
  39. [Sat 07/17/2021 20:26:51] - Extracted SerialOutputControl: 0
  40. [Sat 07/17/2021 20:27:25] - Searching for flashware image for configuration 30005
  41. [Sat 07/17/2021 20:27:25] - Manifest found for configuration 30005
  42. [Sat 07/17/2021 20:27:26] - Flashware image extracted: 30005_fw_cl_mlc_MIC_128Gb_MT29F128G08CBCAB_1Q_2C_1D_PP_R02216_s512.vic
  43. [Sat 07/17/2021 20:27:26] - Searching for manufacturing image for configuration 30005
  44. [Sat 07/17/2021 20:27:26] - Manifest found for configuration 30005
  45. [Sat 07/17/2021 20:27:26] - Manufacturing image extracted: 30005_mf_mlc_MIC_128Gb_MT29F128G08CBCAB_1Q_2C_1D_PP_R02216_s512.vic
  46. [Sat 07/17/2021 20:27:26] - Proceeding in ROM mode, download feature 3...
  47. [Sat 07/17/2021 20:27:26] - Successfully downloaded MFB to the drive...
  48. [Sat 07/17/2021 20:27:26] - Waiting (5 sec) for the drive to settle...
  49. [Sat 07/17/2021 20:27:31] - Successfully received the IDENTIFY data from the drive...
  50. [Sat 07/17/2021 20:27:31] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
  51. [Sat 07/17/2021 20:27:31] - Successfully enabled SMART capabilities...
  52. [Sat 07/17/2021 20:27:33] - Successfully issued a diagnostic unlock...
  53. [Sat 07/17/2021 20:27:34] - Performing the flash test of block 0 (0x0000)...
  54. [Sat 07/17/2021 20:27:37] - Flash Test Results:
  55. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  56. -----------------------------------------------------------------------------
  57. Flash Test Parameters:
  58. -----------------------------------------------------------------------------
  59.                Block Count: 0
  60.                 Page Count: 1
  61.                  Bus Count: 1
  62.         Chip Enabled Count: 2
  63.                  Die Count: 1
  64.                 Lane Count: 4
  65.                Plane Count: 2
  66. -----------------------------------------------------------------------------
  67. Results Notes:
  68. -----------------------
  69.    N1 - At least one page tested and passed with no bit errors.
  70.    N2 - No test data available.  Test may have aborted, or failed during the testing.
  71.    N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
  72.    N4 - At least  one erased page tested had bit error rate greater than half the correction power.
  73.    N5 - Walking zeros test failed.
  74.    N6 - Walking ones test failed.
  75.    N7 - Block contained factory bad block markings and testing was skipped.
  76.    N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
  77.    N9 - Block in plane 0 was marked as a factory bad block.
  78.   N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  79.   N11 - Block in plane 1 was marked as a factory bad block.
  80. -----------------------------------------------------------------------------
  81. +------+------+------+------+--------+--------------------------------------------+---------+
  82. | Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
  83. +------+------+------+------+--------+--------------------------------------------+---------+
  84. | 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
  85. +------+------+------+------+--------+--------------------------------------------+---------+
  86. | 0    | 0    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
  87. +------+------+------+------+--------+--------------------------------------------+---------+
  88. | 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
  89. +------+------+------+------+--------+--------------------------------------------+---------+
  90. | 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  91. +------+------+------+------+--------+--------------------------------------------+---------+
  92. | 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
  93. +------+------+------+------+--------+--------------------------------------------+---------+
  94. | 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
  95. +------+------+------+------+--------+--------------------------------------------+---------+
  96. | 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
  97. +------+------+------+------+--------+--------------------------------------------+---------+
  98. | 0    | 1    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
  99. +------+------+------+------+--------+--------------------------------------------+---------+
  100. -----------------------------------------------------------------------------
  101.   Total Number of test results: 8
  102.             Number of failures: 0
  103.          Number of Passed with warnings: 7
  104.       No. Passed without warnings: 1
  105. -----------------------------------------------------------------------------
  106. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  107. [Sat 07/17/2021 20:27:37] - Performing the FORMAT Command with the following parameters:
  108. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  109.          MemoryWearCycleCapability = 0
  110.               CurrentPE_CycleCount = 0
  111.                      LifeInSeconds = 0
  112.                    LogicalCapacity = 234441648
  113.                         SectorSize = 512
  114.              SectorAlignmentOffset = 0
  115.                   ExpectedMemoryID = 33836 (0x842C)
  116.                    ExpectedNumDies = 0
  117.                SerialOutputControl = 0
  118.                            Time[8] = 0x0000000000000000
  119.             MiscFlag_Erase_R_Block = 0
  120.      MiscFlag_PanicHandlingEnabled = 0
  121.         MiscFlag_PanicOnSATA_Error = 0
  122.   MiscFlag_WriteThrottlingTestMode = 0
  123.       MiscFlag_DisableUserBandECCX = 1
  124.                         L_PageSize = 0
  125.                         E_PageSize = 0
  126.               ErrorCorrectionPower = 0
  127.       ConfigDeviceReadDisturbCount = 0
  128.    ConfigDeviceReadDisturbCountLow = 0
  129.                   ExtraOptions_0_1 = 0
  130. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  131. [Sat 07/17/2021 20:27:45] - FORMAT command completed...
  132. [Sat 07/17/2021 20:27:45] - Waiting (2 sec) for the drive to settle...
  133. [Sat 07/17/2021 20:27:47] - Setting up the stamp information through CDU command...
  134. [Sat 07/17/2021 20:27:50] - Waiting (2 sec) for the drive to settle...
  135. [Sat 07/17/2021 20:27:52] - Downloading the flashware to the drive... feature 3
  136. [Sat 07/17/2021 20:28:09] - Successfully downloaded flashware to the drive...
  137. [Sat 07/17/2021 20:28:09] - Waiting (15 sec) for the drive to settle...
  138. [Sat 07/17/2021 20:28:24] - Successfully received the IDENTIFY data from the drive...
  139. [Sat 07/17/2021 20:28:24] - Firmware revision reported to be: 'NC      '
  140. [Sat 07/17/2021 20:28:24] - Enabling SMART support...
  141. [Sat 07/17/2021 20:28:24] - Issuing a diagnostic unlock to the drive...
  142. [Sat 07/17/2021 20:28:27] - Setting up Max LBA settings...
  143. [Sat 07/17/2021 20:28:30] - Change of sector size is not required, sector size is already set to 512
  144. [Sat 07/17/2021 20:28:31] - Setting the serial number of the drive to: 2E5220008288
  145. [Sat 07/17/2021 20:28:33] - Setting the World Wide Name (WWN) of the drive to: WE5220008288
  146. [Sat 07/17/2021 20:28:36] - Processing completed for device: 2E5220008288
  147. [Sat 07/17/2021 20:28:36] - Begin collecting the device post-process log/information
  148. [Sat 07/17/2021 20:28:36] - Creating the Log Bundle...
  149. [Sat 07/17/2021 20:28:36] - Plain text identify log created
  150. [Sat 07/17/2021 20:28:37] - Plain text diagnostics identify log created
  151. [Sat 07/17/2021 20:28:39] - Plain text diagnostics information log created
  152. [Sat 07/17/2021 20:28:40] - Plain text format information log created
  153. [Sat 07/17/2021 20:28:40] - Plain text SMART log created
  154. [Sat 07/17/2021 20:28:41] - Plain text manufacturing defect list log created
  155. [Sat 07/17/2021 20:28:42] - Plain text grown defect list log created
  156. [Sat 07/17/2021 20:28:43] - Plain text panic directory listing log created
  157. [Sat 07/17/2021 20:28:43] - Completed collecting all plain text log files.
  158. [Sat 07/17/2021 20:28:43] - End of logs and information collection
  159. [Sat 07/17/2021 20:28:44] - Applying the remaining ConfigUniqueDrive settings...
  160. [Sat 07/17/2021 20:28:45] - Setting Customer ID with value : 123456
  161. [Sat 07/17/2021 20:28:45] - Setting Diagnostic Unlock Key with value supplied
  162. [Sat 07/17/2021 20:28:45] - Setting Max LBA Count for 4096 Plus DIFF Sectors with value : 0
  163. [Sat 07/17/2021 20:28:45] - Setting Max LBA Count for 4096 Sectors with value : 0
  164. [Sat 07/17/2021 20:28:45] - Setting Max LBA Count for 512B Plus DIFF Sectors with value : 0
  165. [Sat 07/17/2021 20:28:45] - Setting Max LBA Count for 512B Sectors with value : 0
  166. [Sat 07/17/2021 20:28:45] - Setting Max LBA Count for 520B Sectors with value : 0
  167. [Sat 07/17/2021 20:28:45] - Setting Max LBA Count for 524B Sectors with value : 0
  168. [Sat 07/17/2021 20:28:45] - Setting Max LBA Count for 528B Sectors with value : 0
  169. [Sat 07/17/2021 20:28:45] - Setting Model No. with value : Samsung SSD 850 EVO
  170. [Sat 07/17/2021 20:28:45] - Setting Power Management Version with value : 0
  171. [Sat 07/17/2021 20:28:45] - Total of 1 valid MaxLBA settings were setup to be written to the drive.
  172. [Sat 07/17/2021 20:28:47] - Successfully applied the remaining ConfigUniqueDrive settings...
  173. [Sat 07/17/2021 20:28:47] - Issuing an IdleImmediate command to the drive...
  174. [Sat 07/17/2021 20:28:48] - Not an Enterprise drive,so, continuing without setting master password..
  175. [Sat 07/17/2021 20:28:48] - End of Genesis manufacturing log.
  176. [Sat 07/17/2021 20:28:48] - Exiting...
  177. [Sat 07/17/2021 20:28:48] - Overall Result for Device: /dev/sg2 ****** PASS ******
复制代码
 楼主| 发表于 2021-7-17 21:26:01 | 显示全部楼层
ASP900 128GB NW674开卡ID 31026
  1. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  6. [Sat 07/17/2021 21:36:48] - SF_Genesis has been invoked with the following parameters:
  9.                       argv[2]: 2:0:0:0
  11.                       argv[4]: /home/root1/1/31026.123456.ASP900.driveconfig
  16. [Sat 07/17/2021 21:36:48] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
  18. [Sat 07/17/2021 21:36:53] - Issuing a discovery command for device: '2:0:0:0'
  20. [Sat 07/17/2021 21:36:58] - Discovery command completed...
  21. [Sat 07/17/2021 21:36:58] - Waiting 5 seconds for the system to settle...
  22. [Sat 07/17/2021 21:37:03] - Device designation string '2:0:0:0' is mapped to node '/dev/sg2'
  23. [Sat 07/17/2021 21:37:03] - Proceeding to process SSD device with the following parameters:
  27.       Configuration File = /home/root1/1/31026.123456.ASP900.driveconfig
  31. [Sat 07/17/2021 21:37:03] - Successfully received the IDENTIFY data from the drive...
  32. [Sat 07/17/2021 21:37:03] - Validating Manufacturing Firmware Package: /home/root1/1/unzip/1/1.mfp
  33. [Sat 07/17/2021 21:37:47] - Successfully opened the package: /home/root1/1/unzip/1/1.mfp
  34. [Sat 07/17/2021 21:37:47] - file  /home/root1/1/31026.123456.ASP900.driveconfig Loaded successfully
  35. [Sat 07/17/2021 21:37:48] - Warning:  Unable to query diagnostics information to perform power management settings check
  36. [Sat 07/17/2021 21:37:48] - B01 Power Management configuration request detected
  37. [Sat 07/17/2021 21:37:48] - Successfully extracted *.DriveConfig file: /home/root1/1/31026.123456.ASP900.driveconfig
  38. [Sat 07/17/2021 21:37:48] - Extracted Config_ID: 1 (31026) in DriveConfig file: /home/root1/1/31026.123456.ASP900.driveconfig
  39. [Sat 07/17/2021 21:37:48] - Extracted SerialOutputControl: 0
  40. [Sat 07/17/2021 21:38:12] - Searching for flashware image for configuration 31026
  41. [Sat 07/17/2021 21:38:12] - Manifest found for configuration 31026
  42. [Sat 07/17/2021 21:38:12] - Flashware image extracted: 31026_fw_cl_mlc_MIC_128Gb_MT29F128G08CBCAB_1Q_2C_1D_S_PP_R02631_s512.vic
  43. [Sat 07/17/2021 21:38:12] - Searching for manufacturing image for configuration 31026
  44. [Sat 07/17/2021 21:38:12] - Manifest found for configuration 31026
  45. [Sat 07/17/2021 21:38:12] - Manufacturing image extracted: 31026_mf_mlc_MIC_128Gb_MT29F128G08CBCAB_1Q_2C_1D_S_PP_R02631_s512.vic
  46. [Sat 07/17/2021 21:38:12] - Proceeding in ROM mode, download feature 3...
  47. [Sat 07/17/2021 21:38:13] - Successfully downloaded MFB to the drive...
  48. [Sat 07/17/2021 21:38:13] - Waiting (5 sec) for the drive to settle...
  49. [Sat 07/17/2021 21:38:18] - Successfully received the IDENTIFY data from the drive...
  50. [Sat 07/17/2021 21:38:18] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
  51. [Sat 07/17/2021 21:38:18] - Successfully enabled SMART capabilities...
  52. [Sat 07/17/2021 21:38:20] - Successfully issued a diagnostic unlock...
  53. [Sat 07/17/2021 21:38:21] - Performing the flash test of block 0 (0x0000)...
  54. [Sat 07/17/2021 21:38:24] - Flash Test Results:
  59.                Block Count: 0
  60.                 Page Count: 1
  61.                  Bus Count: 1
  63.                  Die Count: 1
  64.                 Lane Count: 4
  65.                Plane Count: 2
  67. Results Notes:
  88. | 0    | 0    | 0    | 2    | 0x0003 | N1,N3                                      | WARNING |
  90. | 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  92. | 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
  96. | 0    | 1    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
  98. | 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  103.          Number of Passed with warnings: 6
  104.       No. Passed without warnings: 2
  107. [Sat 07/17/2021 21:38:24] - Performing the FORMAT Command with the following parameters:
  112.                    LogicalCapacity = 250069680
  124.                         L_PageSize = 0
  125.                         E_PageSize = 0
  131. [Sat 07/17/2021 21:38:28] - FORMAT command completed...
  132. [Sat 07/17/2021 21:38:28] - Waiting (2 sec) for the drive to settle...
  133. [Sat 07/17/2021 21:38:30] - Setting up the stamp information through CDU command...
  134. [Sat 07/17/2021 21:38:34] - Waiting (2 sec) for the drive to settle...
  135. [Sat 07/17/2021 21:38:36] - Downloading the flashware to the drive... feature 3
  136. [Sat 07/17/2021 21:38:44] - Successfully downloaded flashware to the drive...
  137. [Sat 07/17/2021 21:38:44] - Waiting (15 sec) for the drive to settle...
  138. [Sat 07/17/2021 21:38:59] - Successfully received the IDENTIFY data from the drive...
  139. [Sat 07/17/2021 21:38:59] - Firmware revision reported to be: 'NC      '
  140. [Sat 07/17/2021 21:38:59] - Enabling SMART support...
  141. [Sat 07/17/2021 21:38:59] - Issuing a diagnostic unlock to the drive...
  142. [Sat 07/17/2021 21:39:02] - Setting up Max LBA settings...
  143. [Sat 07/17/2021 21:39:05] - Change of sector size is not required, sector size is already set to 512
  144. [Sat 07/17/2021 21:39:06] - Setting the serial number of the drive to: 2E5220008288
  145. [Sat 07/17/2021 21:39:08] - Setting the World Wide Name (WWN) of the drive to: WE5220008288
  146. [Sat 07/17/2021 21:39:11] - Processing completed for device: 2E5220008288
  147. [Sat 07/17/2021 21:39:11] - Begin collecting the device post-process log/information
  148. [Sat 07/17/2021 21:39:11] - Creating the Log Bundle...
  149. [Sat 07/17/2021 21:39:11] - Plain text identify log created
  150. [Sat 07/17/2021 21:39:12] - Plain text diagnostics identify log created
  151. [Sat 07/17/2021 21:39:14] - Plain text diagnostics information log created
  152. [Sat 07/17/2021 21:39:15] - Plain text format information log created
  153. [Sat 07/17/2021 21:39:15] - Plain text SMART log created
  154. [Sat 07/17/2021 21:39:16] - Plain text manufacturing defect list log created
  155. [Sat 07/17/2021 21:39:17] - Plain text grown defect list log created
  156. [Sat 07/17/2021 21:39:18] - Plain text panic directory listing log created
  157. [Sat 07/17/2021 21:39:18] - Completed collecting all plain text log files.
  158. [Sat 07/17/2021 21:39:18] - End of logs and information collection
  159. [Sat 07/17/2021 21:39:19] - Applying the remaining ConfigUniqueDrive settings...
  160. [Sat 07/17/2021 21:39:20] - Setting Customer ID with value : 123456
  161. [Sat 07/17/2021 21:39:20] - Setting Diagnostic Unlock Key with value supplied
  162. [Sat 07/17/2021 21:39:20] - Setting Max LBA Count for 4096 Plus DIFF Sectors with value : 0
  163. [Sat 07/17/2021 21:39:20] - Setting Max LBA Count for 4096 Sectors with value : 0
  164. [Sat 07/17/2021 21:39:20] - Setting Max LBA Count for 512B Plus DIFF Sectors with value : 0
  165. [Sat 07/17/2021 21:39:20] - Setting Max LBA Count for 512B Sectors with value : 0
  166. [Sat 07/17/2021 21:39:20] - Setting Max LBA Count for 520B Sectors with value : 0
  167. [Sat 07/17/2021 21:39:20] - Setting Max LBA Count for 524B Sectors with value : 0
  168. [Sat 07/17/2021 21:39:20] - Setting Max LBA Count for 528B Sectors with value : 0
  169. [Sat 07/17/2021 21:39:20] - Setting Model No. with value : Samsung SSD 850 EVO
  170. [Sat 07/17/2021 21:39:20] - Setting Power Management Version with value : 0
  171. [Sat 07/17/2021 21:39:20] - Total of 1 valid MaxLBA settings were setup to be written to the drive.
  172. [Sat 07/17/2021 21:39:23] - Successfully applied the remaining ConfigUniqueDrive settings...
  173. [Sat 07/17/2021 21:39:23] - Issuing an IdleImmediate command to the drive...
  174. [Sat 07/17/2021 21:39:23] - Not an Enterprise drive,so, continuing without setting master password..
  175. [Sat 07/17/2021 21:39:23] - End of Genesis manufacturing log.
  176. [Sat 07/17/2021 21:39:23] - Exiting...
  177. [Sat 07/17/2021 21:39:23] - Overall Result for Device: /dev/sg2 ****** PASS ******
复制代码
发表于 2021-7-18 00:34:10 来自手机浏览器 | 显示全部楼层
感谢分享,也分享一下
 楼主| 发表于 2021-7-18 14:37:52 | 显示全部楼层
华友朱总 发表于 2021-7-18 00:34
感谢分享,也分享一下
知道ASP900 TSOP双面的是什么ID吗
发表于 2021-7-19 01:22:32 | 显示全部楼层
CBAAB CFAAB CCME
 楼主| 发表于 2021-7-23 14:28:52 | 显示全部楼层
问题是2241 我找了好多固件包都找不到啊
发表于 2021-7-24 00:25:04 | 显示全部楼层
用2281的工具开2241 只是开卡的时候选2241的ID
 楼主| 发表于 2021-7-28 14:15:28 来自手机浏览器 | 显示全部楼层
2241没这个id 工具都是一样的 有没有sf1222的固件
GMT+8, 2025-6-19 05:50 , Processed in 0.124801 second(s), 11 queries , Redis On.
