查看: 2367|回复: 0
用那actions一件编译redpill引导
发表于 2021-9-30 14:36:30 | 显示全部楼层 |阅读模式
优点:云编译(我没linux)
大佬的作业:https://github.com/guigeng/redpill-tool-chain/
1先点fork
2然后点Settings 创建几个secrets
  DS918P_PID: ${{ secrets.DS918P_PID }}
  DS918P_VID: ${{ secrets.DS918P_VID }}
  DS918P_SN: ${{ secrets.DS918P_SN }}
  DS918P_MAC: ${{ secrets.DS918P_MAC }}
3按需修改,我只用918; 不改应该也行,后面修
重点:末尾六行
on:
  release:
    types: [published]
  workflow_dispatch:
jobs:
  # This workflow contains a single job called "build"
  build:
    # The type of runner that the job will run on
    runs-on: ubuntu-latest
    # Steps represent a sequence of tasks that will be executed as part of the job
    steps:
      # Checks-out your repository under $GITHUB_WORKSPACE, so your job can access it
      - uses: actions/checkout@v2
        with:
          fetch-depth: 0
      - name: edit ds918 config
        env:
          #DS918P_MAC2: ${{ secrets.DS918P_MAC2 }}
        run: |
          chmod +x redpill_tool_chain.sh
          sed -i "s/1234XXX123/${DS918P_SN}/g" apollolake_user_config.json
          sed -i "s/XXYYXXYYXXYY/${DS918P_MAC}/g" apollolake_user_config.json
          sed -i "s/0x46f4/${DS918P_VID}/g" apollolake_user_config.json
          sed -i "s/0x0001/${DS918P_PID}/g" apollolake_user_config.json
      - name: build ds918 7.0.1
        run: |
          ./redpill_tool_chain.sh build apollolake-7.0.1-42218
      - name: create ds918 7.0.1 image
        run: |
          ./redpill_tool_chain.sh auto apollolake-7.0.1-42218
      - name : Upload packages
        uses: actions/upload-artifact@master
        if: always()
        with:
          path: images/*.img
超重点:如果弄secrets,得自用自下,下完记删除
GMT+8, 2025-7-26 21:33 , Processed in 0.124801 second(s), 12 queries , Redis On.
