查看: 25623|回复: 24
[SMI] SM2258XT主控量产工具Flash.SET闪存参数官方定义
发表于 2020-3-10 11:34:53 | 显示全部楼层 |阅读模式
[ColumnName]
Manufacturer,Capacity,Part Number=ID0(H),ID1(H),ID2(H),ID3(H),ID4(H),ID5(H),Flash Type(D),Page Size(D),Spare Byte(D),Block Size(D),Page Number(D),Block Number(D),Minimum Block Number(D),Die Address(H),Plane Number(D),Internal Chip Number(D),CE Number(D),Channel(D),Flash Interface(H),Process(D),Sub-Process(H),Strong Weak Table Select(D),Flash CMD Option1(H),Flash CMD Option2(H),Table Setting(H),SLC CMD Ptn1(H),SLC CMD Ptn2(H),Reliable SLC Mode Option(H),SDR tWC(D),SDR tRC(D),DDR tWC(D),DDR tRC(D),CMD Set Table(D),Read Retry Table(D),SLC Read Retry Table(D),Initial Invalid Block Page(H),Initial Invalid Block Column(H),Initial Invalid Block Pattern(H),Initial Invalid Extend Option(H),ECC Bit(D),VccQ(D),Vcc(D),IO Driving 1(H),IO Driving 2(H),IO Driving 3(H),IO Driving 4(H),Endurance 1(D),Endurance 2(D),Endurance 3(D),Setting Status(H),Flash Status 1(H),Flash Status 2(H),SM2258XT Flash CMD Option 1(H),SM2258XT Flash CMD Option 2(H),SM2258XT Flash CMD Option 3(H),SM2258XT 25inch_Driving1_33V(H),SM2258XT 25inch_Driving2_33V(H),SM2258XT mSATA_Driving1_33V(H),SM2258XT mSATA_Driving2_33V(H),SM2258XT 25inch_Driving1_18V(H),SM2258XT 25inch_Driving2_18V(H),SM2258XT mSATA_Driving1_18V(H),SM2258XT mSATA_Driving2_18V(H),SM2258XT SLC_Block(H),SM2258XT ODT Option(H),SM2258XT Flash CMD Option 4(H),SM2258XT Flash Interface Speed(H),SM2258XT SLC Endurance 1(H),SM2258XT SLC Endurance 2(H),SM2258XT SLC Endurance 3(H),SM2258XT Flash Output Driving(H),
网友整理的SM2246闪存参数详解:http://bbs.mydigit.cn/read.php?tid=1378482
修改方法教程:https://www.mydigit.cn/thread-298203-1-1.html
发表于 2020-3-10 11:57:24 | 显示全部楼层
发表于 2020-3-10 13:24:19 | 显示全部楼层
回复 支持 0 反对 1
发表于 2020-3-10 14:14:17 | 显示全部楼层
发表于 2020-3-11 11:05:45 | 显示全部楼层
回复 支持 2 反对 0
发表于 2020-3-11 11:39:31 | 显示全部楼层
发表于 2020-3-11 21:32:16 | 显示全部楼层
回复 支持 2 反对 0
发表于 2020-3-11 21:34:13 | 显示全部楼层
发表于 2020-3-23 09:21:12 | 显示全部楼层
发表于 2020-3-24 16:55:50 | 显示全部楼层
发表于 2022-10-20 23:56:09 来自手机浏览器 | 显示全部楼层
发表于 2022-10-28 20:04:13 | 显示全部楼层
发表于 2022-10-29 01:08:55 | 显示全部楼层
发表于 2023-1-5 22:18:10 | 显示全部楼层
发表于 2023-1-6 19:33:11 | 显示全部楼层
发表于 2023-1-7 09:29:55 | 显示全部楼层
发表于 2023-3-29 08:26:35 | 显示全部楼层
发表于 2023-4-25 09:52:05 | 显示全部楼层
发表于 2023-4-27 15:22:09 | 显示全部楼层
GMT+8, 2026-6-14 01:35 , Processed in 0.249600 second(s), 11 queries , Gzip On, Redis On.
