The BCM6750 is a 2x2 Wi-Fi 6 system-on-a-chip (SoC) communications processor that enables low-power, small size, multi-gigabit access points, routers, repeaters and service provider gateways for residential applications. The SoC features a tri-core 1.5 GHz ARM Cortex CPU with a single 802.11ax two spatial stream (2×2) WLAN radio and five integrated 802.3-compliant Gigabit PHYs with multiport Ethernet switching.
Features- Triple Core ARM-A7 with 32 KB I/D caches and 512 KB L2 cache
- Integrated Gigabit Ethernet switch with multiple ports
- Fully coherent memory/CPU cache interconnect
- IEEE 802.11ax compliant MAC/BB/Radios
- Dual-bandOFDMA allowing for a higher density of simultaneous users
- Dual spatial stream multiplexing to 1.2-Gbps data rate
- IEEE 802.11a/b/g/n/ax, 2x2 20/40/80 MHz channels
- 1024-QAM modulation rates
- Expanded 6 GHz frequency coverage including spectrum up to 7125 MHz expected to become available under new regulatory rules
- Supports RangeBoost technology
- Provides support for LDPC in both TX and RX for increased wireless coverage
- CQI and CSI can be captured and passed to the host along with the MAC address associated with the captured data
- Supports Digital Pre-Distortion (DPD) reducing power consumption and improving band-edge performance
- Integrated 2.4 GHz power amplifiers and low-noise amplifiers
- Full IEEE 802.11a/b/g/n/ac legacy compatibility with enhanced performance
- Five IEEE 802.3 compliant Gigabit PHYs
- RGMII support
- 16-bit DDR3 interface operating at up to 800 MHz (1600 Mbps)
- NAND support of 128 Mbit to 4 GB devices
- SPI Master interface
- RGB LED driver with brightness, fade, and pulse capability
- 2x UART interfaces
- Complies with PCI Express base specification revision 2.0 for x1 lane and power management base specification
- One USB 3.1 Gen1 port
- Two USB 2.0 Gen1 ports
- PCM interface supporting up to 16 TDM channels and 32 time slots
- I2S Interface supporting master and slave clock source modes
- Supports Linux for access point and router applications
- Comprehensive wireless network security support that includes WPA,WPA2, and AES encryption/decryption
Applications- Residential Wi-Fi access points, routers and repeaters
- Service Provider Gateways
https://www.broadcom.com/products/wireless/wireless-lan-infrastructure/bcm6750
内置2.4G,5G无线,只能选一;;;三核心(tri-core 1.5 GHz ARM-A7 Cortex CPU)1.5G;;OFDMA 让多设备同时使用单一频段
