查看: 1024|回复: 5
[软件] WizTree v4.22 简体中文便携版,通过 MFT 检索硬盘中大文件
发表于 2024-11-11 11:12:08 | 显示全部楼层 |阅读模式
功能描述
通过读取 NTFS 文件系统的主文件表(MFT,Master File Table),实现文件迅速排序
支持将扫描结果,以 CSV 文件分享导入,支持将主文件表转储成 .MFT 文件分享导入
支持以 SpaceSniffer 用颜色区块,显示占用情况,支持通过文件类型按占用直观排序
支持过滤器,精确排查指定条件下的占用情况 https://diskanalyzer.com/guide#search
授权协议
个人用途免费,商业用途收费
个人商业用途最低售价 10 美元
https://diskanalyzer.com/donate
软件实测
更新日志
    v4.22
  • Fixed issue with file system monitoring in 4.21 which could cause deleted files not to be detected
  • Fixed scaling issue with color selection form
  • Korean translation updated
  • Swedish translation updated
    v4.21
  • Improved threading when in non Admin mode and when scanning non NTFS drives/network drives/folders
    resulting in more than 4x faster scanning of SSD drives
  • Reserved Space is now displayed for NTFS volumes
    This is space reserved for the Windows operating system and can be quite significant for drives with Windows installed
    It also accounts for most of the difference between the total allocated space calculated by WizTree and the  “ space used ”  reported by Windows
    The remaining difference is made up of other NTFS file system data (such as directory indexes) which do not appear in the WizTree scan results
  • File grouping size can now be set via Options->Tweaks->File group minimum size
  • MTP/PTP device support updated
    (MTP/PTP devices are things like mobile phones or digital cameras)
    -Context menu issues with MTP/PTP devices fixed
    -Copy/Cut now working correctly with MTP/PTP devices
  • Improved tree loading speed and treemap rendering for drives containing very large numbers of files
  • Fixed context menu issues when running on Windows XP
    ( “ Send to ”  not working, missing text in sub menus)
  • Export to CSV would not export anything when  “ File view ”  selected and no files selected - now exports all files on the list。
  • Context menu issues with very long file names fixed
  • Improved detection of newly inserted USB drives
  • Added  “ Expand All ”  (Shift+F4) option to File menu - will expand all tree nodes
    Press F4 to reset the expansion
  • Portable version now defaults to starting in non admin mode
    Enable  “ Options->Always run as Administrator ” to have WiaTree always start in Admin mode
  • Fixed issue with config ini file settings not being read correctly when containing BOM marker (added by some text editors)
下载地址
WizTree v4.22 简体中文便携版,官方地址
适用 32 / 64 位的 Win XP、Vista、7、8、10、11
https://diskanalyzer.com/files/wiztree_4_22_portable.zip
文件指纹
名称:wiztree_4_22_portable.zip
大小:746,6656 字节 (7291 KiB)
CRC 32 :405AC40C
CRC 64 :E22C8BE74F25EE4F
XXH 64 :4AF4D2BC93D042A4
SHA 1   :FA6778A62E894032037B131B1339DECCF06F900F
SHA 256 :4E499C3D44823863532189FBCBEF21AFBC1D00FC4E312CB17B044FF3E50C5147
BLAKE2sp:D4D97B01F82E8DDA15A7C07EC516A557B22641A9B252455F3A5E5C7AA17F2A6E
发表于 2024-11-11 12:07:14 | 显示全部楼层
大容量的硬盘,必须配备的软件。
发表于 2024-11-11 17:11:08 | 显示全部楼层
我推荐Everything,搜索起来也很快。
发表于 2024-11-11 18:00:42 | 显示全部楼层
一直用这款分析硬盘中的文件占用,感谢分享。
发表于 2024-11-16 12:23:57 | 显示全部楼层
我一直在用,很好用的,速度超快
GMT+8, 2025-7-22 23:40 , Processed in 0.140400 second(s), 11 queries , Redis On.
