查看: 3094|回复: 10
[SandForce] 这是怎么回事,难道ID选错了?大佬们帮忙看看
发表于 2020-2-29 21:16:10 | 显示全部楼层 |阅读模式
威刚的2241VB4,镁光NW674芯片。这是开卡的log?xml version = "1.0"?><Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Sat, 02/29/2020 @ 17:17:03
                  End Time: Sat, 02/29/2020 @ 17:17:47
             OverallResult: FAIL
                  ExitCode: (0x10090008:SF_GENESIS_FORMAT_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 3:0:0:0
                  argv[3]: /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31050.123456.edriveconfig
                  argv[5]: 123456789
                  argv[6]: 234567
                  argv[7]: LOG=/root/log/123456789_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/log/123456789_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sat 02/29/2020 17:17:03] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 3:0:0:0
                      argv[5]: 123456789
                      argv[6]: 234567
[Sat 02/29/2020 17:17:03] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Sat 02/29/2020 17:17:08] - Issuing a discovery command for device: '3:0:0:0'
[Sat 02/29/2020 17:17:14] - Discovery command completed...
[Sat 02/29/2020 17:17:14] - Waiting 5 seconds for the system to settle...
[Sat 02/29/2020 17:17:19] - Device designation string '3:0:0:0' is mapped to node '/dev/sg1'
[Sat 02/29/2020 17:17:19] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31050.123456.edriveconfig
              Serial No. = 123456789
         World Wide Name = 234567
[Sat 02/29/2020 17:17:19] - Successfully received the IDENTIFY data from the drive...
[Sat 02/29/2020 17:17:19] - Validating Manufacturing Firmware Package: /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Sat 02/29/2020 17:17:24] - Successfully opened the package: /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Sat 02/29/2020 17:17:24] - File : /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31050.123456.edriveconfig in processing ...
[Sat 02/29/2020 17:17:24] - file  /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31050.123456.edriveconfig Loaded successfully
[Sat 02/29/2020 17:17:24] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sat 02/29/2020 17:17:24] - B01 Power Management configuration request detected
[Sat 02/29/2020 17:17:24] - Successfully extracted *.DriveConfig file: /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31050.123456.edriveconfig
[Sat 02/29/2020 17:17:24] - Extracted Config_ID: 1 (31050) in DriveConfig file: /root/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31050.123456.edriveconfig
[Sat 02/29/2020 17:17:24] - Extracted SerialOutputControl: 0
[Sat 02/29/2020 17:17:24] - Searching for flashware image for configuration 31050
[Sat 02/29/2020 17:17:24] - Manifest found for configuration 31050
[Sat 02/29/2020 17:17:24] - Flashware image extracted: 31050_fw_cl_mlc_Micron_128Gb_19bit_MT29F128G08CBEBB_1Q_2C_1D_S_PP_R03079_s512.vic
[Sat 02/29/2020 17:17:24] - Searching for manufacturing image for configuration 31050
[Sat 02/29/2020 17:17:24] - Manufacturing image extracted: 31050_mf_mlc_Micron_128Gb_19bit_MT29F128G08CBEBB_1Q_2C_1D_S_PP_R03079_s512.vic
[Sat 02/29/2020 17:17:24] - Proceeding in ROM mode, download feature 3...
[Sat 02/29/2020 17:17:24] - Successfully downloaded MFB to the drive...
[Sat 02/29/2020 17:17:24] - Waiting (5 sec) for the drive to settle...
[Sat 02/29/2020 17:17:29] - Successfully received the IDENTIFY data from the drive...
[Sat 02/29/2020 17:17:29] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Sat 02/29/2020 17:17:29] - Successfully enabled SMART capabilities...
[Sat 02/29/2020 17:17:32] - Successfully issued a diagnostic unlock...
[Sat 02/29/2020 17:17:33] - Performing the flash test of block 0 (0x0000)...
[Sat 02/29/2020 17:17:35] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 0    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 5
      No. Passed without warnings: 3
[Sat 02/29/2020 17:17:35] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 33836 (0x842C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Sat 02/29/2020 17:17:47] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Sat 02/29/2020 17:17:47] - End of Genesis manufacturing log.
[Sat 02/29/2020 17:17:47] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Sat, 02/29/2020 @ 17:17:03 </Start_Time>
        <End_Time> Sat, 02/29/2020 @ 17:17:47 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090008:SF_GENESIS_FORMAT_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 3:0:0:0
                  argv[5]: 123456789
                  argv[6]: 234567
        </Input_Parameters>
        <Log_File> /root/log/123456789_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Sat 02/29/2020 17:17:47] - Overall Result for Device: /dev/sg1 ****** FAIL ******
发表于 2020-3-1 01:15:05 | 显示全部楼层
去SATA接口重新开一次试试  别太相信虚拟机  电压不稳定
 楼主| 发表于 2020-3-1 12:28:22 | 显示全部楼层
是独立电脑主机,直接sata
发表于 2020-3-1 13:24:20 | 显示全部楼层
看你颗粒测试过了 那就应该是在70-80这样的错误 可能是写保护设置
 楼主| 发表于 2020-3-1 19:00:24 | 显示全部楼层
我改下试试
发表于 2020-3-1 19:08:24 | 显示全部楼层
你的颗粒不太行了,威刚一般用的是无保护,你改一下设置试试,另外听楼上的,强烈反对虚拟机开卡,总是因为桥或者什么问题出现莫名其妙错误
发表于 2020-3-3 11:16:02 | 显示全部楼层
谢谢大佬提醒,关了写保护设置开出来了,颗粒也的确不大行了,93%的寿命
发表于 2020-3-3 13:31:40 | 显示全部楼层
谷歌一下 发表于 2020-3-3 11:16
谢谢大佬提醒,关了写保护设置开出来了,颗粒也的确不大行了,93%的寿命 ...
怎么看颗粒寿命的?这个我还不会
发表于 2020-3-3 19:25:50 | 显示全部楼层
丶陪妳看流星 发表于 2020-3-3 13:31
怎么看颗粒寿命的?这个我还不会
CrystalDiskInfo里的健康度
发表于 2020-3-3 21:23:25 | 显示全部楼层
怎么看颗粒寿命的?这个我还不会
一个是看log里面的坏块数,一个是用预测表粗略判断,好的颗粒全部N1,有问题的什么N都出现,当然有例外,Intel颗粒全部N3也不要紧,但是出现N5就比较麻烦
发表于 2020-3-3 22:26:00 | 显示全部楼层
N1-至少测试并通过了一个没有位错误的页面。
N2-没有可用的测试数据。测试可能已中止,或者在测试期间失败。
N3-至少有一页被测试,错误小于或等于ECC校正功率范围的一半。
N4-至少有一个被测试的被擦除页的误比特率大于校正功率的一半。
N5-行走零点测试失败。
步行者测试失败。
N7-包含工厂坏块标记的块和测试被跳过。
N8-至少有一页被测试,其误比特率大于平面0上的校正功率。
平面0中的N9块被标记为工厂坏块。
N10-至少测试了一页,其误比特率大于平面1上的校正功率。
N11-平面1中的块被标记为工厂坏块。
有条件的话可以拆下颗粒上下测试座清空。
目测颗粒体质不行了
GMT+8, 2025-5-20 13:28 , Processed in 0.156000 second(s), 12 queries , Redis On.
