查看: 9498|回复: 44
[安防] 拆个海康威视所谓监控专用交换机 空荡荡的什么也没有
发表于 2020-5-16 22:29:15 来自手机浏览器 | 显示全部楼层 |阅读模式
五口迷你交换机 说是监控专用
也感叹现在的科技
日新月异
一个芯片就解决了全部问题
不知道是好是坏
但是总感觉欠缺一点点什么
参与人数 2家元 +26 收起 理由
digittjau + 20 以資鼓勵
hongo + 6 原創內容
发表于 2021-4-28 13:20:28 | 显示全部楼层
兄弟30-40元的交换机想怎么样呢?能用死机就很好的了
发表于 2020-12-13 18:08:49 来自手机浏览器 | 显示全部楼层
这做工,真是节约到极致了。一个电解电容都没有。(感觉越来越寒酸)
开门,查水表的!
发表于 2020-12-13 17:15:56 | 显示全部楼层
都省成单面板了.:sweat:
发表于 2020-12-13 15:14:17 来自手机浏览器 | 显示全部楼层
IP178G 8 Port 10/100M Ethernet Integrated Switch
(85nm /Extreme Low Power, PWMT® and AFT®)
General Description :
IP178G is fabricated with advanced CMOS (85nm/Low Power) technology and only requires a 3.3V single power supply for saving BOM cost. This feature makes IP178G consumes very low power, such as the full load operation (100Mbps_FDX x8) and embedded LDO, overall power consumption only takes 0.87w.
IP178G also supports Power Management Tool (PWMT®) for IEEE 802.3az, APS, WOL+ and PWD for Green Power. While two link devices have no IEEE 802.3az capability, IP178G use WOL+ to change link from 100Mbps to 10Mbps for saving power.
The PWD of IP178G is designed for power down switch immediately by pushing a button, user don’t plug out the power adapter. Push the button again, it will power on immediately.
Except Low Power and Rich Power Saving method, IP178G supports AFT® for saving Customer Testing Cost. By using a push bottom and cables, IP178G will Auto test completely by itself.
Feature :
8 port Embedded 10/100 PHY Switch Controller
Support 8 100baseTX or 6 100base TX + 2 FX
Support Auto MDI-MDIX function
- APS, auto-power saving while link-off
- IEEE 802.3az protocol based power saving & 10Mbps Te for 10Mbps                                          - WOL+®, light traffic power saving
- PWD, force-off power saving
Support Auto Factory Test (AFT®)
Single Power 3.3V supply
Built in Vcore Regulator
Two Priority queues per port
Support 802.1p & DiffServ based QoS
QoS
- Port base
- 802.1p
- IP DiffServ IPV4/IPV6
- TCP/UDP port number
- Pins configure ports priority (VIP port)
Support max forwarding packet length 1552/1536 bytes option
Support port mirror function
Support 1k MAC address
Support broadcast storm protection
Support  port trunking (LACP)
Support 16 VLAN (IEEE Std 802.1q)
- Port-based/Tagged-based VLAN
- Support insert, remove tag
Built-in 50 ohm resistors for simplifying BOM
85nm Process
Package and operation temperature
IP178G: 68 Pin QFN, 0~70℃
Application :
8 port 10/100 SOHO Switch
6TX+2FX Switch or 7TX + 1FX Switch
拷贝自老论坛
bbs.mydigit.cn/read.php?tid=1817535
发表于 2020-12-13 15:08:16 来自手机浏览器 | 显示全部楼层
为什么老死机呢?我们厂里一个节点装上新的8口的这个海康威视的交换机几乎半天都撑不住,频繁死机。量过交流电,直流电,几乎没波动。换上老的fast八口的交换机能稳定两个月。
发表于 2020-6-24 10:20:16 | 显示全部楼层
腾达代工的,这个还能用的吧,用过几个,目前还在稳定使用中,是腾达的,不是海康的
发表于 2020-6-24 09:04:44 | 显示全部楼层
到现在了,还出5口,其实与8口成本差不多了,可以不考虑出5口了
发表于 2020-6-24 08:58:08 | 显示全部楼层
比TP还干净啊!!哈哈!!
发表于 2020-6-24 08:52:46 | 显示全部楼层
就是贴牌的,,要买真正的交换机还是买 Huawei 、h3c 、cisco这些吧,
就是价格贵:shocked:
发表于 2020-6-24 07:16:57 | 显示全部楼层
linjianking 发表于 2020-5-17 01:26
感觉边TP-link都不如
赤裸裸的炫耀五笔
 楼主| 发表于 2020-6-23 23:55:53 来自手机浏览器 | 显示全部楼层
拿来局域网上网  接两三台电脑 几天就是死机 连续几个了 看来也是垃圾货
 楼主| 发表于 2020-6-20 02:25:17 来自手机浏览器 | 显示全部楼层
799946503 发表于 2020-6-3 13:06
这种的固件是特殊定制的
更注重稳定性,性能上可以进行让步
甚至有可能还固化了VLAN功能 ...
没有vlan功能 我拿了一个来分口接两个电脑上网 几天后交换机居然死机 电脑无法上网 要重启交换机
 楼主| 发表于 2020-6-20 02:23:58 来自手机浏览器 | 显示全部楼层
cp2000 发表于 2020-6-3 12:38
从去年到现在,这种交换机都是针对渠道销售商订货满额赠送的,所以做工用料那块好不到哪里去,毕竟成本要控 ...
他打上海康牌子就要毁了
 楼主| 发表于 2020-6-20 02:22:23 来自手机浏览器 | 显示全部楼层
高级会员 发表于 2020-5-17 22:50
确定是真的?
代理拿的
 楼主| 发表于 2020-6-20 02:21:50 来自手机浏览器 | 显示全部楼层
hongo 发表于 2020-5-17 08:43
为什么迷你交换机都是5口的,而不是4口、8口?
有一口留给上联
发表于 2020-6-3 14:38:22 | 显示全部楼层
enjoylism 发表于 2020-5-24 16:37
他高端的POE交换机当然不是会这种货色,这货才15元
一分价钱一分货
发表于 2020-6-3 13:06:28 | 显示全部楼层
这种的固件是特殊定制的
更注重稳定性,性能上可以进行让步
甚至有可能还固化了VLAN功能
发表于 2020-6-3 12:45:55 | 显示全部楼层
pmp4561705 发表于 2020-5-20 15:30
我还想买海康POE交换机呢,这一看,不敢买了,
从去年到现在,这种交换机都是针对渠道销售商订货满额赠送的,所以做工用料那块好不到哪里去,毕竟成本要控制。
发表于 2020-6-3 12:38:08 | 显示全部楼层
从去年到现在,这种交换机都是针对渠道销售商订货满额赠送的,所以做工用料那块好不到哪里去,毕竟成本要控制。:victory::lol:
GMT+8, 2025-9-5 13:37 , Processed in 0.156000 second(s), 15 queries , Gzip On, Redis On.
